loading LinuxCNC on old smithy 1240
- LPMattei
Debug file information:
insmod: ERROR: could not insert module /usr/realtime-4.19.195-rtai-amd64/modules/rtai_hal.ko: File exists
1103
Stopping realtime threads
Unloading hal components
rmmod: ERROR: Module hal_lib is not currently loaded
rmmod: ERROR: Module rtapi is not currently loaded
rmmod: ERROR: Module rtai_math is not currently loaded
Kernel message information:
[ 30.152898] I-pipe: head domain RTAI registered.
[ 30.152900] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 30.152902] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12500019, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 30.166336] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 30.166360] kstacks pool size = 524288 bytes
[ 30.166361] RTAI[sched]: hard timer type/freq = lapic/12500019(Hz)
[ 30.166361] linear timed lists.
[ 30.166362] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 30.166363] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 30.187101] USERMODE CHECK: OK.
[ 30.187104] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 30.187106] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 30.193516] RTAI[math]: loaded, using musl libm.
[ 30.769685] RTAPI: ERROR: Unexpected realtime delay on task 1
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
[ 436.398961] RTAI[math]: unloaded.
[ 436.456330] SCHED releases registered named ALIEN PEDV$D
[ 436.469839] RTAI[malloc]: unloaded.
[ 436.576300] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 436.598916] I-pipe: head domain RTAI unregistered.
[ 436.598923] RTAI[hal]: unmounted.
This indicates that a previous crash left the realtime modules in an unstable state, it doesn't really tell us anything.insmod: ERROR: could not insert module /usr/realtime-4.19.195-rtai-amd64/modules/rtai_hal.ko: File exists
You will need to reboot the machine and try again, then you will get an error report with the real problem.
- LPMattei
- LPMattei
note: MAXV max: 4.200 units/sec 252.000 units/min
note: LJOG max: 4.200 units/sec 252.000 units/min
note: LJOG default: 0.200 units/sec 12.000 units/min
note: AJOG max: 85.000 units/sec 5100.000 units/min
note: AJOG default: 12.000 units/sec 720.000 units/min
Waiting for component 'inihal' to become ready.......................................A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
.742
.800
..........HAL: ERROR: exit called before init
<commandline>:0: waitpid failed milltask inihal
<commandline>:0: milltask exited without becoming ready
USER PID ACCESS COMMAND
/dev/rtai_shm: smithy ....m halui
Running from terminal outputs this
smithy@debian:~$ linuxcnc
LINUXCNC - 2.8.4
Machine configuration directory is '/home/smithy/linuxcnc/configs/by_machine.smithy-2'
Machine configuration file is '1240combined.ini'
Starting LinuxCNC...
Realtime system did not load
LinuxCNC terminated with an error. You can find more information in the log:
/home/smithy/linuxcnc_debug.txt
and
/home/smithy/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
smithy@debian:~$
- LPMattei
LINUXCNC - 2.8.4
Found file(REL): ./1240combined.hal
waiting for s.joints<0>, s.kinematics_type<0>
USRMOT: ERROR: command timeout
emcMotionInit: emcTrajInit failed
Waiting for component 'inihal' to become ready.waiting for s.joints<0>, s.kinematics_type<0>
............USRMOT: ERROR: command timeout
..................halui: emcCommandSend: no echo from Task after 5.000 seconds
ERROR: Can't remove RTAI modules, kill the following process(es) first
/dev/rtai_shm: smithy 986 ....m halui
and
smithy@debian:~$ halui: emcCommandSend: no echo from Task after 5.000 seconds
libnml/os_intf/_shm.c 412: rcs_shm_nattch: shmctl failed: Invalid argument
smithy@debian:~$ ^C
smithy@debian:~$
Start the latency test from the command-line (latency-test)
then run "dmesg"
Attach the terminal output of both commands here.
- LPMattei
[ 274.259584] hm2/hm2_5i20.0: pin 2:
[ 274.259585] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259586] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 274.259587] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 274.259588] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 274.259588] hm2/hm2_5i20.0: pin 3:
[ 274.259589] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259590] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 274.259591] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 274.259592] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 274.259593] hm2/hm2_5i20.0: pin 4:
[ 274.259594] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259595] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 274.259596] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259597] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 274.259598] hm2/hm2_5i20.0: pin 5:
[ 274.259599] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259599] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 274.259600] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 274.259601] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 274.259602] hm2/hm2_5i20.0: pin 6:
[ 274.259603] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259604] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 274.259605] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259606] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 274.259607] hm2/hm2_5i20.0: pin 7:
[ 274.259607] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259608] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 274.259609] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 274.259610] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 274.259611] hm2/hm2_5i20.0: pin 8:
[ 274.259612] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259613] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 274.259614] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259615] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 274.259615] hm2/hm2_5i20.0: pin 9:
[ 274.259616] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259617] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 274.259618] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 274.259619] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 274.259620] hm2/hm2_5i20.0: pin 10:
[ 274.259621] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259621] hm2/hm2_5i20.0: pin 11:
[ 274.259622] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259623] hm2/hm2_5i20.0: pin 12:
[ 274.259624] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259625] hm2/hm2_5i20.0: pin 13:
[ 274.259626] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259627] hm2/hm2_5i20.0: pin 14:
[ 274.259627] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259629] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 274.259629] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259631] hm2/hm2_5i20.0: Secondary Pin: 0x01 (rx0, Input)
[ 274.259632] hm2/hm2_5i20.0: pin 15:
[ 274.259632] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259633] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 274.259634] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259635] hm2/hm2_5i20.0: Secondary Pin: 0x02 (rx1, Input)
[ 274.259636] hm2/hm2_5i20.0: pin 16:
[ 274.259637] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259638] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 274.259639] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 274.259640] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 274.259641] hm2/hm2_5i20.0: pin 17:
[ 274.259641] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259642] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 274.259643] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 274.259644] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 274.259645] hm2/hm2_5i20.0: pin 18:
[ 274.259646] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259647] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 274.259648] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 274.259649] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 274.259650] hm2/hm2_5i20.0: pin 19:
[ 274.259650] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259651] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 274.259652] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 274.259653] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 274.259654] hm2/hm2_5i20.0: pin 20:
[ 274.259655] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259656] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 274.259657] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259658] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 274.259659] hm2/hm2_5i20.0: pin 21:
[ 274.259660] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259661] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 274.259662] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259663] hm2/hm2_5i20.0: Secondary Pin: 0x81 (tx0, Output)
[ 274.259664] hm2/hm2_5i20.0: pin 22:
[ 274.259664] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259665] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 274.259666] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 274.259667] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 274.259668] hm2/hm2_5i20.0: pin 23:
[ 274.259669] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259670] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 274.259671] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 274.259672] hm2/hm2_5i20.0: Secondary Pin: 0x82 (tx1, Output)
[ 274.259673] hm2/hm2_5i20.0: pin 24:
[ 274.259674] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259675] hm2/hm2_5i20.0: pin 25:
[ 274.259676] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259676] hm2/hm2_5i20.0: pin 26:
[ 274.259677] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259678] hm2/hm2_5i20.0: pin 27:
[ 274.259679] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259680] hm2/hm2_5i20.0: pin 28:
[ 274.259681] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259681] hm2/hm2_5i20.0: pin 29:
[ 274.259682] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259683] hm2/hm2_5i20.0: pin 30:
[ 274.259684] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259685] hm2/hm2_5i20.0: pin 31:
[ 274.259686] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259686] hm2/hm2_5i20.0: pin 32:
[ 274.259687] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259688] hm2/hm2_5i20.0: pin 33:
[ 274.259689] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259690] hm2/hm2_5i20.0: pin 34:
[ 274.259691] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259691] hm2/hm2_5i20.0: pin 35:
[ 274.259692] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259693] hm2/hm2_5i20.0: pin 36:
[ 274.259694] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259695] hm2/hm2_5i20.0: pin 37:
[ 274.259696] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259696] hm2/hm2_5i20.0: pin 38:
[ 274.259697] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259698] hm2/hm2_5i20.0: pin 39:
[ 274.259699] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259700] hm2/hm2_5i20.0: pin 40:
[ 274.259701] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259702] hm2/hm2_5i20.0: pin 41:
[ 274.259702] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259703] hm2/hm2_5i20.0: pin 42:
[ 274.259704] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259705] hm2/hm2_5i20.0: pin 43:
[ 274.259706] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259707] hm2/hm2_5i20.0: pin 44:
[ 274.259708] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259708] hm2/hm2_5i20.0: pin 45:
[ 274.259709] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259710] hm2/hm2_5i20.0: pin 46:
[ 274.259711] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259712] hm2/hm2_5i20.0: pin 47:
[ 274.259713] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259713] hm2/hm2_5i20.0: pin 48:
[ 274.259714] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259715] hm2/hm2_5i20.0: pin 49:
[ 274.259716] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259717] hm2/hm2_5i20.0: pin 50:
[ 274.259718] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259718] hm2/hm2_5i20.0: pin 51:
[ 274.259719] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259720] hm2/hm2_5i20.0: pin 52:
[ 274.259721] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259722] hm2/hm2_5i20.0: pin 53:
[ 274.259723] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259723] hm2/hm2_5i20.0: pin 54:
[ 274.259724] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259725] hm2/hm2_5i20.0: pin 55:
[ 274.259726] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259727] hm2/hm2_5i20.0: pin 56:
[ 274.259728] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259729] hm2/hm2_5i20.0: pin 57:
[ 274.259729] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259730] hm2/hm2_5i20.0: pin 58:
[ 274.259731] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259732] hm2/hm2_5i20.0: pin 59:
[ 274.259733] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259734] hm2/hm2_5i20.0: pin 60:
[ 274.259734] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259735] hm2/hm2_5i20.0: pin 61:
[ 274.259736] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259737] hm2/hm2_5i20.0: pin 62:
[ 274.259738] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259739] hm2/hm2_5i20.0: pin 63:
[ 274.259739] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259740] hm2/hm2_5i20.0: pin 64:
[ 274.259741] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259742] hm2/hm2_5i20.0: pin 65:
[ 274.259743] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259744] hm2/hm2_5i20.0: pin 66:
[ 274.259744] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259745] hm2/hm2_5i20.0: pin 67:
[ 274.259746] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259747] hm2/hm2_5i20.0: pin 68:
[ 274.259748] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259749] hm2/hm2_5i20.0: pin 69:
[ 274.259749] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259750] hm2/hm2_5i20.0: pin 70:
[ 274.259751] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259752] hm2/hm2_5i20.0: pin 71:
[ 274.259753] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 274.259757] hm2/hm2_5i20.0: Module Descriptor 0 at 0x0440:
[ 274.259758] hm2/hm2_5i20.0: General Function Tag: 2 (Watchdog)
[ 274.259759] hm2/hm2_5i20.0: Version: 0
[ 274.259761] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 274.259761] hm2/hm2_5i20.0: Instances: 1
[ 274.259762] hm2/hm2_5i20.0: Base Address: 0x0C00
[ 274.259763] hm2/hm2_5i20.0: -- Num Registers: 3
[ 274.259764] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 274.259765] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 274.259766] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 274.259770] hm2/hm2_5i20.0: Module Descriptor 1 at 0x044C:
[ 274.259771] hm2/hm2_5i20.0: General Function Tag: 3 (IOPort)
