- Thank you received: 286
Trajectory Planner using Ruckig Lib
- ihavenofish
2 years 3 months ago #305721
by ihavenofish
Replied by ihavenofish on topic Trajectory Planner using Ruckig Lib
Remember not to get side tracked away form the core g1/g0 paths. this is how this quest always dies, trying to get to broad or advance, following every little side case.
g1, g0 exact stop moves. get that solid and reliable. helixes can come later.
The following user(s) said Thank You: Lcvette, Grotius, Darium
- Grotius
- Thank you received: 2349
2 years 3 months ago - 2 years 3 months ago #305724
by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Yes get the program solid.
Ok i was on another linux distro trying to get the appimage to run.
It turned out the best way to compile it was from the /opt dir. As this dir is always the
same at linux.
Can someone verify if this pop ups a program?
If it does, first input configuration values for jog axis.
filetransfer.io/data-package/wvAnmLrd#link
I want to stop at github as it now requires 2 steps inlog sheme. I dont like this at all.
So any idea's for new code share alternative?
same at linux.
Last edit: 2 years 3 months ago by Grotius.
The following user(s) said Thank You: tommylight, Lcvette
- Online
- Thank you received: 7491
2 years 3 months ago #305726
Replied by tommylight on topic Trajectory Planner using Ruckig Lib
I see GitLab has gone full AI, so it is no more...
Welcome to CyberPunk era!
- Grotius
2 years 3 months ago - 2 years 3 months ago #305728
by Grotius
Tommy,
This is alternative example : codeberg.org/tok/libreStove
Looks ok to me, and it's free.
It seems ddns is free. Then you can setup a nas to run a public git server, or a website, forum etc.
Then the url would be something like :
http://linux-forum.ddns.net
- jdowsonjr
2 years 3 months ago #305866
by jdowsonjr
Replied by jdowsonjr on topic Trajectory Planner using Ruckig Lib
Hi there, nice work the s curves look nice on the videos on youtube. I would like to work on this too. What is the state of the merge with the main branch? i see the last commit was 4 months ago on the branch of Grotius, how are things going? what can i do to help?
- Grotius
2 years 3 months ago #305899
by Grotius
Hi Jdowsonjr,
The project has moved from github to codeberg. The reason is the required 2 step verification github requires from it sheeps.
codeberg.org/skynet/hal-core.git
Yes, i can't use this account anymore.
Currently working on the path deviation algoritme that processes the G64 P.. Q.. gcode values.
Validate if the app-image runs : filetransfer.io/data-package/wvAnmLrd#link
Then you could try to build & run the application from source.
Use qt to load the project by opening the cmakelists.txt file.
Then look around and get an idea how things are done. Then you can start adding code to the
subject you are interested in.
The following user(s) said Thank You: tivoi, Lcvette, Aciera
Time to create page: 3.371 seconds
