Installing second parallel port
06 Jun 2021 13:16 #211296 by john11668
Installing second parallel port was created by john11668
Right ! so next problem ( there is always another )
Have tried to follow this guys advice even though he does not seem to be brimming with confidence :(
So I go to the lspci -vv command and open a get something not a lot different to him but no clear parallel port in the screed
have tried adding a couple options into my hal file saved , then opened gmocappy
In one case come up with a screen which barrs the reset button so went back to original
In second case it comes up with parallel port not found at 1012
File is attached:-
Can anyone see from this what I need to add to my hal in order for my second parallel port to be seen by EMC
File Name: ispci.txt.txt
File Size:10 KB
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
06 Jun 2021 13:49 - 10 Jun 2021 15:51 #211298 by BeagleBrainz
Replied by BeagleBrainz on topic Installing second parallel port
I’m
Last edit: 10 Jun 2021 15:51 by BeagleBrainz.
06 Jun 2021 16:40 #211308 by john11668
Replied by john11668 on topic Installing second parallel port
Yup, Pretty similar problem , but doesnt look like Dragonbits cnc has found an answer either.
  • BeagleBrainz
  • Visitor
  • Visitor
06 Jun 2021 17:51 - 10 Jun 2021 15:52 #211311 by BeagleBrainz
done
Last edit: 10 Jun 2021 15:52 by BeagleBrainz.
06 Jun 2021 18:17 #211313 by john11668
got this
06 Jun 2021 18:18 #211314 by john11668
sorry about the stuttering finger
  • BeagleBrainz
  • Visitor
  • Visitor
06 Jun 2021 18:52 - 10 Jun 2021 15:53 #211317 by BeagleBrainz
wasting
Last edit: 10 Jun 2021 15:53 by BeagleBrainz.
06 Jun 2021 20:24 #211347 by john11668
Who, or what is Sudo ??
06 Jun 2021 20:56 #211352 by tommylight
Replied by tommylight on topic Installing second parallel port
sudo cat /proc/ioports | grep parport
The following user(s) said Thank You: john11668
06 Jun 2021 21:26 #211356 by john11668
Will try this shortly and report.
Time to create page: 0.108 seconds
