loading LinuxCNC on old smithy 1240
- Thank you received: 5328
26 Sep 2022 22:48 #252813
Replied by PCW on topic loading LinuxCNC on old smithy 1240
Can you post the hal/ini files here?
- LPMattei
27 Sep 2022 19:13 #252880
by LPMattei
Replied by LPMattei on topic loading LinuxCNC on old smithy 1240
Here are both files
- LPMattei
27 Sep 2022 19:29 #252886
by LPMattei
On a whim, I thought I would try something different, instead of running the 1240combined like the old version was, I tried running the regular 1240 config. GUI came up, but the watchdog bit, But I think I am further than I was, but I don't know how to get un bit
- LPMattei
16 Oct 2022 23:36 #254295
by LPMattei
Peter, any luck with Hal or ini files?
17 Oct 2022 00:32 #254296
You would need to post the current hal/ini files
- LPMattei
17 Oct 2022 03:02 #254303
by LPMattei
I posted them above on 27 Sept. Is that the wrong way?
- LPMattei
27 Oct 2022 21:09 #255244
by LPMattei
# 5i20 config file for Smithy 1240 Mill
# load the hostmot2 driver, this doesnt do anything by itself,
# it just waits for low-level drivers to register boards
loadrt hostmot2 debug_idrom=1 debug_module_descriptors=1 debug_pin_descriptors=1 debug_modules=1
# load the low-level driver for the board
# this will load the board's firmware and register it with the hostmot2
# driver loaded above, and it'll show up in HAL
loadrt hm2_pci config="firmware=hm2/5i20/sssvst2_2_4_v31.bit num_encoders=1 num_pwmgens=0 num_stepgens=4 sserial_port_0=0xxxxxxx enable_raw"
#loadrt hm2_pci config="firmware=hm2/5i20/sssvst2_2_2_v35.bit num_encoders=1 num_pwmgens=0 num_stepgens=4 enable_raw"
# 13312 = 0x3400 = Encoder Sample Rate Register
setp hm2_5i20.0.raw.write_address 13312
# sample rate is clock (33 MHz)/SRR+2 = 33MHz/10 = 3.3MHz
setp hm2_5i20.0.raw.write_data 8
# write data
setp hm2_5i20.0.raw.write_strobe 1
# set up the watchdog
#setp hm2_5i20.0.watchdog.timeout_ns 10000000
# load kinematics
loadrt [KINS]KINEMATICS
#autoconverted trivkins
# load motion controller, get name and thread periods from ini file
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD traj_period_nsec=[EMCMOT]TRAJ_PERIOD key=[EMCMOT]SHMEM_KEY num_joints=[KINS]JOINTS
# load charge pump
loadrt charge_pump
setp charge-pump.enable TRUE
# load and configure the spindle speed PID
loadrt pid num_chan=1
setp pid.0.Pgain 0.1
setp pid.0.Igain 100.0
setp pid.0.Dgain 0.0
setp pid.0.maxoutput 1.0
setp pid.0.deadband 0.01
# load and configure the spindle speed limiting, filtering, and comparison blocks
# Need this line so AXIS shows +/- buttons
net srpm spindle.0.speed-out
# Limit bounds and slew rate/second
loadrt limit2
setp limit2.0.min -100
setp limit2.0.max 100
