scurve trajectory planner
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Jan 2025 14:23 - 25 Jan 2025 14:23 #319819 by Grotius
Replied by Grotius on topic scurve trajectory planner
@Julian,
The file seems to run now under -> ./start_axis_9
I removed some segment length checks like : < 1e-12
This is a very tiny value, but it was enough to halt the planner so now and then.
Code is updated.
Last edit: 25 Jan 2025 14:23 by Grotius.
The following user(s) said Thank You: Beef
25 Jan 2025 14:30 #319820 by juliankoenig87
Replied by juliankoenig87 on topic scurve trajectory planner
Well done!
I will update/patch and try some more codes on my testmachines this evening (living in Germany btw.). I will report back then.
25 Jan 2025 15:25 #319822 by spumco
Replied by spumco on topic scurve trajectory planner
And that behaviour continues under scurve planner?  That was what I was referring to. Not what standard planner does.
@Joco - my apologies, I completely misunderstood your original warning.  I thought you were concerned that the current TP maybe didn't lock out FH and motion-inhibit as advertised, and perhaps that situation was carried in to Grotius' s-curve TP.
I have not tested the s-curve TP's behavior.
Sorry to all for the unnecessary tangent.
25 Jan 2025 20:48 #319847 by juliankoenig87
Hi Grotius,
had some time to test. First of all. No freezes, overflows what so ever. So well done!
I found two things and I made two videos to show it:
1.) When stopping or pausing the code the DRO dont stop. this is with my 4 axis testmachine. With the 9axis sim machine this dont happen. Both machines show strange DTG values for the A axis.
Video 1
2.) Of course in the first video the max jerk limits the feed override. So I tested a insane 2000% feed override with insane max jerk and something happened. Up to 500% everything looks fine. Over 500% it stops the code. Then I have to back up to ~350% and everthing starts again. So, yeah, not a real usecase, but I found it while going crazy at testing - sorry.
Video 2
The following user(s) said Thank You: Lcvette
25 Jan 2025 21:48 #319850 by juliankoenig87
Found another one.
The slider for max velocity is working incorrect.
Video
As one can see, I test stupid high velocities, accelerations, jerk values and so on. With such experiments I am able to crash the tp. But no freezes of linuxcnc and I am able to stop the program and restart it without a problem.
The following user(s) said Thank You: Lcvette, Darium
  • Grotius
  • Platinum Member
  • Platinum Member
26 Jan 2025 10:35 - 26 Jan 2025 10:36 #319877 by Grotius
@Hi Julian,
The display value for "dtg" abc, uvw is fixed. This was indeed a bug.
When moving in a blend segment, the "dtg" abc, uvw values are calculated slightly different.
This was not calculated correctly for the display value.
Then i tried max velocity overide : 20.0 and a max jerk of 20.000.
However i was not able to get the planner to run crazy.
Can you post video's with higher resolution or full screen. I cannot read the hal text in the video.
Your last video, maybe provide the file, and run values, so i can try to get same behaviour.
How do you update the code when github is updated?
Living in Holland, Next door.
Code is updated.
Last edit: 26 Jan 2025 10:36 by Grotius.
The following user(s) said Thank You: pommen, Lcvette, Darium, zmrdko
26 Jan 2025 10:57 - 26 Jan 2025 10:59 #319878 by juliankoenig87
Hi Grotius.
I copy cmake and run ./patch and the ./install.
I will do some more testing later and will try to capture the screen. Are you sure you maximized the resolutuon? I can read everthing in my videos.
And of course I will provide the code. I think it will be best to further test with your provided 9axis sim machine so that we will have the same circumstances. But I will test also with my test 4 axis machine with connected 7i92 mesa card just to be sure I dont miss something.
Last edit: 26 Jan 2025 10:59 by juliankoenig87.
The following user(s) said Thank You: Lcvette, Grotius
26 Jan 2025 13:35 - 26 Jan 2025 13:36 #319884 by juliankoenig87
Grotius,
I tested it with "20.0 and a max jerk of 20.000". With this settings the tp dont stop. Try stupidly high values (jerk 20.000.000 for example) and you will see, that anywhere in the override range of 500% to 1500% the tp stops. I think something overflows...
To be clear. I dont WANT to find a bug. I found it because I wanted to test different codes the fast way ;-)
Last edit: 26 Jan 2025 13:36 by juliankoenig87.
The following user(s) said Thank You: Darium
26 Jan 2025 14:05 #319886 by juliankoenig87
Ok. Your new code works a lot better.
With the given 9axis sim machine everything works as it should I think.
But, if you use a my 4axis testmachine (very high kinematic values) than you are able to stop the tp and also get trouble with the axis screen. But nevertheless. Under normal circumstances the 4axis testmachine works now also without axis screen problems.
26 Jan 2025 20:32 - 26 Jan 2025 20:58 #319910 by juliankoenig87
Hi Grotius,
I made a small test nc file for better testing. This is a video with my 4 axis test machine capable of:
- 100m/min velocity
- 1 g acceleration
- 6.000 rpm A axis
- wild acceleration of the A axis
My current project will be capable of 30m/min, 0,5 g and the A axis will be a turning axis (of curse with way less acceleration). So in my opinion the test machine is not sooooo way of.
Video
I try different feed override values and as you can see I set the max jerk nearly to maximum (as if there is no scurve).
The behaviour of the A axis is still strange. And as you can see I am able to stop the tp. but it seems that the planer works on and only the axis gui si stoped. Nevertheless strange.
Please feel free to mention if I am testing to wild! I can live with boundaries so to say.
Last thing I just realised. 2.9.3 need a few percentage of my cpu (i5 4570T), maybe 3 to 10%. 2.10 with your scure tp needs over 40% while in idle and up to 50% while running the program.
Last edit: 26 Jan 2025 20:58 by juliankoenig87.
Time to create page: 0.240 seconds