[ 274.259772] hm2/hm2_5i20.0: Version: 0
[ 274.259773] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 274.259774] hm2/hm2_5i20.0: Instances: 3
[ 274.259775] hm2/hm2_5i20.0: Base Address: 0x1000
[ 274.259775] hm2/hm2_5i20.0: -- Num Registers: 5
[ 274.259777] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 274.259777] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 274.259778] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000001F
[ 274.259782] hm2/hm2_5i20.0: Module Descriptor 2 at 0x0458:
[ 274.259783] hm2/hm2_5i20.0: General Function Tag: 4 (Encoder)
[ 274.259784] hm2/hm2_5i20.0: Version: 2
[ 274.259785] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 274.259786] hm2/hm2_5i20.0: Instances: 2
[ 274.259787] hm2/hm2_5i20.0: Base Address: 0x3000
[ 274.259788] hm2/hm2_5i20.0: -- Num Registers: 5
[ 274.259789] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 274.259789] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 274.259790] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 274.259794] hm2/hm2_5i20.0: Module Descriptor 3 at 0x0464:
[ 274.259795] hm2/hm2_5i20.0: General Function Tag: 6 (PWMGen)
[ 274.259796] hm2/hm2_5i20.0: Version: 0
[ 274.259797] hm2/hm2_5i20.0: Clock Tag: 2 (100.000 MHz)
[ 274.259798] hm2/hm2_5i20.0: Instances: 2
[ 274.259799] hm2/hm2_5i20.0: Base Address: 0x4000
[ 274.259800] hm2/hm2_5i20.0: -- Num Registers: 5
[ 274.259801] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 274.259802] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 274.259803] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 274.259807] hm2/hm2_5i20.0: Module Descriptor 4 at 0x0470:
[ 274.259808] hm2/hm2_5i20.0: General Function Tag: 5 (StepGen)
[ 274.259809] hm2/hm2_5i20.0: Version: 2
[ 274.259810] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 274.259810] hm2/hm2_5i20.0: Instances: 4
[ 274.259811] hm2/hm2_5i20.0: Base Address: 0x2000
[ 274.259812] hm2/hm2_5i20.0: -- Num Registers: 10
[ 274.259813] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 274.259814] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 274.259815] hm2/hm2_5i20.0: -- Multiple Registers: 0x000001FF
[ 274.259819] hm2/hm2_5i20.0: Module Descriptor 5 at 0x047C:
[ 274.259820] hm2/hm2_5i20.0: General Function Tag: 193 (Smart Serial Interface)
[ 274.259821] hm2/hm2_5i20.0: Version: 0
[ 274.259822] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 274.259823] hm2/hm2_5i20.0: Instances: 1
[ 274.259824] hm2/hm2_5i20.0: Base Address: 0x5A00
[ 274.259824] hm2/hm2_5i20.0: -- Num Registers: 6
[ 274.259825] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 274.259826] hm2/hm2_5i20.0: -- Instance Stride: 0x00000040
[ 274.259827] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000003C
[ 274.259831] hm2/hm2_5i20.0: Module Descriptor 6 at 0x0488:
[ 274.259832] hm2/hm2_5i20.0: General Function Tag: 128 (LED)
[ 274.259833] hm2/hm2_5i20.0: Version: 0
[ 274.259834] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 274.259835] hm2/hm2_5i20.0: Instances: 1
[ 274.259836] hm2/hm2_5i20.0: Base Address: 0x0200
[ 274.259837] hm2/hm2_5i20.0: -- Num Registers: 1
[ 274.259838] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 274.259838] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 274.259839] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 274.261126] hm2/hm2_5i20.0: Smart Serial Firmware Version 31
[ 274.269475] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 274.269477] hm2/hm2_5i20.0: IO Pin 000 (P2-01): StepGen #0, pin Step (Output)
[ 274.269479] hm2/hm2_5i20.0: IO Pin 001 (P2-03): StepGen #0, pin Direction (Output)
[ 274.269480] hm2/hm2_5i20.0: IO Pin 002 (P2-05): StepGen #1, pin Step (Output)
[ 274.269481] hm2/hm2_5i20.0: IO Pin 003 (P2-07): StepGen #1, pin Direction (Output)
[ 274.269483] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Encoder #0, pin A (Input)
[ 274.269484] hm2/hm2_5i20.0: IO Pin 005 (P2-11): IOPort
[ 274.269485] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Encoder #0, pin B (Input)
[ 274.269486] hm2/hm2_5i20.0: IO Pin 007 (P2-15): IOPort
[ 274.269488] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Encoder #0, pin Index (Input)
[ 274.269489] hm2/hm2_5i20.0: IO Pin 009 (P2-19): IOPort
[ 274.269490] hm2/hm2_5i20.0: IO Pin 010 (P2-21): IOPort
[ 274.269491] hm2/hm2_5i20.0: IO Pin 011 (P2-23): IOPort
[ 274.269492] hm2/hm2_5i20.0: IO Pin 012 (P2-25): IOPort
[ 274.269493] hm2/hm2_5i20.0: IO Pin 013 (P2-27): IOPort
[ 274.269494] hm2/hm2_5i20.0: IO Pin 014 (P2-29): Smart Serial Interface #0, pin rx0 (Input)
[ 274.269495] hm2/hm2_5i20.0: IO Pin 015 (P2-31): IOPort
[ 274.269497] hm2/hm2_5i20.0: IO Pin 016 (P2-33): StepGen #2, pin Step (Output)
[ 274.269498] hm2/hm2_5i20.0: IO Pin 017 (P2-35): StepGen #2, pin Direction (Output)
[ 274.269499] hm2/hm2_5i20.0: IO Pin 018 (P2-37): StepGen #3, pin Step (Output)
[ 274.269501] hm2/hm2_5i20.0: IO Pin 019 (P2-39): StepGen #3, pin Direction (Output)
[ 274.269502] hm2/hm2_5i20.0: IO Pin 020 (P2-41): IOPort
[ 274.269503] hm2/hm2_5i20.0: IO Pin 021 (P2-43): Smart Serial Interface #0, pin tx0 (Output)
[ 274.269504] hm2/hm2_5i20.0: IO Pin 022 (P2-45): IOPort
[ 274.269505] hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
[ 274.269507] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 274.269508] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 274.269509] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 274.269510] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 274.269511] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 274.269512] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 274.269513] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 274.269514] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 274.269515] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 274.269516] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 274.269517] hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
[ 274.269518] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 274.269519] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 274.269520] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 274.269522] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 274.269523] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 274.269524] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 274.269525] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 274.269526] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 274.269527] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 274.269528] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 274.269529] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 274.269530] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 274.269531] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 274.269532] hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
[ 274.269533] hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
[ 274.269534] hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
[ 274.269535] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 274.269537] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 274.269538] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 274.269539] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 274.269540] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 274.269541] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 274.269542] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 274.269543] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 274.269544] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 274.269545] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 274.269546] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 274.269547] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 274.269548] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 274.269549] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 274.269550] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 274.269552] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 274.269553] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 274.269554] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 274.269555] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 274.269556] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 274.269557] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 274.269558] hm2/hm2_5i20.0: HM2 Modules used:
[ 274.269559] hm2/hm2_5i20.0: Encoders: 1
[ 274.269560] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 274.269561] hm2/hm2_5i20.0: version: 2
[ 274.269562] hm2/hm2_5i20.0: counter_addr: 0x3000
[ 274.269563] hm2/hm2_5i20.0: latch_control_addr: 0x3100
[ 274.269564] hm2/hm2_5i20.0: timestamp_div_addr: 0x3200
[ 274.269565] hm2/hm2_5i20.0: timestamp_count_addr: 0x3300
[ 274.269566] hm2/hm2_5i20.0: filter_rate_addr: 0x3400
[ 274.269567] hm2/hm2_5i20.0: timestamp_div: 0x0000
[ 274.269567] hm2/hm2_5i20.0: instance 0:
[ 274.269568] hm2/hm2_5i20.0: hw:
[ 274.269569] hm2/hm2_5i20.0: counter = 0003.ffff
[ 274.269570] hm2/hm2_5i20.0: latch/control = 0000.0800
[ 274.269571] hm2/hm2_5i20.0: prev_control = 0000.0800
[ 274.269573] hm2/hm2_5i20.0: SSerial: 1
[ 274.269574] hm2/hm2_5i20.0: version 31
[ 274.269575] hm2/hm2_5i20.0: instance 0:
[ 274.269576] hm2/hm2_5i20.0: Command Addr 0x5a00
[ 274.269577] hm2/hm2_5i20.0: Data Addr 0x5b00
[ 274.269578] hm2/hm2_5i20.0: port 0 device hm2_5i20.0.8i20.0.0
[ 274.269579] hm2/hm2_5i20.0: Parameters:
[ 274.269580] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269580] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269581] hm2/hm2_5i20.0: DataType = 0x02
[ 274.269582] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269583] hm2/hm2_5i20.0: ParmMax 1.00
[ 274.269584] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269585] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269586] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269587] hm2/hm2_5i20.0: UnitString = degrees
[ 274.269588] hm2/hm2_5i20.0: NameString = angle
[ 274.269589] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269590] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269591] hm2/hm2_5i20.0: DataType = 0x03
[ 274.269591] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269592] hm2/hm2_5i20.0: ParmMax 30.00
[ 274.269593] hm2/hm2_5i20.0: ParmMin -30.00
[ 274.269594] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269595] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269596] hm2/hm2_5i20.0: UnitString = amps
[ 274.269597] hm2/hm2_5i20.0: NameString = current
[ 274.269598] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269599] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269599] hm2/hm2_5i20.0: DataType = 0x02
[ 274.269600] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269601] hm2/hm2_5i20.0: ParmMax 65535.00
[ 274.269602] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269603] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269604] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269605] hm2/hm2_5i20.0: UnitString = Deg C
[ 274.269606] hm2/hm2_5i20.0: NameString = card-temp
[ 274.269607] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269608] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269608] hm2/hm2_5i20.0: DataType = 0x02
[ 274.269609] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269610] hm2/hm2_5i20.0: ParmMax 655.34
[ 274.269611] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269612] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269613] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269614] hm2/hm2_5i20.0: UnitString = volts
[ 274.269615] hm2/hm2_5i20.0: NameString = bus-voltage
[ 274.269616] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269617] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269618] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269619] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269619] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269620] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269621] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269622] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269623] hm2/hm2_5i20.0: UnitString = none
[ 274.269624] hm2/hm2_5i20.0: NameString = status.current-lim
[ 274.269625] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269626] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269627] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269628] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269628] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269629] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269630] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269631] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269632] hm2/hm2_5i20.0: UnitString = none
[ 274.269633] hm2/hm2_5i20.0: NameString = status.brake-on
[ 274.269634] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269635] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269636] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269636] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269637] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269638] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269639] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269640] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269641] hm2/hm2_5i20.0: UnitString = none
[ 274.269642] hm2/hm2_5i20.0: NameString = status.brake-old
[ 274.269643] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269644] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269645] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269645] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269646] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269647] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269648] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269649] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269650] hm2/hm2_5i20.0: UnitString = none
[ 274.269651] hm2/hm2_5i20.0: NameString = status.bus-underv
[ 274.269652] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269653] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269654] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269654] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269655] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269656] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269657] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269658] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269659] hm2/hm2_5i20.0: UnitString = none
[ 274.269660] hm2/hm2_5i20.0: NameString = status.wd-reset
[ 274.269661] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269662] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269662] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269663] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269664] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269665] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269666] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269667] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269668] hm2/hm2_5i20.0: UnitString = none
