- Thank you received: 11
Building a chain driven Plasma table.
- Creative25
2 years 1 month ago - 2 years 1 month ago #310530
by Creative25
Replied by Creative25 on topic Building a chain driven Plasma table.
I got the water tray into an acceptable condition.
I removed the problem welds and
welded some slats underneath to straighten things out. (The sheets had a radius when they came back from bending)
Then I re welded them..
Next time I would cut them in such a way that seems will be shorter and all in the same direction. I hope this post will help some others hobby welders avoid the same problems.
Last edit: 2 years 1 month ago by Creative25.
- Creative25
2 years 1 month ago - 2 years 1 month ago #310849
by Creative25
- Thank you received: 5334
2 years 1 month ago #310855
Replied by PCW on topic Building a chain driven Plasma table.
That means the host computer has a latency issue of some kind
Common causes:
Power management/speed-step/Turbo modes/C states >C1 enabled in BIOS
Network hardware issues with Ethernet connected cards
With Intel MACs you need to disable IRQ coalescing (man hm2_eth)
With Realtek MACs and the LinuxCNC buster release you may need to install
the DKMS RTK8168 driver as the driver included with the shipped kernel is broken
Common causes:
- Creative25
2 years 1 month ago #310877
by Creative25
Thanks for the info.
Mine is an Intel MacBook 2012
Could you point me to some info on how to disable IRQ?
2 years 1 month ago #310904
The hm2_eth manual page has this information
man hm2_eth
Notes:
1. ethtool must be present (looks like it may be missing in the latest
LinuxCNC distribution so needs to be added)
2. This only applies to computers with Intel Ethernet hardware
man hm2_eth
Notes:
- Creative25
2 years 1 month ago #311067
by Creative25
I just installed ethtool.
Now there is no error message on startup.
Time to create page: 0.880 seconds
