- Thank you received: 2349
Trajectory Planner using Ruckig Lib
- Grotius
2 years 3 months ago - 2 years 3 months ago #305074
by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
@Tommy,
I was thinking about the core dump. This is kernel related.
This is my output after downloading the file. Some times i have to start the app twice before i can actually jog.
This is also the case when using not a appimage.
user@debian10:~/Downloads$ ./runtest_cnc-x86_64.AppImage
Current directory: /tmp/.mount_runtesaRaBsk/usr/bin
Note: Using POSIX realtime
Created shared memory segment
user@debian10:~/Downloads$ reading motion settings.
hal ready. component id:17
V3d_Viewer 0
Graphic3d_CView 0
OpenGL_View 0
V3d_View 0
GLXDirectRendering: Yes
GLXVendor: SGI
GLXVersion: 1.4
GLXClientVendor: Mesa Project and SGI
GLXClientVersion: 1.4
GLvendor: Intel
GLdevice: Mesa Intel(R) HD Graphics 4600 (HSW GT2)
GLversion: 4.6 (Core Profile) Mesa 22.3.6
GLSLversion: 4.60
Max texture size: 16384
Max FBO dump size: 4096x16384
Max combined texture units: 192
Max MSAA samples: 8
Viewport: 818x377
GPU memory: 1536 MiB
ResolutionRatio: 1
Unexpected realtime delay on task 0 with period 20000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
If you still keep core dump, i can edit the appimage to run Using POSIX non realtime
Warning: Spoiler!
V3d_Viewer 0
Graphic3d_CView 0
OpenGL_View 0
V3d_View 0
GLXVendor: SGI
GLXVersion: 1.4
GLvendor: Intel
GLSLversion: 4.60
Max MSAA samples: 8
Viewport: 818x377
ResolutionRatio: 1
Last edit: 2 years 3 months ago by Grotius.
- Thank you received: 2177
2 years 3 months ago #305080
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
Just tried the updated AppImage and I also get a CoreDump on my non-RT LinuxMint machine. I then tried it on a machine with a preemt_rt kernel and when I try to start the AppImage the terminal just hangs there, no output at all.I was thinking about the core dump. This is kernel related.
2 years 3 months ago #305081
How do I do that?
How do I do that?
The following user(s) said Thank You: Lcvette, Grotius
- Online
- Thank you received: 7491
2 years 3 months ago #305083
Replied by tommylight on topic Trajectory Planner using Ruckig Lib
Yup, this is non RT kernel, will try on a RT kernel later.
- tiagounderground
- Thank you received: 13
2 years 3 months ago - 2 years 3 months ago #305085
by tiagounderground
Replied by tiagounderground on topic Trajectory Planner using Ruckig Lib
same here on the rt kernel on debian 12, try to start the AppImage the terminal just hangs there, no output at all
Last edit: 2 years 3 months ago by tiagounderground.
- Grotius
2 years 3 months ago #305086
by Grotius
@Arciera,
How do I do that?
Using the cmake system, compile everything and then run it. When u use no sudo for the "cmake make install" step,
it will run non-realtime. I will do that, but now i have no time to do that. Family visit.
How do I do that?
Time to create page: 0.242 seconds