[ 274.269669] hm2/hm2_5i20.0: NameString = status.sw-reset
[ 274.269670] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269671] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269671] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269672] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269673] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269674] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269675] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269676] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269677] hm2/hm2_5i20.0: UnitString = none
[ 274.269678] hm2/hm2_5i20.0: NameString = status.ext-reset
[ 274.269679] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269680] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269680] hm2/hm2_5i20.0: DataType = 0x00
[ 274.269681] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269682] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269683] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269684] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269685] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269686] hm2/hm2_5i20.0: UnitString = pad
[ 274.269687] hm2/hm2_5i20.0: NameString = pad
[ 274.269688] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269688] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269689] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269690] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269691] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269692] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269693] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269694] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269695] hm2/hm2_5i20.0: UnitString = none
[ 274.269696] hm2/hm2_5i20.0: NameString = status.no-enable
[ 274.269696] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269697] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269698] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269699] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269700] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269701] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269702] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269703] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269704] hm2/hm2_5i20.0: UnitString = none
[ 274.269705] hm2/hm2_5i20.0: NameString = status.pid-on
[ 274.269705] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269706] hm2/hm2_5i20.0: DataLength = 0x06
[ 274.269707] hm2/hm2_5i20.0: DataType = 0x00
[ 274.269708] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269709] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269710] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269711] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269712] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269713] hm2/hm2_5i20.0: UnitString = pad
[ 274.269713] hm2/hm2_5i20.0: NameString = pad
[ 274.269714] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269715] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269716] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269717] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269718] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269719] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269720] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269721] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269722] hm2/hm2_5i20.0: UnitString = none
[ 274.269722] hm2/hm2_5i20.0: NameString = fault.watchdog
[ 274.269723] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269724] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269725] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269726] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269727] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269728] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269729] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269730] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269730] hm2/hm2_5i20.0: UnitString = none
[ 274.269731] hm2/hm2_5i20.0: NameString = fault.no-enable
[ 274.269732] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269733] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269734] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269735] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269736] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269737] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269738] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269739] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269739] hm2/hm2_5i20.0: UnitString = none
[ 274.269740] hm2/hm2_5i20.0: NameString = fault.overtemp
[ 274.269741] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269742] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269743] hm2/hm2_5i20.0: DataType = 0x00
[ 274.269744] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269745] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269746] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269747] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269748] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269748] hm2/hm2_5i20.0: UnitString = pad
[ 274.269749] hm2/hm2_5i20.0: NameString = pad
[ 274.269750] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269751] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269752] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269753] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269754] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269755] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269756] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269756] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269757] hm2/hm2_5i20.0: UnitString = none
[ 274.269758] hm2/hm2_5i20.0: NameString = fault.overcurrent
[ 274.269759] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269760] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269761] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269762] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269763] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269764] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269764] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269765] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269766] hm2/hm2_5i20.0: UnitString = none
[ 274.269767] hm2/hm2_5i20.0: NameString = fault.U-current
[ 274.269768] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269769] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269770] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269771] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269771] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269772] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269773] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269774] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269775] hm2/hm2_5i20.0: UnitString = none
[ 274.269776] hm2/hm2_5i20.0: NameString = fault.V-current
[ 274.269777] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269778] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269779] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269780] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269781] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269781] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269782] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269783] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269784] hm2/hm2_5i20.0: UnitString = none
[ 274.269785] hm2/hm2_5i20.0: NameString = fault.W-current
[ 274.269786] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269787] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269788] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269789] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269789] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269790] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269791] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269792] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269793] hm2/hm2_5i20.0: UnitString = none
[ 274.269794] hm2/hm2_5i20.0: NameString = fault.bus-underv
[ 274.269795] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269796] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269797] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269797] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269798] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269799] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269800] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269801] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269802] hm2/hm2_5i20.0: UnitString = none
[ 274.269803] hm2/hm2_5i20.0: NameString = fault.bus-high
[ 274.269804] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269805] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269806] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269807] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269807] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269808] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269809] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269810] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269811] hm2/hm2_5i20.0: UnitString = none
[ 274.269812] hm2/hm2_5i20.0: NameString = fault.bus-overv
[ 274.269813] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269814] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269815] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269815] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269816] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269817] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269818] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269819] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269820] hm2/hm2_5i20.0: UnitString = none
[ 274.269821] hm2/hm2_5i20.0: NameString = fault.module
[ 274.269822] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269823] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269824] hm2/hm2_5i20.0: DataType = 0x00
[ 274.269825] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269825] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269826] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269827] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269828] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269829] hm2/hm2_5i20.0: UnitString = pad
[ 274.269830] hm2/hm2_5i20.0: NameString = pad
[ 274.269831] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269832] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269833] hm2/hm2_5i20.0: DataType = 0x00
[ 274.269834] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269835] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269835] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269836] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269837] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269838] hm2/hm2_5i20.0: UnitString = pad
[ 274.269839] hm2/hm2_5i20.0: NameString = pad
[ 274.269840] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269841] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269842] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269843] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269843] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269844] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269845] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269846] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269847] hm2/hm2_5i20.0: UnitString = none
[ 274.269848] hm2/hm2_5i20.0: NameString = fault.overrun
[ 274.269849] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269850] hm2/hm2_5i20.0: DataLength = 0x01
[ 274.269851] hm2/hm2_5i20.0: DataType = 0x07
[ 274.269852] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269852] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269853] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269854] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 274.269855] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 274.269856] hm2/hm2_5i20.0: UnitString = none
[ 274.269857] hm2/hm2_5i20.0: NameString = fault.framingr
[ 274.269858] hm2/hm2_5i20.0: Globals:
[ 274.269859] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269860] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269861] hm2/hm2_5i20.0: DataType = 0x02
[ 274.269862] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269862] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269863] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269864] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269865] hm2/hm2_5i20.0: ParmAddr = 0x0874
[ 274.269866] hm2/hm2_5i20.0: UnitString = none
[ 274.269867] hm2/hm2_5i20.0: NameString = swrevision
[ 274.269868] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269869] hm2/hm2_5i20.0: DataLength = 0x20
[ 274.269870] hm2/hm2_5i20.0: DataType = 0x02
[ 274.269871] hm2/hm2_5i20.0: DataDir = 0x00
[ 274.269871] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269872] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269873] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269874] hm2/hm2_5i20.0: ParmAddr = 0x0928
[ 274.269875] hm2/hm2_5i20.0: UnitString = none
[ 274.269876] hm2/hm2_5i20.0: NameString = unitnumber
[ 274.269877] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269878] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269879] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269879] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269880] hm2/hm2_5i20.0: ParmMax 32.76
[ 274.269881] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269882] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269883] hm2/hm2_5i20.0: ParmAddr = 0x0002
[ 274.269884] hm2/hm2_5i20.0: UnitString = amps
[ 274.269885] hm2/hm2_5i20.0: NameString = nvmaxcurrent
[ 274.269886] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269887] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269888] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269889] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269889] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269890] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269891] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269892] hm2/hm2_5i20.0: ParmAddr = 0x0024
[ 274.269893] hm2/hm2_5i20.0: UnitString = volts
[ 274.269894] hm2/hm2_5i20.0: NameString = nvbusundervmax
