scurve trajectory planner
- FabianB
- Thank you received: 19
10 Feb 2025 13:03 - 10 Feb 2025 13:09 #321156
by FabianB
Replied by FabianB on topic scurve trajectory planner
Hi Grotius,
thanks for all the work you have put into this project to bring s curves to LinuxCNC. That's a really impressive achievement. Julian told me about your work.
I have not yet managed to work through all the papers in detail which you have linked so I might be a little bit underinformed but your definition of your torsion for 3D clothoids seems to be a bit unusual (or I don't understand it).
Is your intention like this?
theta0 & kappa0 -> xy => kappa0 = curvature
theta1 & kappa1 -> z => kappa1 = torsion for the 3D case
This would fit to your first approach to extend a clothoid to 3D by simply adding a second clothoid to the z dimension (which does not result in a curve with perfect curvature and torsion transition but probably way better than before). However, this is not how curvature and torsion of a 3D curve are defined in general so it will not fit to the 3D clothoid description in the Frego paper.
Best regards,
Fabian
Best regards,
Fabian
Last edit: 10 Feb 2025 13:09 by FabianB. Reason: typo
- Grotius
- Thank you received: 2349
10 Feb 2025 21:14 #321187
by Grotius
Replied by Grotius on topic scurve trajectory planner
@Fabian,
Thanks for writing me. Mabye you could help us?
The frego paper i tried to read it tonight. It brings up several idea's how clothoids where solved in the past.
And then it bring's up a closed form solution.
However i just miss the knowlegde here to understand how it's done.
This paper i would bring under attention, it uses 4 clothoids to generate a clothoid spline fillet in 3d.
The mathematics are quite well documented. And the result pictures look very promising.
clothoid paper 3d_1
clothoid paper 3d_1
- Grotius
10 Feb 2025 22:51 #321191
by Grotius
Hi automata,
Yes you are right.
We will try to implement 3d clothoid.
If this won't succeed we revert to your method.
Yes you are right.
- FabianB
11 Feb 2025 09:35 #321217
by FabianB
The closed form solution from the Frego paper only works if the clothoid starts with curavture and torsion = 0 aka from a straight line. So for our usecase this can not be used in all situation, only if we we want to connect to a straight line and not to arcs or splines etc.
Thanks for the new paper, I will read it later.
- FabianB
11 Feb 2025 10:17 - 11 Feb 2025 10:23 #321220
by FabianB
I tried to draw a picture to ilustrate the issue with the 2D clothoids stacked on each other to approximate a 3D clothoid.We want to connect a straight line in y with another line in x. The second one isI tried to draw a picture to ilustrate the issue with the 2D clothoids stacked on each other to approximate a 3D clothoid.We want to connect a straight line in y with another line in x. The second one is also shifted up in z. The 1) picture shows a 3D drawing of the situation. Pictures 2) and 3) show the xy and xz planes respectively with how the 2D clothoids would look like respectively.
The 2 clothoids look fine by themself, the one in xy is also close to the correct one I guess. The issue is with the second one in xz. The clothoid optimizes curvature in this xz projection so you get linear increasing and decreasing curvature relative to arc length in this projection but not linear in total 3D arc length. In this example the difference is quite extreme because the curve is initially moving mainly in y and not in x. So the resulting curve does not behave as expected. Picture 4) shows the resulting curve in the yz plane, the tool is barely moving in z for quite some time (because the machine is mostly using in y and this direction got ignored for the clothoid calculation. Then it suddenly needs to move quite a lot in z and jerk is much higher than expected from the xz clothoid.
I hope I managed to explain this, it’s kind of hard to visualize 3D clothoids.
So in summary this approach leads to a smooth curve with fitting curvatures at the ends but in between the change in curvature and torsion is not linear and jerk might be higher than expected. The resulting connection curve also dependens on the orientation in the coordinate system. If the example was rotated for example by 45° the resulting clothoids would look differntly. This is of course kind of unintuitive.
So it does work to some extend but is not the best solution and there might be more extreme edge cases where this might go wrong.
Last edit: 11 Feb 2025 10:23 by FabianB.
The following user(s) said Thank You: akb1212, tivoi, pommen, Grotius, Aciera
- automata
- Thank you received: 92
11 Feb 2025 14:52 #321234
by automata
Replied by automata on topic scurve trajectory planner
Hi Grotius,
In the latest version of scurve, how do you set the max deviation parameter?
Right now, I am not able to change the filleting using the spline. Is there any way to enable spline filleting?
I am running the ../cmake/configs/axis_9/axis_scurve_9_mm.ini config.
My tpmod parameters are:
Parameters:
Owner Type Dir Value Name
4 float RW 0.5 tpmod.hal_blend_speed
4 s32 RW 1 tpmod.hal_blend_type
4 s32 RW 1 tpmod.hal_g0_transition_blend
4 s32 RW 20 tpmod.hal_look_ahead_lines
4 float RW 2500 tpmod.hal_max_jerk
No amount of fiddling with G64 is getting the splines to show up.
Am I missing something or some step?
Regards,
-automata
Parameters:
Regards,
-automata
- Grotius
11 Feb 2025 17:17 - 11 Feb 2025 17:22 #321249
by Grotius
@Fabian,
Thank you for nice illustration. This indeed will not work.
Good you have seen the Frego paper is not suitable for our work!
For the new paper, i managed to code Equatation 39.
However Equatation 40, i dont understand the first greek character, and the name of this character.
@Automata,
Currently there is no filleting algo active in the source.
Latest update was to test scurve by Julian.
Also G93,94,95 work now.
Next to do is add filletizing algo. Should be nice if we can directly add a 3d clothoid.
@Automata,
Last edit: 11 Feb 2025 17:22 by Grotius.
- Thank you received: 2176
11 Feb 2025 17:57 - 11 Feb 2025 17:58 #321256
Replied by Aciera on topic scurve trajectory planner
The greek letter is 'kappa' and stands for curvatureHowever Equatation 40, i dont understand the first greek character, and the name of this character.
Last edit: 11 Feb 2025 17:58 by Aciera.
- Grotius
11 Feb 2025 20:47 #321278
by Grotius
Hi Arciera,
Thanks.
I wrote a email to "Min Wan" University in China.
He or she is one of the abstract creators of the 3d clothoid.
I asked for any source code. Or any code they have used for testing their algo that can help us.
Fingers crossed.
To me it looks like " means second derivate?
And the sign above the z and x i don't know.
Thanks.
Fingers crossed.
12 Feb 2025 08:46 #321330
Time to create page: 0.233 seconds
