loading LinuxCNC on old smithy 1240
31 Oct 2022 19:50 - 31 Oct 2022 19:52 #255600
Replied by andypugh on topic loading LinuxCNC on old smithy 1240
9 float OUT 0 hm2_5i20.0.8i20.0.0.bus-voltage ==> voltage
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.bus-underv
Looks like the power to the 8i20 is off?
Last edit: 31 Oct 2022 19:52 by andypugh.
- LPMattei
31 Oct 2022 20:02 #255603
by LPMattei
Replied by LPMattei on topic loading LinuxCNC on old smithy 1240
shouldn't be, unless there is a change in how it is turned on with new SW. if I install old drive with old SW, it will work. could it be a line we commented out in the hal?
31 Oct 2022 20:14 #255607
Was the machine actually on when you got the list?
I think that your PyVCP panel should be showing bus voltage too?
- LPMattei
31 Oct 2022 20:34 #255608
by LPMattei
I need to apologize, when I said it worked when I put the old drive / SW in, I made an assumption (I know). I forgot that I had added a power drawbar, I've been looking right at it, and forgot that after I installed it, I never actually ran the spindle. I need to mess with the interlock switch that is apparently wired incorrectly. I'm guessing the spindle will work once I fix that. I will get back in a bit
- LPMattei
31 Oct 2022 20:46 #255610
by LPMattei
update, there is an issue with the interlock sw, With old SW I was able to disengage interlock sw and spindle would run. With new version, it doesn't run in either position. So I'm thinking it is somewhere in hal still
- LPMattei
31 Oct 2022 21:09 #255611
by LPMattei
OK, so I jumped out the interlock, and spindle runs with old SW, but still not with new SW.
- LPMattei
31 Oct 2022 21:23 #255612
by LPMattei
I ran halcmd again, with switch jumped out and gui up and system homed smithy@debian:~$ halcmd show pin *8i20*
Component Pins:
Owner Type Dir Value Name
9 float IN 0.3333333 hm2_5i20.0.8i20.0.0.angle <== rotor_angle
9 float OUT 328.32 hm2_5i20.0.8i20.0.0.bus-voltage ==> voltage
9 float OUT 40 hm2_5i20.0.8i20.0.0.card-temp ==> temp
9 float IN -0 hm2_5i20.0.8i20.0.0.current <== current
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.U-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.U-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.V-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.V-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.W-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.W-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-high
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-high-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-overv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-overv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-underv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-underv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.framingr
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.framingr-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.module
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.module-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.no-enable
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.no-enable-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overcurrent
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overcurrent-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overrun
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overrun-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overtemp
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overtemp-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.watchdog
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.watchdog-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-old
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.brake-old-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-on
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.brake-on-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.bus-underv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.bus-underv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.current-lim
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.current-lim-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.ext-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.ext-reset-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.no-enable
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.no-enable-not
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.pid-on
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.pid-on-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.sw-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.sw-reset-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.wd-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.wd-reset-not
smithy@debian:~$
Component Pins:
smithy@debian:~$
- LPMattei
31 Oct 2022 21:28 #255613
by LPMattei
Is there maybe something here that needs changed?
# Spindle Contactor Enable
setp hm2_5i20.0.gpio.041.is_output TRUE
setp hm2_5i20.0.gpio.041.invert_output TRUE
# Door Closed - Energizes spindle contactor
net CLOSED hm2_5i20.0.gpio.029.in_not hm2_5i20.0.gpio.041.out
01 Nov 2022 00:28 #255625
It looks like the 8i20 has volts and is enabled.
Open the halmeter and / or halshow and follow the spindle.0.... pins through.
There is a pid component for closed-loop spindle control, and then the bldc component, so quite a lot of places a signal could be getting lost.
Look at the signals and pins here, especially 8i20.current:
This might need to be 30, now:That could be limiting the motor to 1A.
net current bldc.0.out hm2_5i20.0.8i20.0.0.current abs.0.inThis might need to be 30, now:
setp pid.0.maxoutput 1.0Please Log in or Create an account to join the conversation.
- LPMattei
01 Nov 2022 00:42 #255627
by LPMattei
setp pid.0.maxoutput 30 did it. Spindle now runs.
Anything else to test before calling it good?
Time to create page: 0.270 seconds
