- Thank you received: 11
Building a chain driven Plasma table.
- Creative25
5 years 3 weeks ago #222549
by Creative25
Replied by Creative25 on topic Building a chain driven Plasma table.
Currently I am Wiring up the control box.
I just upgraded to Linuxcnc 2.9 and use Qtplasmac.
Seems things are much more simple compared to Plasmac.
But no I am a bit confused.
So I updated firmware for the Mesa board 6i76e
Now how do I get The Thcad working?
I run the pncconfig. There are two firmwares I can choose from. 7i76e and one For 7i76e_7i76x1_Dpl
Which is the right one?
Or do I still have to manually edit some hal files?
5 years 3 weeks ago #222597
It probably doesn't matter if you are just running the 7i76E with nothing on the expansion ports.
You might have to, but see how close you can get with the GUI configurator.
Replied by andypugh on topic Building a chain driven Plasma table.
- Creative25
5 years 3 weeks ago #222628
by Creative25
The Configurator did make a hal file with entries for the thcad.
Is there I way that i can make the thcad show the voltage without connecting a plasma cutter?
- Thank you received: 7491
5 years 3 weeks ago #222629
Replied by tommylight on topic Building a chain driven Plasma table.
Voltage is shown all the time, 0V if everything is set up properly when the torch is off.
If you have a THCAD5 or THCAD10, use a battery of 1.5 or 3 or 3,7 or 9V, it will show on screen but the value will be /scale.
- Creative25
5 years 3 weeks ago #222634
by Creative25
Thanks for the info.
If I connect a 1.5 volt battery i can see the Led on the Thcad blinks faster.
But on Qtplasmac it always shows Zero
I Attached the hal file that was generated by the Configurator.
5 years 3 weeks ago #222636
Screenshot of preferences?
Time to create page: 0.918 seconds