setp limit2.0.maxv 50
# Stalled spindle detector
loadrt abs
loadrt comp count=2
setp comp.0.in0 1.0
setp comp.1.in0 0.0
loadrt and2 count=2
# Filter srps
loadrt lowpass
setp lowpass.0.gain 0.07
# Spindle at-speed detection
loadrt near
setp near.0.scale 1.1
setp near.0.difference 0.1
net srps spindle.0.speed-out-rps limit2.0.in near.0.in1
net scmd limit2.0.out pid.0.command
net fb hm2_5i20.0.encoder.00.velocity pid.0.feedback spindle.0.speed-in lowpass.0.in comp.1.in1
net sflt lowpass.0.out near.0.in2
net at-speed near.0.out spindle.0.at-speed
net scur-abs abs.0.out comp.0.in1
net scmd-ok comp.0.equal and2.0.in0
net sfb-ok comp.1.equal and2.0.in1
net stall and2.0.out
# These loopbacks are usually disconnected by a postgui halfile
net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
net tool-prepare-loopback iocontrol.0.tool-prepare iocontrol.0.tool-prepared
### q = encoder, h=hall sensors, i=index
loadrt bldc cfg=qh
setp bldc.0.rev 1
setp hm2_5i20.0.encoder.00.scale 2880
net Spos hm2_5i20.0.encoder.00.position spindle.0.revs
net Sidx hm2_5i20.0.encoder.00.index-enable spindle.0.index-enable
net pid-out pid.0.output bldc.0.value
net rawcount hm2_5i20.0.encoder.00.rawcounts
net rotor_angle hm2_5i20.0.8i20.0.0.angle bldc.0.rotor-angle
setp hm2_5i20.0.8i20.0.0.max_current 30.0
net current bldc.0.out hm2_5i20.0.8i20.0.0.current abs.0.in
### IF cfg==*q* uncomment these lines
setp bldc.0.initvalue 0.8
setp bldc.0.lead-angle 0
### 2.2kW Motor
setp bldc.0.poles 4
### 1kW Motor
#setp bldc.0.poles 8
setp bldc.0.scale -2880
net rawcount bldc.0.rawcounts
### IF cfg==*h* uncomment these lines
net spindle-on spindle.0.on pid.0.enable
net sa bldc.0.hall1 hm2_5i20.0.gpio.005.in
net sb bldc.0.hall2 hm2_5i20.0.gpio.007.in
net sc bldc.0.hall3 hm2_5i20.0.gpio.009.in
### 2.2kW Motor
setp bldc.0.pattern 17 # 17 or 44
### 1kW Motor
#setp bldc.0.pattern 34 # 15 or 34
### ELSE uncomment these lines
#net amp-enable bldc.0.init
#net init-done bldc.0.init-done
### IF cfg==*i* uncomment this line
#net Sidx bldc.0.index-enable
# invert the step pulse polarity
setp hm2_5i20.0.gpio.000.invert_output TRUE
setp hm2_5i20.0.gpio.002.invert_output TRUE
setp hm2_5i20.0.gpio.016.invert_output TRUE
setp hm2_5i20.0.gpio.018.invert_output TRUE
# configure the stepgen parameters
setp hm2_5i20.0.stepgen.00.dirsetup 5000
setp hm2_5i20.0.stepgen.00.dirhold 2000
setp hm2_5i20.0.stepgen.00.steplen 2000
setp hm2_5i20.0.stepgen.00.stepspace 2000
setp hm2_5i20.0.stepgen.00.position-scale [JOINT_0]SCALE
setp hm2_5i20.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_5i20.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
setp hm2_5i20.0.stepgen.01.dirsetup 5000