[ 274.269895] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269896] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269897] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269898] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269898] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269899] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269900] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269901] hm2/hm2_5i20.0: ParmAddr = 0x0022
[ 274.269902] hm2/hm2_5i20.0: UnitString = volts
[ 274.269903] hm2/hm2_5i20.0: NameString = nvbusundervmin
[ 274.269904] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269905] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269906] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269907] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269907] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269908] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269909] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269910] hm2/hm2_5i20.0: ParmAddr = 0x0026
[ 274.269911] hm2/hm2_5i20.0: UnitString = volts
[ 274.269912] hm2/hm2_5i20.0: NameString = nvbusoverv
[ 274.269913] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269914] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269915] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269915] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269916] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269917] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269918] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269919] hm2/hm2_5i20.0: ParmAddr = 0x0028
[ 274.269920] hm2/hm2_5i20.0: UnitString = volts
[ 274.269921] hm2/hm2_5i20.0: NameString = nvbrakeonv
[ 274.269922] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269923] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269924] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269924] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269925] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269926] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269927] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269928] hm2/hm2_5i20.0: ParmAddr = 0x002a
[ 274.269929] hm2/hm2_5i20.0: UnitString = volts
[ 274.269930] hm2/hm2_5i20.0: NameString = nvbrakeoffv
[ 274.269931] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269932] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269932] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269933] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269934] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269935] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269936] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269937] hm2/hm2_5i20.0: ParmAddr = 0x0006
[ 274.269938] hm2/hm2_5i20.0: UnitString = bps
[ 274.269939] hm2/hm2_5i20.0: NameString = nvrembaudrate
[ 274.269940] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269941] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269942] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269942] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269943] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269944] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269945] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269946] hm2/hm2_5i20.0: ParmAddr = 0x000a
[ 274.269947] hm2/hm2_5i20.0: UnitString = none
[ 274.269948] hm2/hm2_5i20.0: NameString = nvkqp
[ 274.269949] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269950] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269951] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269951] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269952] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269953] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269954] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269955] hm2/hm2_5i20.0: ParmAddr = 0x000e
[ 274.269956] hm2/hm2_5i20.0: UnitString = none
[ 274.269957] hm2/hm2_5i20.0: NameString = nvkqihi
[ 274.269958] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269959] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269959] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269960] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269961] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269962] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269963] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269964] hm2/hm2_5i20.0: ParmAddr = 0x000c
[ 274.269965] hm2/hm2_5i20.0: UnitString = none
[ 274.269966] hm2/hm2_5i20.0: NameString = nvkqilo
[ 274.269966] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269967] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269968] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269969] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269970] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269971] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269972] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269973] hm2/hm2_5i20.0: ParmAddr = 0x0010
[ 274.269973] hm2/hm2_5i20.0: UnitString = none
[ 274.269974] hm2/hm2_5i20.0: NameString = nvkqil
[ 274.269975] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269976] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269977] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269978] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269979] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269980] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269981] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269982] hm2/hm2_5i20.0: ParmAddr = 0x0012
[ 274.269982] hm2/hm2_5i20.0: UnitString = none
[ 274.269983] hm2/hm2_5i20.0: NameString = nvkdp
[ 274.269984] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269985] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269986] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269987] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269988] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269989] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269990] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.269991] hm2/hm2_5i20.0: ParmAddr = 0x0016
[ 274.269992] hm2/hm2_5i20.0: UnitString = none
[ 274.269993] hm2/hm2_5i20.0: NameString = nvkdihi
[ 274.269993] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.269994] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.269995] hm2/hm2_5i20.0: DataType = 0x04
[ 274.269996] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.269997] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.269998] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.269999] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.270000] hm2/hm2_5i20.0: ParmAddr = 0x0014
[ 274.270000] hm2/hm2_5i20.0: UnitString = none
[ 274.270001] hm2/hm2_5i20.0: NameString = nvkdilo
[ 274.270002] hm2/hm2_5i20.0: RecordType = 0xa0
[ 274.270003] hm2/hm2_5i20.0: DataLength = 0x10
[ 274.270004] hm2/hm2_5i20.0: DataType = 0x04
[ 274.270005] hm2/hm2_5i20.0: DataDir = 0x80
[ 274.270006] hm2/hm2_5i20.0: ParmMax 0.00
[ 274.270007] hm2/hm2_5i20.0: ParmMin 0.00
[ 274.270008] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 274.270008] hm2/hm2_5i20.0: ParmAddr = 0x0018
[ 274.270009] hm2/hm2_5i20.0: UnitString = none
[ 274.270010] hm2/hm2_5i20.0: NameString = nvkdil
[ 274.270011] hm2/hm2_5i20.0: Modes:
[ 274.270012] hm2/hm2_5i20.0:
[ 274.270013] hm2/hm2_5i20.0: StepGen: 4
[ 274.270014] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 274.270015] hm2/hm2_5i20.0: version: 2
[ 274.270016] hm2/hm2_5i20.0: step_rate_addr: 0x2000
[ 274.270017] hm2/hm2_5i20.0: accumulator_addr: 0x2100
[ 274.270018] hm2/hm2_5i20.0: mode_addr: 0x2200
[ 274.270019] hm2/hm2_5i20.0: dir_setup_time_addr: 0x2300
[ 274.270020] hm2/hm2_5i20.0: dir_hold_time_addr: 0x2400
[ 274.270020] hm2/hm2_5i20.0: pulse_width_addr: 0x2500
[ 274.270021] hm2/hm2_5i20.0: pulse_idle_width_addr: 0x2600
[ 274.270022] hm2/hm2_5i20.0: table_sequence_data_setup_addr: 0x2700
[ 274.270023] hm2/hm2_5i20.0: table_sequence_length_addr: 0x2800
[ 274.270024] hm2/hm2_5i20.0: master_dds_addr: 0x2900
[ 274.270025] hm2/hm2_5i20.0: instance 0:
[ 274.270026] hm2/hm2_5i20.0: enable = 0
[ 274.270026] hm2/hm2_5i20.0: hw:
[ 274.270027] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 274.270028] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 274.270029] hm2/hm2_5i20.0: mode = 0x00000000
[ 274.270030] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 274.270031] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 274.270032] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 274.270033] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 274.270034] hm2/hm2_5i20.0: instance 1:
[ 274.270035] hm2/hm2_5i20.0: enable = 0
[ 274.270036] hm2/hm2_5i20.0: hw:
[ 274.270036] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 274.270037] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 274.270038] hm2/hm2_5i20.0: mode = 0x00000000
[ 274.270039] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 274.270040] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 274.270041] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 274.270042] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 274.270043] hm2/hm2_5i20.0: instance 2:
[ 274.270044] hm2/hm2_5i20.0: enable = 0
[ 274.270045] hm2/hm2_5i20.0: hw:
[ 274.270045] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 274.270046] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 274.270047] hm2/hm2_5i20.0: mode = 0x00000000
[ 274.270048] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 274.270049] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 274.270050] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 274.270051] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 274.270052] hm2/hm2_5i20.0: instance 3:
[ 274.270053] hm2/hm2_5i20.0: enable = 0
[ 274.270054] hm2/hm2_5i20.0: hw:
[ 274.270055] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 274.270056] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 274.270056] hm2/hm2_5i20.0: mode = 0x00000000
[ 274.270057] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 274.270058] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 274.270059] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 274.270060] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 274.270062] hm2/hm2_5i20.0: IO Ports: 3
[ 274.270063] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 274.270064] hm2/hm2_5i20.0: version: 0
[ 274.270065] hm2/hm2_5i20.0: data_addr: 0x1000
[ 274.270066] hm2/hm2_5i20.0: ddr_addr: 0x1100
[ 274.270067] hm2/hm2_5i20.0: alt_source_addr: 0x1200
[ 274.270067] hm2/hm2_5i20.0: open_drain_addr: 0x1300
[ 274.270068] hm2/hm2_5i20.0: output_invert_addr: 0x1400
[ 274.270069] hm2/hm2_5i20.0: instance 0:
[ 274.270070] hm2/hm2_5i20.0: data_read = 0xFF434F
[ 274.270071] hm2/hm2_5i20.0: data_write = 0x000000
[ 274.270072] hm2/hm2_5i20.0: ddr = 0x200000
[ 274.270073] hm2/hm2_5i20.0: alt_source = 0x2F415F
[ 274.270074] hm2/hm2_5i20.0: open_drain = 0x000000
[ 274.270075] hm2/hm2_5i20.0: output_invert = 0x000000
[ 274.270076] hm2/hm2_5i20.0: instance 1:
[ 274.270077] hm2/hm2_5i20.0: data_read = 0xFFDF7F
[ 274.270077] hm2/hm2_5i20.0: data_write = 0x000000
[ 274.270078] hm2/hm2_5i20.0: ddr = 0x000000
[ 274.270079] hm2/hm2_5i20.0: alt_source = 0x000000
[ 274.270080] hm2/hm2_5i20.0: open_drain = 0x000000
[ 274.270081] hm2/hm2_5i20.0: output_invert = 0x000000
[ 274.270082] hm2/hm2_5i20.0: instance 2:
[ 274.270083] hm2/hm2_5i20.0: data_read = 0xFFFFFF
[ 274.270083] hm2/hm2_5i20.0: data_write = 0x000000
[ 274.270084] hm2/hm2_5i20.0: ddr = 0x000000
[ 274.270085] hm2/hm2_5i20.0: alt_source = 0x000000
[ 274.270086] hm2/hm2_5i20.0: open_drain = 0x000000
[ 274.270087] hm2/hm2_5i20.0: output_invert = 0x000000
[ 274.270088] hm2/hm2_5i20.0: Watchdog: 1
[ 274.270090] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 274.270090] hm2/hm2_5i20.0: version: 0
[ 274.270091] hm2/hm2_5i20.0: timer_addr: 0x0C00
[ 274.270092] hm2/hm2_5i20.0: status_addr: 0x0D00
[ 274.270093] hm2/hm2_5i20.0: reset_addr: 0x0E00
[ 274.270094] hm2/hm2_5i20.0: instance 0:
[ 274.270095] hm2/hm2_5i20.0: param timeout_ns = 5000000
[ 274.270096] hm2/hm2_5i20.0: pin has_bit = 0
[ 274.270097] hm2/hm2_5i20.0: reg timer = 0x80000000
[ 274.270157] hm2/hm2_5i20.0: registered
[ 274.270158] hm2_5i20.0: initialized AnyIO board at 0000:04:01.0
[ 274.702715] hm2_5i20.0: dropping AnyIO board at 0000:04:01.0
[ 274.702719] hm2/hm2_5i20.0: unregistered
[ 274.703659] hm2_pci: driver unloaded
[ 274.718706] hm2: unloading
[ 276.834810] RTAI[math]: unloaded.
[ 276.868331] SCHED releases registered named ALIEN PEDV$D
[ 276.882124] RTAI[malloc]: unloaded.
[ 276.988310] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 277.010877] I-pipe: head domain RTAI unregistered.
[ 277.010885] RTAI[hal]: unmounted.
[ 332.571944] I-pipe: head domain RTAI registered.
[ 332.571947] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 332.571950] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12498789, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 332.577551] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 332.577571] kstacks pool size = 524288 bytes
[ 332.577572] RTAI[sched]: hard timer type/freq = lapic/12498789(Hz)
[ 332.577573] linear timed lists.
[ 332.577574] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 332.577575] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 332.595040] USERMODE CHECK: OK.
[ 332.595044] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 332.595046] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 332.601982] RTAI[math]: loaded, using musl libm.
[ 332.645054] hm2: loading Mesa HostMot2 driver version 0.15
[ 332.647991] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 332.648109] hm2_pci: discovered 5i20 at 0000:04:01.0
[ 332.648168] hm2_5i20.0: Direct firmware load for hm2/5i20/sssvst2_2_2_v35.bit failed with error -2
[ 332.648174] hm2/hm2_5i20.0: firmware hm2/5i20/sssvst2_2_2_v35.bit not found
[ 332.648175] hm2/hm2_5i20.0: install the package containing the firmware.
[ 332.648176] hm2_5i20.0: board fails HM2 registration
[ 332.648221] hm2_pci: probe of 0000:04:01.0 failed with error -2
[ 332.892418] hm2: unloading
[ 332.977221] RTAI[math]: unloaded.
[ 333.018649] SCHED releases registered named ALIEN PEDV$D
[ 333.035075] RTAI[malloc]: unloaded.
[ 333.142616] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 333.161311] I-pipe: head domain RTAI unregistered.
[ 333.161319] RTAI[hal]: unmounted.
[ 374.262895] I-pipe: head domain RTAI registered.
[ 374.262898] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 374.262901] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12498789, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 374.267995] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 374.268016] kstacks pool size = 524288 bytes
[ 374.268016] RTAI[sched]: hard timer type/freq = lapic/12498789(Hz)
[ 374.268017] linear timed lists.
[ 374.268019] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 374.268020] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 374.280025] USERMODE CHECK: OK.
