- Thank you received: 2100
Building a chain driven Plasma table.
- phillc54
5 years 2 weeks ago #222873
by phillc54
What changes?
Replied by phillc54 on topic Building a chain driven Plasma table.
Somehow changes to Qtplasmac don’t work if you run the configuration again.
Is this a bug?
What changes?
- Creative25
- Thank you received: 11
5 years 2 weeks ago #222876
by Creative25
Replied by Creative25 on topic Building a chain driven Plasma table.
Change from F/1 to F/32
And change to the 0 Volt frequency
Do not influence voltagedisplay.
However the change to 0 V frequency can be seen in the qtplasma…..new file.
- phillc54
5 years 2 weeks ago #222878
by phillc54
That is the expected behaviour:
forum.linuxcnc.org/38-general-linuxcnc-q...able?start=30#222731
- Creative25
5 years 2 weeks ago #223279
by Creative25
- Thank you received: 7491
5 years 2 weeks ago #223292
Replied by tommylight on topic Building a chain driven Plasma table.
Yes.
The following user(s) said Thank You: Creative25
- Creative25
2 years 2 months ago #309155
by Creative25
Hi to all so I am back after a ling break.
And I finally could start building my plasma table.
So far I got the tandem axis running which I chose to be the X axis.
Homing and everything Is running fine.
I also was able to Calibrate the Axis movement to within 2mm per 2 meters.
Dont have anything accurate to measure the movement except a tabe measure.
What is still have to do is to find out how much acceleration the Stepper motors can handle.
When i use the Motor tuning option in pnconfig. Only one of the motors is moving.
Is there a way to make both motors to move at the same time?
So far i use acceleration of 1000 and maximum Speed of 15000mm / min.
Seems to be running well without loosing steps.
What acceleration should I try to reach for good plasma cutting?
Time to create page: 0.334 seconds
