Emco compact 5 Pc pin out help
  • Moderator
  • Moderator
24 Jul 2022 18:19 #248186 by tommylight
Replied by tommylight on topic Emco compact 5 Pc pin out help
Sam might be on to something, that sounds more like miss used gearbox
The following user(s) said Thank You: Franzmeizter
28 Jul 2022 19:51 - 19 Nov 2022 17:23 #248580 by Franzmeizter
Replied by Franzmeizter on topic Emco compact 5 Pc pin out help
I think the problem is related to the gearbox because there is a set of gears missing. I have not pulled of the belt yet but I will do that to see if the sound comes from the gearbox or the motor. I assume that I have to start look for the gear set between the motor and the spindle, otherwise I am afraid I can not regulate the span of the rpm...
Last edit: 19 Nov 2022 17:23 by Franzmeizter.
30 Jul 2022 13:34 #248670 by skunkworks
Replied by skunkworks on topic Emco compact 5 Pc pin out help
can you take a picture of the rpm chart on the door - you are not missing any gears but might be missing an idler pulley...
Time to create page: 0.285 seconds