setp hm2_5i20.0.stepgen.01.dirhold 2000
setp hm2_5i20.0.stepgen.01.steplen 2000
setp hm2_5i20.0.stepgen.01.stepspace 2000
setp hm2_5i20.0.stepgen.01.position-scale [JOINT_1]SCALE
setp hm2_5i20.0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_5i20.0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
setp hm2_5i20.0.stepgen.02.dirsetup 5000
setp hm2_5i20.0.stepgen.02.dirhold 2000
setp hm2_5i20.0.stepgen.02.steplen 2000
setp hm2_5i20.0.stepgen.02.stepspace 2000
setp hm2_5i20.0.stepgen.02.position-scale [JOINT_2]SCALE
setp hm2_5i20.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_5i20.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
setp hm2_5i20.0.stepgen.03.dirsetup 5000
setp hm2_5i20.0.stepgen.03.dirhold 2000
setp hm2_5i20.0.stepgen.03.steplen 2000
setp hm2_5i20.0.stepgen.03.stepspace 2000
setp hm2_5i20.0.stepgen.03.position-scale [AXIS_3]SCALE
setp hm2_5i20.0.stepgen.03.maxaccel [AXIS_3]STEPGEN_MAXACCEL
setp hm2_5i20.0.stepgen.03.maxvel [AXIS_3]STEPGEN_MAXVEL
# connect position commands from motion module to step generator
net Xpos-cmd joint.0.motor-pos-cmd hm2_5i20.0.stepgen.00.position-cmd
net Ypos-cmd joint.1.motor-pos-cmd hm2_5i20.0.stepgen.01.position-cmd
net Zpos-cmd joint.2.motor-pos-cmd hm2_5i20.0.stepgen.02.position-cmd
#net Apos-cmd joint.3.motor-pos-cmd hm2_5i20.0.stepgen.03.position-cmd
# connect position feedback from step generators to motion module
net Xpos-fb hm2_5i20.0.stepgen.00.position-fb joint.0.motor-pos-fb
net Ypos-fb hm2_5i20.0.stepgen.01.position-fb joint.1.motor-pos-fb
net Zpos-fb hm2_5i20.0.stepgen.02.position-fb joint.2.motor-pos-fb
#net Apos-fb hm2_5i20.0.stepgen.03.position-fb joint.3.motor-pos-fb
# connect enable signals for step generators
net Xen joint.0.amp-enable-out hm2_5i20.0.stepgen.00.enable
net Yen joint.1.amp-enable-out hm2_5i20.0.stepgen.01.enable
net Zen joint.2.amp-enable-out hm2_5i20.0.stepgen.02.enable
#net Aen joint.3.amp-enable-out hm2_5i20.0.stepgen.03.enable
# enable velocity mode jogging
setp joint.0.jog-vel-mode TRUE
setp axis.x.jog-vel-mode TRUE
setp joint.1.jog-vel-mode TRUE
setp axis.y.jog-vel-mode TRUE
setp joint.2.jog-vel-mode TRUE
setp axis.z.jog-vel-mode TRUE
#setp joint.3.jog-vel-mode axis.a.jog-vel-mode TRUE
# connect the charge pump signal to an output
setp hm2_5i20.0.gpio.022.is_output TRUE
net chargepump hm2_5i20.0.gpio.022.out charge-pump.out
# Safety Relay Monitoring Contacts
net estop-enable hm2_5i20.0.gpio.037.in iocontrol.0.emc-enable-in
# Run Switch
loadrt debounce cfg=1
setp debounce.0.delay 1000
net key-on hm2_5i20.0.gpio.039.in_not debounce.0.0.in
net machine-on debounce.0.0.out hm2_5i20.0.sserial.port-0.run hm2_5i20.0.8i20.0.0.amp_enable halui.machine.on
