- Thank you received: 2100
Building a chain driven Plasma table.
- phillc54
5 years 3 weeks ago #222731
by phillc54
Replied by phillc54 on topic Building a chain driven Plasma table.
It is called "qtplasmac.prefs.new_value"
The two values in there need to be used for Voltage Scale and Voltage Offset in the PARAMETERS tab.
If you have no manual edits in the main .hal or .ini files then you can use PnCconf as much as you like, these two files will be overwritten.
It will not overwrite custom.hal or custom_postgui.hal so it is best to keep your customisations in either of those.
It also won't overwrite qtplasmac.prefs if it exists, that is why qtplasmac.prefs.new_value is created.
- Creative25
- Thank you received: 11
5 years 3 weeks ago - 5 years 3 weeks ago #222760
by Creative25
Replied by Creative25 on topic Building a chain driven Plasma table.
Last edit: 5 years 3 weeks ago by Creative25.
- Creative25
5 years 3 weeks ago #222799
by Creative25
I just did an experiment
I changed the jumpers to F/32
And also the settings in pncconf
Now it just shows random numbers.
Just seems to be counting until it starts from zero again.
If I check it in hal meter the numbers jump between negative and positive numbers.
Is the counter supposed to reset so you get a frequency?
- Thank you received: 4153
5 years 3 weeks ago #222847
Replied by rodw on topic Building a chain driven Plasma table.
I suspect you are probably missing this from your hal file
Your are in the right place but its encoder.00.velocity you need to be watching on the watch tab.
# --- 7i76e ENCODER SETUP ---
setp hm2_7i76e.0.encoder.00.scale -1
setp hm2_7i76e.0.encoder.00.counter-mode 1
- Creative25
5 years 3 weeks ago - 5 years 3 weeks ago #222851
by Creative25
Mine looks like this, is that a problem?
# ---ARC VOLTAGE ENCODER---
net plasmac:arc-voltage-in <= hm2_7i76e.0.encoder.00.velocity
#setp hm2_7i76e.0.encoder.00.filter 1
- Creative25
5 years 2 weeks ago #222863
by Creative25
So I finally got it working.
Problem is I modified a config file from linuxcnc 2.8
So I ran PNCconfig. And made a new configuration from scratch.
I figured out for some reason F/1 does not work.
Somehow changes to Qtplasmac don’t work if you run the configuration again.
Is this a bug?
I changed Jumper to F/32 and Made another configuration from scratch. Now it works perfectly.
Is this a bug?
Time to create page: 2.946 seconds
