Building a chain driven Plasma table.
2 years 1 month ago #311070 by Creative25
Replied by Creative25 on topic Building a chain driven Plasma table.
Next I want to add ohmic sensing. With a Thad.
I have downloaded the Firmware files from mesa. There are many files in the hostmot2 folder but have no idea which file I need to flash unto the 7i76E mesa board. What is the file name?
other question is about the serial resistor between positive and Thcad recommended is 390k but in one of the threads 25k is recommended can I freely experiment with resistors? Or does it need a high value to protect the Thcad?
2 years 1 month ago #311074 by PCW
Replied by PCW on topic Building a chain driven Plasma table.
7i76e_7i76x1_Dpl.bit is the firmware needed for a 7I76E and multiple THCADs
The load resistor for Ohmic sensing determines the sense current
I would not use higher than 25K
Note the if you use a lower value you need to make sure that you do not exceed
the resistors power rating with the open circuit plasma voltage.
2 years 1 month ago - 2 years 1 month ago #311087 by rodw
Replied by rodw on topic Building a chain driven Plasma table.
The hm2_eth manual page has this information
man hm2_eth
Notes:
1. ethtool must be present (looks like it may be missing in the latest
LinuxCNC distribution so needs to be added)
2. This only applies to computers with Intel Ethernet hardware
The latest distribution starts with a base image from Debian via Debian build.
I do remember installing Linuxcnc on Bookworm before the installer was created having to install ethtool. Is it included in a plain vanilla Debian 12 Install?
If ethtool is required by a Linuxcnc component and not installed by Debian, shouldn't ethtool be a prerequisite in our .deb file? This sounds like an issue that should be raised in Git.
Last edit: 2 years 1 month ago by rodw.
2 years 1 month ago #311090 by tommylight
Replied by tommylight on topic Building a chain driven Plasma table.
No, also not in Mint.
It is not required by LinuxCNC nor any of it's components, it is required only by some Intel NIC's to set the coalescence to 0.
2 years 1 month ago #311092 by rodw
Then I think the hm2_eth docs could be improved to show how to install it. I think its a Mesa specific setting. I don't think it is required on other Ethernet connected systems such as Ethercat. (this may be because Ethercat uses its own NIC drivers)
2 years 1 month ago #311093 by Creative25
I So I flashed the new firmware on the mesa card.
When I started Linuxcnc  the previous error came back. Jogging etc was still fine.
After this I  pasted the code from the Plasma primer into the custom Hal file.
Now I get the following error message.
Time to create page: 0.398 seconds
