linuxcnc trajectory planner
2 years 2 weeks ago - 2 years 2 weeks ago #312166 by juliankoenig87
This is usually the point where I get rid of G2/3 in all my postprocessors of my CAMs... Didnt you had the discussion wheter to use G2/3 or not? I think in the end this whole topic is one reason why a lot of systems use only G1 in small lenght of course. I assume it would make a lot of things easier, or am I wrong?
Best regards
Julian
Last edit: 2 years 2 weeks ago by juliankoenig87.
2 years 2 weeks ago #312197 by Grotius
Replied by Grotius on topic linuxcnc trajectory planner
@Hi Julian,
As i speak for the programming world, i suggest programmers love to describe a line, arc or spline using a few points.
As memory efficient as can be.
But i get your point.
The error i was getting, i think i figur it out.
The arc function that get's the current point on the arc does this not
by giving it a 0-1 progress.
Instead a 0-arclenght input is the way to do it.
So here i was wrong. But it's also poor commented, so i could not know it so easy.
The following user(s) said Thank You: akb1212, Lcvette, Darium
2 years 2 weeks ago - 2 years 2 weeks ago #312253 by Lcvette
Replied by Lcvette on topic linuxcnc trajectory planner
awesome to see this active again!! glad you are ok and back at it image missing /media/kunena/emoticons/laughing.png
Last edit: 2 years 2 weeks ago by Lcvette.
2 years 2 weeks ago #312292 by Grotius
@Lcvette,
Thank you for your kind words !. image missing /media/kunena/emoticons/wink.png
Had a weird experience. The scene was as follows.
1. Run linuxcnc with the "linuxcnc" splash gcode. Added G64 P1 to the top of gcode file. Then i pressed run.
2. Ok machine run's the file. In the background the traject optimizer was busy and a few moments later image missing /media/kunena/emoticons/whistling.png was ready.
3. Then load the produced file : ~/cmake/ "validate.ngc". into linuxcnc.
4. The gcode preview shows that "arcs" where converted to "lines". So how is this possible. Did i made a typo in the code?
5. Then i was reading online :
link
when the maximum deviation of an arc from a straight line is less than the G64 Q- tolerance, the arc is broken into two lines (from start of arc to midpoint, and from midpoint to end).
Conclusion for the test environment :
The interpreter had transformed the G2 & G3's into G1's. And the optimizer was then reading this false information.
So now to avoid this mismatch the files to blend are loaded with a empty G64 P, Q value, ensuring a valid input to the optimizer.
Then inside the optimizer the G64 P & Q values are set for now.
Ok, Then finally :
The vertical lines are for testing. It are spline control points. I had to visualize them to track the previous error.
Ok for now this is looking better.
The following user(s) said Thank You: akb1212, tommylight, Lcvette, Aciera, Darium
2 years 2 weeks ago #312296 by Lcvette
nice! yeah not sure how to get around linuxcnc applying the G64 rules pre optimizer. may need something edited during initial load?
2 years 2 weeks ago #312303 by Grotius
Hi Lcvette,
I didn't know linuxcnc would do this. When coding and testing i got my head scratched and thought : alien obstruction image missing /media/kunena/emoticons/devil.png
Yes, indeed. We are screwed. image missing /media/kunena/emoticons/unsure.png
Tested this in top off a linuxcnc gcode file :
G64 P10 Motion blending tolerance
G61 Exact Path Mode
This then resolves the issue.
Wich means this is not applied :
Another error i was getting:
"same Y word..".
Cause, when running the "validation.ngc" file, when start is pressed, the file overwrites itself.
To avoid this, the filename now get a random number attached.
In the mean time, we learned a lot today.
The following user(s) said Thank You: akb1212, Lcvette, tiagounderground, Darium
Time to create page: 0.103 seconds