[ 374.280028] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 374.280030] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 374.291389] RTAI[math]: loaded, using musl libm.
[ 374.336329] hm2: loading Mesa HostMot2 driver version 0.15
[ 374.339551] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 374.339664] hm2_pci: discovered 5i20 at 0000:04:01.0
[ 374.470741] hm2/hm2_5i20.0: Low Level init 0.15
[ 374.470764] hm2/hm2_5i20.0: IDRom:
[ 374.470766] hm2/hm2_5i20.0: IDRom Type: 0x00000003
[ 374.470767] hm2/hm2_5i20.0: Offset to Modules: 0x00000040
[ 374.470768] hm2/hm2_5i20.0: Offset to Pin Description: 0x000001C0
[ 374.470769] hm2/hm2_5i20.0: Board Name: MESA5I20
[ 374.470770] hm2/hm2_5i20.0: FPGA Size: 200
[ 374.470771] hm2/hm2_5i20.0: FPGA Pins: 208
[ 374.470772] hm2/hm2_5i20.0: Port Width: 24
[ 374.470772] hm2/hm2_5i20.0: IO Ports: 3
[ 374.470773] hm2/hm2_5i20.0: IO Width: 72
[ 374.470774] hm2/hm2_5i20.0: Clock Low: 33333333 Hz (33333 KHz, 33 MHz)
[ 374.470776] hm2/hm2_5i20.0: Clock High: 100000000 Hz (100000 KHz, 100 MHz)
[ 374.470777] hm2/hm2_5i20.0: Instance Stride 0: 0x00000004
[ 374.470777] hm2/hm2_5i20.0: Instance Stride 1: 0x00000040
[ 374.470778] hm2/hm2_5i20.0: Register Stride 0: 0x00000100
[ 374.470779] hm2/hm2_5i20.0: Register Stride 1: 0x00000100
[ 374.470855] hm2/hm2_5i20.0: 72 HM2 Pin Descriptors:
[ 374.470856] hm2/hm2_5i20.0: pin 0:
[ 374.470857] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470858] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470859] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470860] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 374.470861] hm2/hm2_5i20.0: pin 1:
[ 374.470862] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470863] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470864] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470865] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 374.470866] hm2/hm2_5i20.0: pin 2:
[ 374.470867] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470868] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470869] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 374.470869] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 374.470870] hm2/hm2_5i20.0: pin 3:
[ 374.470871] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470872] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470873] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 374.470874] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 374.470875] hm2/hm2_5i20.0: pin 4:
[ 374.470876] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470877] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 374.470877] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470879] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 374.470879] hm2/hm2_5i20.0: pin 5:
[ 374.470880] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470881] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 374.470882] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 374.470883] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 374.470884] hm2/hm2_5i20.0: pin 6:
[ 374.470885] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470886] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 374.470887] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470888] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 374.470888] hm2/hm2_5i20.0: pin 7:
[ 374.470889] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470890] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 374.470891] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 374.470892] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 374.470893] hm2/hm2_5i20.0: pin 8:
[ 374.470894] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470895] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 374.470896] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470896] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 374.470897] hm2/hm2_5i20.0: pin 9:
[ 374.470898] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470899] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 374.470900] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 374.470901] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 374.470902] hm2/hm2_5i20.0: pin 10:
[ 374.470903] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470903] hm2/hm2_5i20.0: pin 11:
[ 374.470904] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470905] hm2/hm2_5i20.0: pin 12:
[ 374.470906] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470907] hm2/hm2_5i20.0: pin 13:
[ 374.470908] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470909] hm2/hm2_5i20.0: pin 14:
[ 374.470909] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470911] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 374.470911] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470913] hm2/hm2_5i20.0: Secondary Pin: 0x01 (rx0, Input)
[ 374.470913] hm2/hm2_5i20.0: pin 15:
[ 374.470914] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470915] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 374.470916] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470917] hm2/hm2_5i20.0: Secondary Pin: 0x02 (rx1, Input)
[ 374.470918] hm2/hm2_5i20.0: pin 16:
[ 374.470919] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470920] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470921] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 374.470922] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 374.470923] hm2/hm2_5i20.0: pin 17:
[ 374.470924] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470924] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470925] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 374.470926] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 374.470927] hm2/hm2_5i20.0: pin 18:
[ 374.470928] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470929] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470930] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 374.470931] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 374.470932] hm2/hm2_5i20.0: pin 19:
[ 374.470933] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470933] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 374.470934] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 374.470935] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 374.470936] hm2/hm2_5i20.0: pin 20:
[ 374.470937] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470938] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 374.470939] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470940] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 374.470941] hm2/hm2_5i20.0: pin 21:
[ 374.470942] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470943] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 374.470944] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470945] hm2/hm2_5i20.0: Secondary Pin: 0x81 (tx0, Output)
[ 374.470946] hm2/hm2_5i20.0: pin 22:
[ 374.470947] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470948] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 374.470949] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 374.470950] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 374.470951] hm2/hm2_5i20.0: pin 23:
[ 374.470951] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470952] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 374.470953] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 374.470954] hm2/hm2_5i20.0: Secondary Pin: 0x82 (tx1, Output)
[ 374.470955] hm2/hm2_5i20.0: pin 24:
[ 374.470956] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470957] hm2/hm2_5i20.0: pin 25:
[ 374.470958] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470959] hm2/hm2_5i20.0: pin 26:
[ 374.470959] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470960] hm2/hm2_5i20.0: pin 27:
[ 374.470961] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470962] hm2/hm2_5i20.0: pin 28:
[ 374.470963] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470964] hm2/hm2_5i20.0: pin 29:
[ 374.470964] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470965] hm2/hm2_5i20.0: pin 30:
[ 374.470966] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470967] hm2/hm2_5i20.0: pin 31:
[ 374.470968] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470969] hm2/hm2_5i20.0: pin 32:
[ 374.470970] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470970] hm2/hm2_5i20.0: pin 33:
[ 374.470971] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470972] hm2/hm2_5i20.0: pin 34:
[ 374.470973] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470974] hm2/hm2_5i20.0: pin 35:
[ 374.470975] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470975] hm2/hm2_5i20.0: pin 36:
[ 374.470976] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470977] hm2/hm2_5i20.0: pin 37:
[ 374.470978] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470979] hm2/hm2_5i20.0: pin 38:
[ 374.470980] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470981] hm2/hm2_5i20.0: pin 39:
[ 374.470981] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470982] hm2/hm2_5i20.0: pin 40:
[ 374.470983] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470984] hm2/hm2_5i20.0: pin 41:
[ 374.470985] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470986] hm2/hm2_5i20.0: pin 42:
[ 374.470986] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470987] hm2/hm2_5i20.0: pin 43:
[ 374.470988] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470989] hm2/hm2_5i20.0: pin 44:
[ 374.470990] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470991] hm2/hm2_5i20.0: pin 45:
[ 374.470992] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470992] hm2/hm2_5i20.0: pin 46:
[ 374.470993] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470994] hm2/hm2_5i20.0: pin 47:
[ 374.470995] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470996] hm2/hm2_5i20.0: pin 48:
[ 374.470997] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470997] hm2/hm2_5i20.0: pin 49:
[ 374.470998] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.470999] hm2/hm2_5i20.0: pin 50:
[ 374.471000] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471001] hm2/hm2_5i20.0: pin 51:
[ 374.471002] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471002] hm2/hm2_5i20.0: pin 52:
[ 374.471003] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471004] hm2/hm2_5i20.0: pin 53:
[ 374.471005] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471006] hm2/hm2_5i20.0: pin 54:
[ 374.471007] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471007] hm2/hm2_5i20.0: pin 55:
[ 374.471008] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471009] hm2/hm2_5i20.0: pin 56:
[ 374.471010] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471011] hm2/hm2_5i20.0: pin 57:
[ 374.471012] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471012] hm2/hm2_5i20.0: pin 58:
[ 374.471013] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471014] hm2/hm2_5i20.0: pin 59:
[ 374.471015] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471016] hm2/hm2_5i20.0: pin 60:
[ 374.471017] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471018] hm2/hm2_5i20.0: pin 61:
[ 374.471018] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471019] hm2/hm2_5i20.0: pin 62:
[ 374.471020] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471021] hm2/hm2_5i20.0: pin 63:
[ 374.471022] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471023] hm2/hm2_5i20.0: pin 64:
[ 374.471023] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471024] hm2/hm2_5i20.0: pin 65:
[ 374.471025] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471026] hm2/hm2_5i20.0: pin 66:
[ 374.471027] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471028] hm2/hm2_5i20.0: pin 67:
[ 374.471028] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471029] hm2/hm2_5i20.0: pin 68:
[ 374.471030] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471031] hm2/hm2_5i20.0: pin 69:
[ 374.471032] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471033] hm2/hm2_5i20.0: pin 70:
[ 374.471033] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471034] hm2/hm2_5i20.0: pin 71:
[ 374.471035] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 374.471039] hm2/hm2_5i20.0: Module Descriptor 0 at 0x0440:
[ 374.471040] hm2/hm2_5i20.0: General Function Tag: 2 (Watchdog)
[ 374.471041] hm2/hm2_5i20.0: Version: 0
[ 374.471043] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 374.471044] hm2/hm2_5i20.0: Instances: 1
[ 374.471045] hm2/hm2_5i20.0: Base Address: 0x0C00
[ 374.471046] hm2/hm2_5i20.0: -- Num Registers: 3
[ 374.471047] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 374.471048] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 374.471049] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 374.471053] hm2/hm2_5i20.0: Module Descriptor 1 at 0x044C:
[ 374.471054] hm2/hm2_5i20.0: General Function Tag: 3 (IOPort)
[ 374.471054] hm2/hm2_5i20.0: Version: 0
[ 374.471056] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 374.471056] hm2/hm2_5i20.0: Instances: 3
[ 374.471057] hm2/hm2_5i20.0: Base Address: 0x1000
[ 374.471058] hm2/hm2_5i20.0: -- Num Registers: 5
[ 374.471059] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 374.471060] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 374.471061] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000001F
[ 374.471065] hm2/hm2_5i20.0: Module Descriptor 2 at 0x0458:
[ 374.471066] hm2/hm2_5i20.0: General Function Tag: 4 (Encoder)
[ 374.471067] hm2/hm2_5i20.0: Version: 2
[ 374.471068] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 374.471069] hm2/hm2_5i20.0: Instances: 2
[ 374.471070] hm2/hm2_5i20.0: Base Address: 0x3000
[ 374.471070] hm2/hm2_5i20.0: -- Num Registers: 5
[ 374.471071] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 374.471072] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 374.471073] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 374.471077] hm2/hm2_5i20.0: Module Descriptor 3 at 0x0464:
[ 374.471078] hm2/hm2_5i20.0: General Function Tag: 6 (PWMGen)
[ 374.471079] hm2/hm2_5i20.0: Version: 0
[ 374.471080] hm2/hm2_5i20.0: Clock Tag: 2 (100.000 MHz)
[ 374.471081] hm2/hm2_5i20.0: Instances: 2
[ 374.471082] hm2/hm2_5i20.0: Base Address: 0x4000
[ 374.471083] hm2/hm2_5i20.0: -- Num Registers: 5
[ 374.471084] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 374.471084] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 374.471085] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 374.471089] hm2/hm2_5i20.0: Module Descriptor 4 at 0x0470:
[ 374.471090] hm2/hm2_5i20.0: General Function Tag: 5 (StepGen)
[ 374.471091] hm2/hm2_5i20.0: Version: 2
[ 374.471092] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 374.471093] hm2/hm2_5i20.0: Instances: 4
[ 374.471094] hm2/hm2_5i20.0: Base Address: 0x2000
[ 374.471095] hm2/hm2_5i20.0: -- Num Registers: 10
