scurve trajectory planner
1 year 5 months ago #329345 by grandixximo
Replied by grandixximo on topic scurve trajectory planner
The best way to know is testing for yourself, it all depends on what you mean by "real work", if you find issues for your use case politely post them here.
I did my own testing, and it is getting closer to my "real work", it is very exciting, but there is still a lot of work, and I'm extremely impressed and grateful to Grotius and co to be tackling this, much appreciated...
The following user(s) said Thank You: HalaszAttila
1 year 5 months ago - 1 year 4 months ago #329438 by ruediger123
Replied by ruediger123 on topic scurve trajectory planner
 Hallo,
I tested the new version today and noticed that when I round the corners P64 P10.0 the speed of the axis (joint) does not behave as expected (yellow circle).
The acceleration (green circles) is interrupted by (blue circles) whereby the change in acceleration (jerk) appears to be too large.
At P64 P0.0 the axis (joint) behaves as expected.
Can this behavior be set via parameters?
Gruß
Rüdiger
Last edit: 1 year 4 months ago by ruediger123.
1 year 2 months ago #333033 by automata
Replied by automata on topic scurve trajectory planner
Hi, is there any more testing and progress on the scurve planner to report?
-automata
1 year 2 months ago #333114 by konrad
Replied by konrad on topic scurve trajectory planner
@Rüdiger
May this be a result of the missing (?, the screenshot is hard to read) Q parameter? From the   readme :
Important Runtime NotesWhen using the S-curve trajectory planner, always use the
G64 P[x] Q[x]
 command combination. If
Q[x]
 is not specified, the interpreter may:
  1. Remove or filter out small segments.
  2. Convert arc segments into line segments.
A standard input should look like this:
G64 P0.01 Q0.0
1 year 2 months ago #333260 by ruediger123
As far as I know, the Scurve Trajectory Planner plans the tool's trajectory using jerk, acceleration, and speed, which works very well, but doesn't take the constraints of the individual axes into account.
For example, the trajectory speed is constant in a 90° corner, while the axis speeds change without considering constraints.
This can be seen in my previous post.
I hope I explained the connections correctly.
gruss
Rüdiger
1 year 2 months ago #333360 by Grotius
Replied by Grotius on topic scurve trajectory planner
This is correct. In the source code the trajectory path is used to calculate xyz coordinates.
There it doesn't apply any calculation to reduce any speed for x or y or z. So if Z maxvel is very low, it does not reduce
speed for z.
The following user(s) said Thank You: Darium
Time to create page: 0.443 seconds