#connect limit switches to limit inputs
net Xmax hm2_5i20.0.gpio.024.in_not joint.0.pos-lim-sw-in
net Xmin hm2_5i20.0.gpio.026.in_not joint.0.neg-lim-sw-in
net Ymax hm2_5i20.0.gpio.028.in_not joint.1.pos-lim-sw-in
net Ymin hm2_5i20.0.gpio.030.in_not joint.1.neg-lim-sw-in
net Zmax hm2_5i20.0.gpio.032.in_not joint.2.pos-lim-sw-in
net Zmin hm2_5i20.0.gpio.034.in_not joint.2.neg-lim-sw-in
#connect positive limit signals to home inputs
net Xmax joint.0.home-sw-in
net Ymax joint.1.home-sw-in
net Zmax joint.2.home-sw-in
# Spindle Contactor Enable
setp hm2_5i20.0.gpio.041.is_output TRUE
setp hm2_5i20.0.gpio.041.invert_output TRUE
# Door Closed - Energizes spindle contactor
net CLOSED hm2_5i20.0.gpio.029.in_not hm2_5i20.0.gpio.041.out
# Main Contactors - True when both contactors are energized
net ACOK hm2_5i20.0.gpio.035.in_not
# VFD Fault Relay - True when VFD is not faulted
#net VFDOK hm2_5i20.0.gpio.031.in_not
# A Axis Home - On Sieg machines there is no VFD fault signal,
# it is used for the A axis home sensor on 4 axis machines
#net AHOME hm2_5i20.0.gpio.031.in joint.3.home-sw-in
# Stop on any spindle fault
loadrt or2
#net VFDOK hm2_5i20.0.gpio.031.in_not and2.1.in0
net VFDOK hm2_5i20.0.gpio.031.in_not or2.0.in0
#net AUTO halui.mode.is-auto and2.1.in1
net stall or2.0.in1
#net ABORT and2.1.out halui.abort
net ABORT or2.0.out halui.abort
# Spindle Contactor - False when spindle contactor is energized
net SOFF hm2_5i20.0.gpio.033.in halui.program.pause motion.feed-hold
# Axis Drive Status Signals
# True when YAKO stepper drive is on a full step position
# True when a Leadshine stepper drive is in the READY state
net DRV0 hm2_5i20.0.gpio.025.in_not
net DRV1 hm2_5i20.0.gpio.027.in_not
net DRV2 hm2_5i20.0.gpio.036.in_not
net DRV3 hm2_5i20.0.gpio.038.in_not
# Output Bits
# Link Spindle Direction Signals to make AXIS Display Buttons
net FWD spindle.0.reverse
net REV spindle.0.forward
# Flood Coolant
setp hm2_5i20.0.gpio.043.is_output TRUE
setp hm2_5i20.0.gpio.043.invert_output TRUE
net M8 hm2_5i20.0.gpio.043.out iocontrol.0.coolant-flood
# Mist Coolant
setp hm2_5i20.0.gpio.045.is_output TRUE
setp hm2_5i20.0.gpio.045.invert_output TRUE
net M7 hm2_5i20.0.gpio.045.out iocontrol.0.coolant-mist
# hook the functions to threads
# read inputs
addf hm2_5i20.0.read servo-thread
# handle motion commands
# run the motion controller
# limit the spindle speed command
addf limit2.0 servo-thread
# do spindle pid calcs
addf pid.0.do-pid-calcs servo-thread
# filter encoder velocity
addf lowpass.0 servo-thread
# compare filtered encoder velocity to commanded
addf near.0 servo-thread
# detect a stalled spindle
addf abs.0 servo-thread
addf comp.0 servo-thread
addf comp.1 servo-thread
addf and2.0 servo-thread
# delay running the 8i20 smart serial channel
addf debounce.0 servo-thread
# detect a spindle fault
#addf and2.1 servo-thread
addf or2.0 servo-thread
# write outputs
addf hm2_5i20.0.write servo-thread
# run bldc function
addf bldc.0 servo-thread