[ 374.471096] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 374.471097] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 374.471098] hm2/hm2_5i20.0: -- Multiple Registers: 0x000001FF
[ 374.471102] hm2/hm2_5i20.0: Module Descriptor 5 at 0x047C:
[ 374.471103] hm2/hm2_5i20.0: General Function Tag: 193 (Smart Serial Interface)
[ 374.471104] hm2/hm2_5i20.0: Version: 0
[ 374.471105] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 374.471105] hm2/hm2_5i20.0: Instances: 1
[ 374.471106] hm2/hm2_5i20.0: Base Address: 0x5A00
[ 374.471107] hm2/hm2_5i20.0: -- Num Registers: 6
[ 374.471108] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 374.471109] hm2/hm2_5i20.0: -- Instance Stride: 0x00000040
[ 374.471110] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000003C
[ 374.471114] hm2/hm2_5i20.0: Module Descriptor 6 at 0x0488:
[ 374.471115] hm2/hm2_5i20.0: General Function Tag: 128 (LED)
[ 374.471116] hm2/hm2_5i20.0: Version: 0
[ 374.471117] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 374.471118] hm2/hm2_5i20.0: Instances: 1
[ 374.471119] hm2/hm2_5i20.0: Base Address: 0x0200
[ 374.471119] hm2/hm2_5i20.0: -- Num Registers: 1
[ 374.471121] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 374.471121] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 374.471122] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 374.472368] hm2/hm2_5i20.0: Smart Serial Firmware Version 31
[ 374.480504] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 374.480506] hm2/hm2_5i20.0: IO Pin 000 (P2-01): StepGen #0, pin Step (Output)
[ 374.480508] hm2/hm2_5i20.0: IO Pin 001 (P2-03): StepGen #0, pin Direction (Output)
[ 374.480509] hm2/hm2_5i20.0: IO Pin 002 (P2-05): StepGen #1, pin Step (Output)
[ 374.480510] hm2/hm2_5i20.0: IO Pin 003 (P2-07): StepGen #1, pin Direction (Output)
[ 374.480512] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Encoder #0, pin A (Input)
[ 374.480513] hm2/hm2_5i20.0: IO Pin 005 (P2-11): IOPort
[ 374.480514] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Encoder #0, pin B (Input)
[ 374.480516] hm2/hm2_5i20.0: IO Pin 007 (P2-15): IOPort
[ 374.480517] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Encoder #0, pin Index (Input)
[ 374.480518] hm2/hm2_5i20.0: IO Pin 009 (P2-19): IOPort
[ 374.480519] hm2/hm2_5i20.0: IO Pin 010 (P2-21): IOPort
[ 374.480520] hm2/hm2_5i20.0: IO Pin 011 (P2-23): IOPort
[ 374.480521] hm2/hm2_5i20.0: IO Pin 012 (P2-25): IOPort
[ 374.480522] hm2/hm2_5i20.0: IO Pin 013 (P2-27): IOPort
[ 374.480524] hm2/hm2_5i20.0: IO Pin 014 (P2-29): Smart Serial Interface #0, pin rx0 (Input)
[ 374.480525] hm2/hm2_5i20.0: IO Pin 015 (P2-31): IOPort
[ 374.480526] hm2/hm2_5i20.0: IO Pin 016 (P2-33): StepGen #2, pin Step (Output)
[ 374.480528] hm2/hm2_5i20.0: IO Pin 017 (P2-35): StepGen #2, pin Direction (Output)
[ 374.480529] hm2/hm2_5i20.0: IO Pin 018 (P2-37): StepGen #3, pin Step (Output)
[ 374.480530] hm2/hm2_5i20.0: IO Pin 019 (P2-39): StepGen #3, pin Direction (Output)
[ 374.480531] hm2/hm2_5i20.0: IO Pin 020 (P2-41): IOPort
[ 374.480533] hm2/hm2_5i20.0: IO Pin 021 (P2-43): Smart Serial Interface #0, pin tx0 (Output)
[ 374.480534] hm2/hm2_5i20.0: IO Pin 022 (P2-45): IOPort
[ 374.480535] hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
[ 374.480536] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 374.480537] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 374.480538] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 374.480539] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 374.480540] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 374.480541] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 374.480542] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 374.480543] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 374.480545] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 374.480546] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 374.480547] hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
[ 374.480548] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 374.480549] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 374.480550] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 374.480551] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 374.480552] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 374.480553] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 374.480554] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 374.480555] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 374.480556] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 374.480557] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 374.480558] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 374.480560] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 374.480561] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 374.480562] hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
[ 374.480563] hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
[ 374.480564] hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
[ 374.480565] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 374.480566] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 374.480567] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 374.480568] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 374.480569] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 374.480570] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 374.480572] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 374.480573] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 374.480574] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 374.480575] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 374.480576] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 374.480577] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 374.480578] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 374.480579] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 374.480580] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 374.480581] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 374.480582] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 374.480583] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 374.480584] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 374.480585] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 374.480587] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 374.480587] hm2/hm2_5i20.0: HM2 Modules used:
[ 374.480588] hm2/hm2_5i20.0: Encoders: 1
[ 374.480590] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 374.480591] hm2/hm2_5i20.0: version: 2
[ 374.480592] hm2/hm2_5i20.0: counter_addr: 0x3000
[ 374.480593] hm2/hm2_5i20.0: latch_control_addr: 0x3100
[ 374.480593] hm2/hm2_5i20.0: timestamp_div_addr: 0x3200
[ 374.480594] hm2/hm2_5i20.0: timestamp_count_addr: 0x3300
[ 374.480595] hm2/hm2_5i20.0: filter_rate_addr: 0x3400
[ 374.480596] hm2/hm2_5i20.0: timestamp_div: 0x0000
[ 374.480597] hm2/hm2_5i20.0: instance 0:
[ 374.480598] hm2/hm2_5i20.0: hw:
[ 374.480599] hm2/hm2_5i20.0: counter = 0003.ffff
[ 374.480600] hm2/hm2_5i20.0: latch/control = 0000.0800
[ 374.480601] hm2/hm2_5i20.0: prev_control = 0000.0800
[ 374.480603] hm2/hm2_5i20.0: SSerial: 1
[ 374.480603] hm2/hm2_5i20.0: version 31
[ 374.480604] hm2/hm2_5i20.0: instance 0:
[ 374.480605] hm2/hm2_5i20.0: Command Addr 0x5a00
[ 374.480606] hm2/hm2_5i20.0: Data Addr 0x5b00
[ 374.480607] hm2/hm2_5i20.0: port 0 device hm2_5i20.0.8i20.0.0
[ 374.480608] hm2/hm2_5i20.0: Parameters:
[ 374.480609] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480610] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480611] hm2/hm2_5i20.0: DataType = 0x02
[ 374.480612] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480613] hm2/hm2_5i20.0: ParmMax 1.00
[ 374.480613] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480614] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480615] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480616] hm2/hm2_5i20.0: UnitString = degrees
[ 374.480617] hm2/hm2_5i20.0: NameString = angle
[ 374.480618] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480619] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480620] hm2/hm2_5i20.0: DataType = 0x03
[ 374.480621] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480622] hm2/hm2_5i20.0: ParmMax 30.00
[ 374.480623] hm2/hm2_5i20.0: ParmMin -30.00
[ 374.480624] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480624] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480625] hm2/hm2_5i20.0: UnitString = amps
[ 374.480626] hm2/hm2_5i20.0: NameString = current
[ 374.480627] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480628] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480629] hm2/hm2_5i20.0: DataType = 0x02
[ 374.480630] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480631] hm2/hm2_5i20.0: ParmMax 65535.00
[ 374.480632] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480633] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480633] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480634] hm2/hm2_5i20.0: UnitString = Deg C
[ 374.480635] hm2/hm2_5i20.0: NameString = card-temp
[ 374.480636] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480637] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480638] hm2/hm2_5i20.0: DataType = 0x02
[ 374.480639] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480640] hm2/hm2_5i20.0: ParmMax 655.34
[ 374.480641] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480642] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480642] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480643] hm2/hm2_5i20.0: UnitString = volts
[ 374.480644] hm2/hm2_5i20.0: NameString = bus-voltage
[ 374.480645] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480646] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480647] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480648] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480649] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480650] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480651] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480651] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480652] hm2/hm2_5i20.0: UnitString = none
[ 374.480653] hm2/hm2_5i20.0: NameString = status.current-lim
[ 374.480654] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480655] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480656] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480657] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480658] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480659] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480660] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480660] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480661] hm2/hm2_5i20.0: UnitString = none
[ 374.480662] hm2/hm2_5i20.0: NameString = status.brake-on
[ 374.480663] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480664] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480665] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480666] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480667] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480668] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480668] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480669] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480670] hm2/hm2_5i20.0: UnitString = none
[ 374.480671] hm2/hm2_5i20.0: NameString = status.brake-old
[ 374.480672] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480673] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480674] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480675] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480676] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480676] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480677] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480678] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480679] hm2/hm2_5i20.0: UnitString = none
[ 374.480680] hm2/hm2_5i20.0: NameString = status.bus-underv
[ 374.480681] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480682] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480683] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480684] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480685] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480685] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480686] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480687] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480688] hm2/hm2_5i20.0: UnitString = none
[ 374.480689] hm2/hm2_5i20.0: NameString = status.wd-reset
[ 374.480690] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480691] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480692] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480693] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480693] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480694] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480695] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480696] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480697] hm2/hm2_5i20.0: UnitString = none
[ 374.480698] hm2/hm2_5i20.0: NameString = status.sw-reset
[ 374.480699] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480700] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480701] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480702] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480702] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480703] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480704] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480705] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480706] hm2/hm2_5i20.0: UnitString = none
[ 374.480707] hm2/hm2_5i20.0: NameString = status.ext-reset
[ 374.480708] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480709] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480710] hm2/hm2_5i20.0: DataType = 0x00
[ 374.480710] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480711] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480712] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480713] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480714] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480715] hm2/hm2_5i20.0: UnitString = pad
[ 374.480716] hm2/hm2_5i20.0: NameString = pad
[ 374.480717] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480718] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480719] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480719] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480720] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480721] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480722] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480723] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480724] hm2/hm2_5i20.0: UnitString = none
[ 374.480725] hm2/hm2_5i20.0: NameString = status.no-enable
