loading LinuxCNC on old smithy 1240
- LPMattei
20 Sep 2022 18:39 #252427
by LPMattei
loading LinuxCNC on old smithy 1240 was created by LPMattei
I have an old Smithy 1240, I want to load the latest, or at least more recent version of LinuxCNC. I am very new to this, so apologies if this is too dumb a question. My Smithy 1240 currently runs 2.5.4 and everything works fine, but I want to add a usb pendant and it doesn't look like it will work , I put in a new drive and loaded the latest version, and LinuxCNC wont start, it gives an error that it cannot find firmware hm2/5i20/sssvst2_2_4_v31.bit. My assumption is there is a configuration that needs to be done, but I have no info on the machine configuration.
So I guess my questions are:
A: Can the SW be updated while saving the current configuration?
B: Can someone point me to info on how to configure the software if A: is not possible?
C: Does someone have this working and is willing to send me a working / configured copy of it?
- Thank you received: 5328
20 Sep 2022 20:43 #252441
Replied by PCW on topic loading LinuxCNC on old smithy 1240
as a first step, I would copy the existing firmware file and configuration files
from the original hard drive and transfer them to the new installation drive
There is a built-in utility to update configuration files (from 2.7 to 2.8/2.9) but I am not sure if it works on 2.5.X version files
- LPMattei
20 Sep 2022 22:46 #252450
by LPMattei
Replied by LPMattei on topic loading LinuxCNC on old smithy 1240
Can you point me to where those files are, I had copied the file it was barking about, but it didn't seem to help
20 Sep 2022 23:00 #252451
The firmware file should be in
/lib/firmware/hm2/5i20/
You will need to duplicate this directory on the new installation disk
The hal and ini files should be in
~/linuxcnc/configs
~/linuxcnc/configs
- LPMattei
25 Sep 2022 18:34 #252722
by LPMattei
Thank you, I will try that
- LPMattei
25 Sep 2022 20:51 - 25 Sep 2022 21:37 #252738
by LPMattei
OK, I moved the files and now I get a new error relating to 1240combined.hal max current. I ran latency test as it said, but I didn't see it matter. Attached are the error and section from 1240combined.hal file
Last edit: 25 Sep 2022 21:37 by LPMattei.
26 Sep 2022 14:41 #252771
Is the 8I20 powered?
- LPMattei
26 Sep 2022 16:46 #252785
by LPMattei
I would have to say yes, if I swap in the disk with the old version SW it works fine
26 Sep 2022 20:30 #252799
Can you try commenting out that line (line 86) in the hal file
and trying to start LinuxCNC again.
I think possibly some pin names changed over the years
- LPMattei
26 Sep 2022 22:42 #252811
by LPMattei
I tried that, then I commented the next 3 lines that failed.
# setp hm2_5i20.0.stepgen.03.position-scale [AXIS_3]SCALE
# setp hm2_5i20.0.stepgen.03.maxaccel [AXIS_3]STEPGEN_MAXACCEL
# setp hm2_5i20.0.stepgen.03.maxvel [AXIS_3]STEPGEN_MAXVEL
then it gave following error
./1240combined.hal:191: Pin 'hm2_5i20.0.8i20.0.0.amp_enable' does not exist
I feel like it is missing something and I will be chasing the errors all the way down.
Time to create page: 0.190 seconds
