Installing second parallel port
08 Jun 2021 09:44 #211491 by john11668
Replied by john11668 on topic Installing second parallel port
Ok!
So this thread does not really seem to be leading anywhere constructive .
The stepconfig process clearly allows for a configuration employing two parallel ports and I would like to go this way.
So what must I do to get my computer into a suitable configuration to allow me to do this.
I dont really need to be told what will not work, or that I need Mesa, ethernet joystick controller, or whatever ,
I do need to speak to those who have successfully installed and use two parallel ports , and can explain to me, preferably in words of one syllable how to add a second usable one to my computer.
Anyone out there who successfully uses this configuration and can help me ?
  • Moderator
  • Moderator
08 Jun 2021 10:33 #211493 by tommylight
Replied by tommylight on topic Installing second parallel port
Attached is a config for two parallel ports used to drive 4 servo motors with simple PWM drives.
Notice the
loadrt
addf
and pin names
Ignoring our replies is not helping you, you have a built in parallel port on the PC, so take a picture of the board and upload it here. I had the same PC (several of them) and they all came with a header and work properly with NO installation of any drivers.
For add on cards, it is not listed on your result of cat/proc, so it is not seen by Linux, so try inserting it into another slot if possible and check again.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
08 Jun 2021 12:10 - 10 Jun 2021 16:00 #211503 by BeagleBrainz
Replied by BeagleBrainz on topic Installing second parallel port
la
Last edit: 10 Jun 2021 16:00 by BeagleBrainz.
08 Jun 2021 16:26 #211525 by Clive S
Replied by Clive S on topic Installing second parallel port
These cards work fine.
Startech PEX1P Parallel Port 1 Port Adapter PCIe Card
08 Jun 2021 17:41 #211530 by john11668
08 Jun 2021 19:47 - 08 Jun 2021 21:27 #211535 by Clive S
So one of these Clive ?
www.ebay.co.uk/itm/254930870151?chn=ps&n...1ead965fa1b1072eb21c
Yes as long as you have the correct slot for the card..
I purchased 5 of them used for £25. All 5 worked fine
Last edit: 08 Jun 2021 21:27 by Clive S.
08 Jun 2021 21:47 #211550 by john11668
Have 2 PCI slots (one long, one longer ) both longer than this card .
08 Jun 2021 22:42 #211555 by john11668
Pic of my motherboard as requested Tommy
I have ordered a header but not sure if there is a suitable connector on the board. There is a 25 pin "serial 2 " port by the end of the long PCI slot but not sure if it is big enough for the header . I would happily order the card you suggest Clive but again unsure if it will fit either if my PCI slots . My own previous attempt was fitted into the shorter of the two slots but clearly was not visible to the system for whatever reason.
I will try it in the longer slot tomorrow.
www.ebay.co.uk/itm/303920082347
I was not ignoring replies , just having some difficulty interpreting particularly the one liners .
Just to remind you folks I am a novice to linux , so what seems obvious to you may not be clear to me .
Please bear with me .
08 Jun 2021 23:16 - 08 Jun 2021 23:18 #211560 by fc60
Replied by fc60 on topic Installing second parallel port
Greetings,
My meager offering.
The white slot on the right appears to be a PCI slot.
The white slot in the middle looks like a PCIe (PCI Express) slot.
The link you provided earlier is a PCIe1X board. I do not see any such slots in your photo. (It would look like the other two white ones only about 25mm long.)
Most aftermarket boards are made by a major manufacturer and they just put different stickers on them
Linux looks for the chip manufacturer as the operating system has files to configure it.
Try to source a PCI parallel port card locally, preferably used, so you can return it for a different brand if needed. Remember, it is the "CHIP" that Linux looks for.
Here is a link to a good graphic description of the various slots...
PCI Slots
Cheers,
David
Formerly from Northowram.
Last edit: 08 Jun 2021 23:18 by fc60. Reason: Spelling, of course!!!
  • Moderator
  • Moderator
09 Jun 2021 00:05 #211567 by tommylight
Cancel the order, please, there is already a parallel port on that MB.
How many topic are currently running the same subject ?
I am sure there are two made by the same member and another one .....
Just thinking out loud, this got messed up so i will do a rerun tomorrow and check where i messed up, if i did.
2AM here ....
The following user(s) said Thank You: john11668
