- Thank you received: 2177
Are you using qt for it as viewer and editor? This should be the nice as you can load the cmakelists directly in qt.
Is there a particular reason for not handling one fillet after the other?
In a other function, we start with a list of segments. (gcode input) .
They then already have a flag if they may be trimmed front & back.
It this point the empty fillet segments are inserted inbetween. This is a vector insert operation.