# pet the watchdog so he won't bite us!
addf hm2_5i20.0.pet_watchdog servo-thread
# toggle the charge pump
addf charge-pump servo-thread
# write data
# load kinematics
# load charge pump
loadrt charge_pump
loadrt limit2
loadrt abs
loadrt comp count=2
setp comp.0.in0 1.0
setp comp.1.in0 0.0
loadrt and2 count=2
# Filter srps
loadrt lowpass
loadrt near
loadrt bldc cfg=qh
setp bldc.0.rev 1
### 2.2kW Motor
setp bldc.0.poles 4
### 1kW Motor
### 2.2kW Motor
### 1kW Motor
# Run Switch
loadrt or2
net stall or2.0.in1
# Output Bits
# Flood Coolant
# Mist Coolant
# read inputs
# write outputs
# run bldc function
- LPMattei
27 Oct 2022 21:11 #255245
by LPMattei
# This config file was created 2022-09-25 16:14:19.542872 by the update_ini script
# The original config files may be found in the /home/smithy/linuxcnc/configs/by_machine.smithy/1240combined.old.old directory
# EMC controller parameters for Mesa 5i20 controlled Smithy 1240 Mill
[EMC]
MACHINE = Smithy 1240 Combined Box Mill
VERSION = 1.1
DEBUG = 0x00000000
#DEBUG = 0x7FFFFFFF
[DISPLAY]
#DISPLAY = eztrol
# CYCLE_TIME is used by eztrol
CYCLE_TIME = .1
DISPLAY = axis
#DISPLAY = mini
#DISPLAY = tkemc
#HELP_FILE = /usr/share/doc/emc2/tklinucnc.txt
#DISPLAY = xemc
#HELP_FILE = /usr/share/doc/emc2/xlinucnc.txt
#DISPLAY = keystick
TKPKG = Ngcgui 1.0
TKPKG = Ngcguittt 1.0
# note: ngcgui_app.tcl must precede ngcgui_ttt.tcl
NGCGUI_FONT = Helvetica -12 normal
TTT = truetype-tracer
TTT_PREAMBLE = in_std.ngc
NGCGUI_PREAMBLE = in_std.ngc
NGCGUI_POSTAMBLE = bye.ngc
NGCGUI_SUBFILE = backlash.ngc
NGCGUI_SUBFILE = hole_circle.ngc
NGCGUI_SUBFILE = helix.ngc
NGCGUI_SUBFILE = helix_rtheta.ngc
NGCGUI_SUBFILE = slot.ngc
NGCGUI_SUBFILE = simp.ngc
NGCGUI_SUBFILE = xyz.ngc
NGCGUI_SUBFILE = iquad.ngc
NGCGUI_SUBFILE = oquad.ngc
NGCGUI_SUBFILE = db25.ngc
NGCGUI_SUBFILE = ihex.ngc
NGCGUI_SUBFILE = ohex.ngc
NGCGUI_SUBFILE = gosper.ngc
NGCGUI_SUBFILE = ""
#NGCGUI_SUBFILE = "" use when imageframe is specified if
# opening other files is required
# images will be put in a toplevel window
NGCGUI_OPTIONS =
#NGCGUI_OPTIONS = opt1 opt2 ...
# opt items:
# nonew -- disallow making a new tab page
# noremove -- disallow removing any tab page
# noauto -- no autosend (makeFile, then manually send)
# noiframe -- no internal image, image on separate toplevel
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.5
MIN_SPINDLE_OVERRIDE = 0.2
MAX_SPINDLE_OVERRIDE = 1.5
INTRO_TIME = 5
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
PROGRAM_PREFIX = ../../nc_files/
EDITOR = gedit
TOOL_EDITOR = tooledit
DEFAULT_LINEAR_VELOCITY = 0.2
# @SCALE = 25600
#MAX_LINEAR_VELOCITY = 1.9
# @SCALE = 10000
MAX_LINEAR_VELOCITY = 4.2
DEFAULT_ANGULAR_VELOCITY = 12.0
MAX_ANGULAR_VELOCITY = 85
#PYVCP = 8i20.xml
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[RS274NGC]
PARAMETER_FILE = emc.var
SUBROUTINE_PATH = ../../nc_files/ngcgui_lib:../../nc_files/ngcgui_lib/utilitysubs
USER_M_PATH = ../../nc_files/ngcgui_lib/mfiles
[EMCMOT]
EMCMOT = motmod
SHMEM_KEY = 111