[ 374.480726] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480727] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480728] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480728] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480729] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480730] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480731] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480732] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480733] hm2/hm2_5i20.0: UnitString = none
[ 374.480734] hm2/hm2_5i20.0: NameString = status.pid-on
[ 374.480735] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480736] hm2/hm2_5i20.0: DataLength = 0x06
[ 374.480737] hm2/hm2_5i20.0: DataType = 0x00
[ 374.480738] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480739] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480739] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480740] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480741] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480742] hm2/hm2_5i20.0: UnitString = pad
[ 374.480743] hm2/hm2_5i20.0: NameString = pad
[ 374.480744] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480745] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480746] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480747] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480747] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480748] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480749] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480750] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480751] hm2/hm2_5i20.0: UnitString = none
[ 374.480752] hm2/hm2_5i20.0: NameString = fault.watchdog
[ 374.480753] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480754] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480755] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480756] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480756] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480757] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480758] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480759] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480760] hm2/hm2_5i20.0: UnitString = none
[ 374.480761] hm2/hm2_5i20.0: NameString = fault.no-enable
[ 374.480762] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480763] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480764] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480764] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480765] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480766] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480767] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480768] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480769] hm2/hm2_5i20.0: UnitString = none
[ 374.480770] hm2/hm2_5i20.0: NameString = fault.overtemp
[ 374.480771] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480772] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480773] hm2/hm2_5i20.0: DataType = 0x00
[ 374.480773] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480774] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480775] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480776] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480777] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480778] hm2/hm2_5i20.0: UnitString = pad
[ 374.480779] hm2/hm2_5i20.0: NameString = pad
[ 374.480780] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480781] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480782] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480782] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480783] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480784] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480785] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480786] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480787] hm2/hm2_5i20.0: UnitString = none
[ 374.480788] hm2/hm2_5i20.0: NameString = fault.overcurrent
[ 374.480789] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480790] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480791] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480791] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480792] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480793] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480794] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480795] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480796] hm2/hm2_5i20.0: UnitString = none
[ 374.480797] hm2/hm2_5i20.0: NameString = fault.U-current
[ 374.480798] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480799] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480799] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480800] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480801] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480802] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480803] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480804] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480805] hm2/hm2_5i20.0: UnitString = none
[ 374.480806] hm2/hm2_5i20.0: NameString = fault.V-current
[ 374.480807] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480807] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480808] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480809] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480810] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480811] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480812] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480813] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480814] hm2/hm2_5i20.0: UnitString = none
[ 374.480815] hm2/hm2_5i20.0: NameString = fault.W-current
[ 374.480815] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480816] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480817] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480818] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480819] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480820] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480821] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480822] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480823] hm2/hm2_5i20.0: UnitString = none
[ 374.480823] hm2/hm2_5i20.0: NameString = fault.bus-underv
[ 374.480824] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480825] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480826] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480827] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480828] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480829] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480830] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480830] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480831] hm2/hm2_5i20.0: UnitString = none
[ 374.480832] hm2/hm2_5i20.0: NameString = fault.bus-high
[ 374.480833] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480834] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480835] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480836] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480837] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480838] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480839] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480839] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480840] hm2/hm2_5i20.0: UnitString = none
[ 374.480841] hm2/hm2_5i20.0: NameString = fault.bus-overv
[ 374.480842] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480843] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480844] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480845] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480846] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480847] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480848] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480848] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480849] hm2/hm2_5i20.0: UnitString = none
[ 374.480850] hm2/hm2_5i20.0: NameString = fault.module
[ 374.480851] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480852] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480853] hm2/hm2_5i20.0: DataType = 0x00
[ 374.480854] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480855] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480856] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480856] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480857] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480858] hm2/hm2_5i20.0: UnitString = pad
[ 374.480859] hm2/hm2_5i20.0: NameString = pad
[ 374.480860] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480861] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480862] hm2/hm2_5i20.0: DataType = 0x00
[ 374.480863] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480863] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480864] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480865] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480866] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480867] hm2/hm2_5i20.0: UnitString = pad
[ 374.480868] hm2/hm2_5i20.0: NameString = pad
[ 374.480869] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480870] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480871] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480872] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480872] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480873] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480874] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480875] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480876] hm2/hm2_5i20.0: UnitString = none
[ 374.480877] hm2/hm2_5i20.0: NameString = fault.overrun
[ 374.480878] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480879] hm2/hm2_5i20.0: DataLength = 0x01
[ 374.480880] hm2/hm2_5i20.0: DataType = 0x07
[ 374.480880] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480881] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480882] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480883] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 374.480884] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 374.480885] hm2/hm2_5i20.0: UnitString = none
[ 374.480886] hm2/hm2_5i20.0: NameString = fault.framingr
[ 374.480887] hm2/hm2_5i20.0: Globals:
[ 374.480888] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480889] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480890] hm2/hm2_5i20.0: DataType = 0x02
[ 374.480890] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480891] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480892] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480893] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480894] hm2/hm2_5i20.0: ParmAddr = 0x0874
[ 374.480895] hm2/hm2_5i20.0: UnitString = none
[ 374.480896] hm2/hm2_5i20.0: NameString = swrevision
[ 374.480897] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480898] hm2/hm2_5i20.0: DataLength = 0x20
[ 374.480899] hm2/hm2_5i20.0: DataType = 0x02
[ 374.480899] hm2/hm2_5i20.0: DataDir = 0x00
[ 374.480900] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480901] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480902] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480903] hm2/hm2_5i20.0: ParmAddr = 0x0928
[ 374.480904] hm2/hm2_5i20.0: UnitString = none
[ 374.480905] hm2/hm2_5i20.0: NameString = unitnumber
[ 374.480906] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480907] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480908] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480908] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480909] hm2/hm2_5i20.0: ParmMax 32.76
[ 374.480910] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480911] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480912] hm2/hm2_5i20.0: ParmAddr = 0x0002
[ 374.480913] hm2/hm2_5i20.0: UnitString = amps
[ 374.480914] hm2/hm2_5i20.0: NameString = nvmaxcurrent
[ 374.480915] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480916] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480917] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480917] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480918] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480919] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480920] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480921] hm2/hm2_5i20.0: ParmAddr = 0x0024
[ 374.480922] hm2/hm2_5i20.0: UnitString = volts
[ 374.480923] hm2/hm2_5i20.0: NameString = nvbusundervmax
[ 374.480924] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480925] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480926] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480926] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480927] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480928] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480929] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480930] hm2/hm2_5i20.0: ParmAddr = 0x0022
[ 374.480931] hm2/hm2_5i20.0: UnitString = volts
[ 374.480932] hm2/hm2_5i20.0: NameString = nvbusundervmin
[ 374.480933] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480934] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480934] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480935] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480936] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480937] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480938] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480939] hm2/hm2_5i20.0: ParmAddr = 0x0026
[ 374.480940] hm2/hm2_5i20.0: UnitString = volts
[ 374.480941] hm2/hm2_5i20.0: NameString = nvbusoverv
[ 374.480942] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480943] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480943] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480944] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480945] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480946] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480947] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480948] hm2/hm2_5i20.0: ParmAddr = 0x0028
[ 374.480949] hm2/hm2_5i20.0: UnitString = volts
[ 374.480950] hm2/hm2_5i20.0: NameString = nvbrakeonv
[ 374.480950] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480951] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480952] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480953] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480954] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480955] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480956] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480957] hm2/hm2_5i20.0: ParmAddr = 0x002a
[ 374.480958] hm2/hm2_5i20.0: UnitString = volts
[ 374.480959] hm2/hm2_5i20.0: NameString = nvbrakeoffv
