- Thank you received: 11
Building a chain driven Plasma table.
- Creative25
2 years 3 weeks ago - 2 years 3 weeks ago #311356
by Creative25
Replied by Creative25 on topic Building a chain driven Plasma table.
So I thought I will share a bit about my chain driven machine. I learned it is possible to make a good machine that is chain driven. it has its own advantages and disadvantages. I found after dealing with all the plays of gears on shafts. Dealing with gears that don’t run true. I have a machine with zero backlash. it runs quiet hardly any chain noise except when moving long distances on maximum speeds. Also the bearings running on a rectangular tube has no issues. Only issue I have is that the X axis flexes a bit when the machine stops suddenly that’s why I reduced the acceleration to 750 mm. The shaking originates from the flexing of the two side plates of the Gantry during hard acceleration. So I will redesign them to make them lighter and more rigid. Hole cutting has improved a lot. But there is still more I can do.
Last edit: 2 years 3 weeks ago by Creative25.
- Creative25
2 years 3 weeks ago - 2 years 3 weeks ago #311361
by Creative25
I have added some buttons to the control box. But it seems Qtplasmac just ignores them. I have configured them with pncconf.
In halshow I can see that the machine reads them. But that’s all if I press the white button that is configured to start a cycle nothing happens. Are there more things that I need to configure so that the button will work?
Is there any tutorial about adding physical buttons?
- phillc54
- Thank you received: 2100
2 years 3 weeks ago #311373
by phillc54
Replied by phillc54 on topic Building a chain driven Plasma table.
Are the buttons connected to the appropriate QtPlasmaC external HAL pins?
linuxcnc.org/docs/2.9/html/plasma/qtplas...l#plasma:ext-hal-pin
The following user(s) said Thank You: Creative25
- Creative25
2 years 3 weeks ago #311388
by Creative25
So basically pncconfig does not do configurations that are specific to qtplasmac.
Could I move the appropriate lines for these buttons from my Hal file to the postguy halfile. And just replace the pins that pncconfig created with the appropriate Qtplasmac external Hal pins?
- phillc54
2 years 3 weeks ago #311389
by phillc54
PNCconf has not been taught anything about the external HAL pins.So basically pncconfig does not do configurations that are specific to qtplasmac.
Yes, that should work fine.Could I move the appropriate lines for these buttons from my Hal file to the postguy halfile. And just replace the pins that pncconfig created with the appropriate Qtplasmac external Hal pins?
- Creative25
2 years 3 weeks ago #311418
by Creative25
Time to create page: 0.732 seconds
