- Thank you received: 2177
At this point linuxcnc cannot be recovered and has to be restarted
Correction: If I wait long enough after hitting the 'Stop program execution' button it does actually stop the program and the GUI is responsive again but loading another ngc file (not even running it) makes it hang again.
termial output:
Code:USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 1 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 53 timeout USRMOT: ERROR: command 1 timeout USRMOT: ERROR: command 38 timeout task: main loop took 35.003955 seconds USRMOT: ERROR: command 11 timeout task: main loop took 1.001118 seconds