COMM_TIMEOUT = 1.0
BASE_PERIOD = 250000
SERVO_PERIOD = 250000
TRAJ_PERIOD = 250000
[TASK]
TASK = milltask
CYCLE_TIME = 0.001
[HAL]
HALUI = halui
HALFILE = 1240combined.hal
#HALFILE = naiky.hal
EZTROL_HALFILE = 5i20eztrol.hal
POSTGUI_HALFILE = axis_manualtoolchange.hal
POSTGUI_HALFILE = 8i20postgui.hal
[HALUI]
#No Content
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
# @SCALE = 25600
# @SCALE = 10000
MAX_LINEAR_ACCELERATION = 10.0
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = mill.tbl
#TOOL_CHANGE_POSITION = 0 0 2
#TOOL_CHANGE_WITH_SPINDLE_ON = 1
TOOL_CHANGE_QUILL_UP = 1
#TOOL_CHANGE_AT_G30 = 1
[KINS]
KINEMATICS = trivkins coordinates=XYZ
#This is a best-guess at the number of joints, it should be checked
JOINTS = 3
[AXIS_X]
MIN_LIMIT = -21.8
MAX_LIMIT = 0.2
MAX_VELOCITY = 4.2
MAX_ACCELERATION = 10.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.000
# @SCALE = 25600
#MAX_VELOCITY = 1.9
# @SCALE = 10000
MAX_VELOCITY = 4.2
STEPGEN_MAXVEL = 4.9
STEPGEN_MAXACCEL = 40000
BACKLASH = 0.0005
# Leadscrew Pitch = 5mm
# Drive Ratio = 1:1
# Steps/Rev = 25600
# Vel at 250k Steps/S = 115"/min
#SCALE = 130048
# Steps/Rev = 10000
# Vel at 250k Steps/S = 295"/min
SCALE = 50800
OUTPUT_SCALE = 1.000
MIN_LIMIT = -21.8
MAX_LIMIT = 0.2
FERROR = 0.25
MIN_FERROR = 0.1
HOME_OFFSET = 0.25
HOME_SEARCH_VEL = 0.5
HOME_LATCH_VEL = 0.05
HOME_FINAL_VEL = 0.5
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 2
[AXIS_Y]
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
MAX_VELOCITY = 4.2
[JOINT_1]
TYPE = LINEAR
HOME = 0.000
# @SCALE = 25600
#MAX_VELOCITY = 1.9
# @SCALE = 10000
MAX_VELOCITY = 4.2
BACKLASH = 0.0015
# Drive Ratio = 1:1
# Steps/Rev = 25600
#SCALE = -130048
# Steps/Rev = 10000
SCALE = -50800
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
FERROR = 0.25
MIN_FERROR = 0.1
HOME_OFFSET = 0.25
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
[AXIS_Z]
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
MAX_VELOCITY = 4.2
[JOINT_2]
TYPE = LINEAR
HOME = 0.000
# @SCALE = 25600
#MAX_VELOCITY = 1.9
# @SCALE = 10000
MAX_VELOCITY = 4.2
BACKLASH = 0.0000
# Drive Ratio = 1:1
# Steps/Rev = 25600
#SCALE = -130048
# Steps/Rev = 10000
SCALE = -50800
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
FERROR = 0.25
MIN_FERROR = 0.1
HOME_OFFSET = 0.25
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[EZTROL]
QTEMC_PLUGIN = /usr/share/eztrol/lib/libqtemc-2.4.6.so
QTEMCHAL_PLUGIN = /usr/share/eztrol/lib/libqtemchal-2.4.6.so
EZTROLGUI = /usr/share/eztrol/eztrolgui/libguimill2.so
MAX_SPINDLE_RPM = 4000
DIR_PLUGIN = /usr/share/eztrol/eztrolplugins
PLUGIN = libeztrol_wizard_plugin.so
PLUGIN = libeztrol_webwizard_plugin.so
# disabling settings gcode editor will benefit systems with small memory size
ENABLE_SETTINGS_EDITOR = true
# disable OpenGL 3D Preview
ENABLE_3D_PREVIEW = true
# set to Full Screen TRUE/FALSE
FULLSCREEN = false
# Settings Tab GCode Editor Syntax Highlight
# color guide - www.w3.org/TR/SVG/types.html#ColorKeywords
AXIS_COLOR = magenta