[ 374.480960] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480960] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480961] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480962] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480963] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480964] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480965] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480966] hm2/hm2_5i20.0: ParmAddr = 0x0006
[ 374.480967] hm2/hm2_5i20.0: UnitString = bps
[ 374.480967] hm2/hm2_5i20.0: NameString = nvrembaudrate
[ 374.480968] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480969] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480970] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480971] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480972] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480973] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480974] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480975] hm2/hm2_5i20.0: ParmAddr = 0x000a
[ 374.480975] hm2/hm2_5i20.0: UnitString = none
[ 374.480976] hm2/hm2_5i20.0: NameString = nvkqp
[ 374.480977] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480978] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480979] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480980] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480981] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480982] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480983] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480983] hm2/hm2_5i20.0: ParmAddr = 0x000e
[ 374.480984] hm2/hm2_5i20.0: UnitString = none
[ 374.480985] hm2/hm2_5i20.0: NameString = nvkqihi
[ 374.480986] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480987] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480988] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480989] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480990] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480990] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.480991] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.480992] hm2/hm2_5i20.0: ParmAddr = 0x000c
[ 374.480993] hm2/hm2_5i20.0: UnitString = none
[ 374.480994] hm2/hm2_5i20.0: NameString = nvkqilo
[ 374.480995] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.480996] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.480997] hm2/hm2_5i20.0: DataType = 0x04
[ 374.480998] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.480998] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.480999] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.481000] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.481001] hm2/hm2_5i20.0: ParmAddr = 0x0010
[ 374.481002] hm2/hm2_5i20.0: UnitString = none
[ 374.481003] hm2/hm2_5i20.0: NameString = nvkqil
[ 374.481004] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.481005] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.481006] hm2/hm2_5i20.0: DataType = 0x04
[ 374.481007] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.481007] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.481008] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.481009] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.481010] hm2/hm2_5i20.0: ParmAddr = 0x0012
[ 374.481011] hm2/hm2_5i20.0: UnitString = none
[ 374.481012] hm2/hm2_5i20.0: NameString = nvkdp
[ 374.481013] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.481014] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.481015] hm2/hm2_5i20.0: DataType = 0x04
[ 374.481016] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.481016] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.481017] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.481018] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.481019] hm2/hm2_5i20.0: ParmAddr = 0x0016
[ 374.481020] hm2/hm2_5i20.0: UnitString = none
[ 374.481021] hm2/hm2_5i20.0: NameString = nvkdihi
[ 374.481022] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.481023] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.481024] hm2/hm2_5i20.0: DataType = 0x04
[ 374.481024] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.481025] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.481026] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.481027] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.481028] hm2/hm2_5i20.0: ParmAddr = 0x0014
[ 374.481029] hm2/hm2_5i20.0: UnitString = none
[ 374.481030] hm2/hm2_5i20.0: NameString = nvkdilo
[ 374.481031] hm2/hm2_5i20.0: RecordType = 0xa0
[ 374.481031] hm2/hm2_5i20.0: DataLength = 0x10
[ 374.481032] hm2/hm2_5i20.0: DataType = 0x04
[ 374.481033] hm2/hm2_5i20.0: DataDir = 0x80
[ 374.481034] hm2/hm2_5i20.0: ParmMax 0.00
[ 374.481035] hm2/hm2_5i20.0: ParmMin 0.00
[ 374.481036] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 374.481037] hm2/hm2_5i20.0: ParmAddr = 0x0018
[ 374.481038] hm2/hm2_5i20.0: UnitString = none
[ 374.481038] hm2/hm2_5i20.0: NameString = nvkdil
[ 374.481039] hm2/hm2_5i20.0: Modes:
[ 374.481040] hm2/hm2_5i20.0:
[ 374.481041] hm2/hm2_5i20.0: StepGen: 4
[ 374.481042] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 374.481043] hm2/hm2_5i20.0: version: 2
[ 374.481044] hm2/hm2_5i20.0: step_rate_addr: 0x2000
[ 374.481045] hm2/hm2_5i20.0: accumulator_addr: 0x2100
[ 374.481046] hm2/hm2_5i20.0: mode_addr: 0x2200
[ 374.481047] hm2/hm2_5i20.0: dir_setup_time_addr: 0x2300
[ 374.481047] hm2/hm2_5i20.0: dir_hold_time_addr: 0x2400
[ 374.481048] hm2/hm2_5i20.0: pulse_width_addr: 0x2500
[ 374.481049] hm2/hm2_5i20.0: pulse_idle_width_addr: 0x2600
[ 374.481050] hm2/hm2_5i20.0: table_sequence_data_setup_addr: 0x2700
[ 374.481051] hm2/hm2_5i20.0: table_sequence_length_addr: 0x2800
[ 374.481052] hm2/hm2_5i20.0: master_dds_addr: 0x2900
[ 374.481053] hm2/hm2_5i20.0: instance 0:
[ 374.481053] hm2/hm2_5i20.0: enable = 0
[ 374.481054] hm2/hm2_5i20.0: hw:
[ 374.481055] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 374.481056] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 374.481057] hm2/hm2_5i20.0: mode = 0x00000000
[ 374.481058] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 374.481059] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 374.481060] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 374.481061] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 374.481062] hm2/hm2_5i20.0: instance 1:
[ 374.481063] hm2/hm2_5i20.0: enable = 0
[ 374.481064] hm2/hm2_5i20.0: hw:
[ 374.481064] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 374.481065] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 374.481066] hm2/hm2_5i20.0: mode = 0x00000000
[ 374.481067] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 374.481068] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 374.481069] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 374.481070] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 374.481071] hm2/hm2_5i20.0: instance 2:
[ 374.481072] hm2/hm2_5i20.0: enable = 0
[ 374.481073] hm2/hm2_5i20.0: hw:
[ 374.481073] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 374.481074] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 374.481075] hm2/hm2_5i20.0: mode = 0x00000000
[ 374.481076] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 374.481077] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 374.481078] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 374.481079] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 374.481080] hm2/hm2_5i20.0: instance 3:
[ 374.481081] hm2/hm2_5i20.0: enable = 0
[ 374.481082] hm2/hm2_5i20.0: hw:
[ 374.481082] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 374.481083] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 374.481084] hm2/hm2_5i20.0: mode = 0x00000000
[ 374.481085] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 374.481086] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 374.481087] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 374.481088] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 374.481089] hm2/hm2_5i20.0: IO Ports: 3
[ 374.481091] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 374.481091] hm2/hm2_5i20.0: version: 0
[ 374.481092] hm2/hm2_5i20.0: data_addr: 0x1000
[ 374.481093] hm2/hm2_5i20.0: ddr_addr: 0x1100
[ 374.481094] hm2/hm2_5i20.0: alt_source_addr: 0x1200
[ 374.481095] hm2/hm2_5i20.0: open_drain_addr: 0x1300
[ 374.481096] hm2/hm2_5i20.0: output_invert_addr: 0x1400
[ 374.481097] hm2/hm2_5i20.0: instance 0:
[ 374.481098] hm2/hm2_5i20.0: data_read = 0xFF434F
[ 374.481099] hm2/hm2_5i20.0: data_write = 0x000000
[ 374.481100] hm2/hm2_5i20.0: ddr = 0x200000
[ 374.481101] hm2/hm2_5i20.0: alt_source = 0x2F415F
[ 374.481101] hm2/hm2_5i20.0: open_drain = 0x000000
[ 374.481102] hm2/hm2_5i20.0: output_invert = 0x000000
[ 374.481103] hm2/hm2_5i20.0: instance 1:
[ 374.481104] hm2/hm2_5i20.0: data_read = 0xFFDF7F
[ 374.481105] hm2/hm2_5i20.0: data_write = 0x000000
[ 374.481106] hm2/hm2_5i20.0: ddr = 0x000000
[ 374.481107] hm2/hm2_5i20.0: alt_source = 0x000000
[ 374.481108] hm2/hm2_5i20.0: open_drain = 0x000000
[ 374.481108] hm2/hm2_5i20.0: output_invert = 0x000000
[ 374.481109] hm2/hm2_5i20.0: instance 2:
[ 374.481110] hm2/hm2_5i20.0: data_read = 0xFFFFFF
[ 374.481111] hm2/hm2_5i20.0: data_write = 0x000000
[ 374.481112] hm2/hm2_5i20.0: ddr = 0x000000
[ 374.481113] hm2/hm2_5i20.0: alt_source = 0x000000
[ 374.481114] hm2/hm2_5i20.0: open_drain = 0x000000
[ 374.481114] hm2/hm2_5i20.0: output_invert = 0x000000
[ 374.481116] hm2/hm2_5i20.0: Watchdog: 1
[ 374.481117] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 374.481118] hm2/hm2_5i20.0: version: 0
[ 374.481119] hm2/hm2_5i20.0: timer_addr: 0x0C00
[ 374.481120] hm2/hm2_5i20.0: status_addr: 0x0D00
[ 374.481121] hm2/hm2_5i20.0: reset_addr: 0x0E00
[ 374.481121] hm2/hm2_5i20.0: instance 0:
[ 374.481122] hm2/hm2_5i20.0: param timeout_ns = 5000000
[ 374.481123] hm2/hm2_5i20.0: pin has_bit = 0
[ 374.481124] hm2/hm2_5i20.0: reg timer = 0x80000000
[ 374.481184] hm2/hm2_5i20.0: registered
[ 374.481186] hm2_5i20.0: initialized AnyIO board at 0000:04:01.0
[ 381.673936] hm2_5i20.0: dropping AnyIO board at 0000:04:01.0
[ 381.673940] hm2/hm2_5i20.0: unregistered
[ 381.674643] hm2_pci: driver unloaded
[ 381.690019] hm2: unloading
[ 524.958372] RTAI[math]: unloaded.
[ 525.015903] SCHED releases registered named ALIEN PEDV$D
[ 525.027527] RTAI[malloc]: unloaded.
[ 525.131881] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 525.150482] I-pipe: head domain RTAI unregistered.
[ 525.150488] RTAI[hal]: unmounted.
[ 528.450929] I-pipe: head domain RTAI registered.
[ 528.450932] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 528.450934] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12498789, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 528.456654] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 528.456680] kstacks pool size = 524288 bytes
[ 528.456681] RTAI[sched]: hard timer type/freq = lapic/12498789(Hz)
[ 528.456682] linear timed lists.
[ 528.456683] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 528.456684] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 528.478488] USERMODE CHECK: OK.
[ 528.478491] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 528.478493] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 528.482384] RTAI[math]: loaded, using musl libm.
[ 535.247749] RTAPI: ERROR: Unexpected realtime delay on task 1
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
[ 542.202456] RTAI[math]: unloaded.
[ 542.255887] SCHED releases registered named ALIEN PEDV$D
[ 542.271394] RTAI[malloc]: unloaded.
[ 542.375869] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 542.398475] I-pipe: head domain RTAI unregistered.
[ 542.398483] RTAI[hal]: unmounted.
[ 693.212173] I-pipe: head domain RTAI registered.
[ 693.212175] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 693.212178] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12498789, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 693.218714] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 693.218739] kstacks pool size = 524288 bytes
[ 693.218740] RTAI[sched]: hard timer type/freq = lapic/12498789(Hz)
[ 693.218740] linear timed lists.
[ 693.218742] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 693.218743] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 693.222023] USERMODE CHECK: OK.
[ 693.222027] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 693.222029] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 693.231799] RTAI[math]: loaded, using musl libm.
[ 708.810223] RTAI[math]: unloaded.
[ 708.863783] SCHED releases registered named ALIEN PEDV$D
[ 708.877681] RTAI[malloc]: unloaded.
[ 708.983762] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 709.006385] I-pipe: head domain RTAI unregistered.
[ 709.006392] RTAI[hal]: unmounted.
- LPMattei
[ 877.395492] I-pipe: head domain RTAI registered.
[ 877.395495] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 877.395498] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12498789, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 877.402436] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 877.402459] kstacks pool size = 524288 bytes
[ 877.402460] RTAI[sched]: hard timer type/freq = lapic/12498789(Hz)
[ 877.402461] linear timed lists.
[ 877.402462] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 877.402463] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 877.416168] USERMODE CHECK: OK.
[ 877.416171] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 877.416173] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 877.428296] RTAI[math]: loaded, using musl libm.
[ 897.967905] RTAI[math]: unloaded.
[ 898.021367] SCHED releases registered named ALIEN PEDV$D
[ 898.033314] RTAI[malloc]: unloaded.
[ 898.141349] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 898.164015] I-pipe: head domain RTAI unregistered.
[ 898.164022] RTAI[hal]: unmounted.
[ 903.692123] I-pipe: head domain RTAI registered.
[ 903.692126] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 903.692128] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12498789, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 903.700854] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 903.700880] kstacks pool size = 524288 bytes
[ 903.700881] RTAI[sched]: hard timer type/freq = lapic/12498789(Hz)
[ 903.700882] linear timed lists.
[ 903.700883] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 903.700884] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 903.719388] USERMODE CHECK: OK.
[ 903.719391] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 903.719392] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 903.727393] RTAI[math]: loaded, using musl libm.
smithy@debian:~$
"[ 332.648174] hm2/hm2_5i20.0: firmware hm2/5i20/sssvst2_2_2_v35.bit not found "
Can you check what you actually have in /lib/firmware/hm2/5i20 ?
- LPMattei