LINENUMBER_COLOR = rosybrown
GM_COLOR = blue
STFDRLPQH_COLOR = red
O_COLOR = blue
RESERVEDWORDS_COLOR = darkviolet
VARIABLE_COLOR = olive
COMMENT_COLOR = seagreen
GUI_STYLESHEET = eztrolstyle1.qss
[EZTROLWIZARDS]
WIZARD_DIRECTORY = /usr/share/eztrol/eztrolwizards
SAVE_DIRECTORY = ../../nc_files
[EZTROLWEBWIZARD]
URL = www.mattshaver.com/ecmacam/ecmacam.htm
[EMC]
VERSION = 1.1
DEBUG = 0x00000000
#DEBUG = 0x7FFFFFFF
[DISPLAY]
#DISPLAY = eztrol
CYCLE_TIME = .1
DISPLAY = axis
#DISPLAY = mini
#DISPLAY = tkemc
#DISPLAY = xemc
#DISPLAY = keystick
TKPKG = Ngcgui 1.0
NGCGUI_SUBFILE = ""
NGCGUI_OPTIONS =
# opt items:
INTRO_TIME = 5
EDITOR = gedit
# @SCALE = 25600
# @SCALE = 10000
#PYVCP = 8i20.xml
[FILTER]
py = python
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
SHMEM_KEY = 111
COMM_TIMEOUT = 1.0
[TASK]
TASK = milltask
CYCLE_TIME = 0.001
[HAL]
HALUI = halui
[HALUI]
#No Content
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = inch
# @SCALE = 25600
# @SCALE = 10000
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[KINS]
JOINTS = 3
[AXIS_X]
MIN_LIMIT = -21.8
MAX_LIMIT = 0.2
MAX_VELOCITY = 4.2
[JOINT_0]
TYPE = LINEAR
HOME = 0.000
# @SCALE = 25600
#MAX_VELOCITY = 1.9
# @SCALE = 10000
MAX_VELOCITY = 4.2
BACKLASH = 0.0005
# Drive Ratio = 1:1
# Steps/Rev = 25600
#SCALE = 130048
# Steps/Rev = 10000
SCALE = 50800
MIN_LIMIT = -21.8
MAX_LIMIT = 0.2
FERROR = 0.25
MIN_FERROR = 0.1
HOME_OFFSET = 0.25
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
[AXIS_Y]
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
MAX_VELOCITY = 4.2
[JOINT_1]
TYPE = LINEAR
HOME = 0.000
# @SCALE = 25600
#MAX_VELOCITY = 1.9
# @SCALE = 10000
MAX_VELOCITY = 4.2
BACKLASH = 0.0015
# Drive Ratio = 1:1
# Steps/Rev = 25600
#SCALE = -130048
# Steps/Rev = 10000
SCALE = -50800
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
FERROR = 0.25
MIN_FERROR = 0.1
HOME_OFFSET = 0.25
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
[AXIS_Z]
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
MAX_VELOCITY = 4.2
[JOINT_2]
TYPE = LINEAR
HOME = 0.000
# @SCALE = 25600
#MAX_VELOCITY = 1.9
# @SCALE = 10000
MAX_VELOCITY = 4.2
BACKLASH = 0.0000
# Drive Ratio = 1:1
# Steps/Rev = 25600
#SCALE = -130048
# Steps/Rev = 10000
SCALE = -50800
MIN_LIMIT = -11.8
MAX_LIMIT = 0.2
FERROR = 0.25
MIN_FERROR = 0.1
HOME_OFFSET = 0.25
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[EZTROL]
FULLSCREEN = false
GM_COLOR = blue
O_COLOR = blue
[EZTROLWIZARDS]
[EZTROLWEBWIZARD]
- LPMattei
27 Oct 2022 21:14 #255246
by LPMattei
I posted them again below in plain text rather than an uploaded file as above
27 Oct 2022 23:57 #255261
Replied by andypugh on topic loading LinuxCNC on old smithy 1240
Can you run the following in a terminal window to get a pin list? The point is to see if the 8i20 is being detected:
Paste the output here.
halrun
loadrt hm2_pci config="firmware=hm2/5i20/sssvst2_2_4_v31.bit"
show pinPaste the output here.
Time to create page: 0.268 seconds
