scurve trajectory planner
1 year 8 months ago #321132 by Grotius
Replied by Grotius on topic scurve trajectory planner
I thought, mabye just start coding a clothoid lib. And try to
understand how 3d clothoids work.
I followed this paper, the same as Andrew used : 2d clothoid
Then coded chapter 4 into c code.
Was also able to look into Andrews clothoid code from where i
borrowed the gaus legendre.
With a little assistance of DeepSeek i was able to get a single 2d clothoid
running and plotted with gnu plot.
Then i turned on my experimental mode and tried to expand the signle 2d clothoid
to a single 3d clothoid.
The 3d clothoid uses torsion. To keep it simple i used simple names in the c code.
theta0 & kappa0 -> xy
theta1 & kappa1 -> z
I think the hard part is really the bi-clothoid fitting, wich has to be coded yet.
Code so far:
libclothoid
Gnu plot of single 3d clothoid:
The following user(s) said Thank You: akb1212, tivoi
1 year 8 months ago #321143 by automata
Replied by automata on topic scurve trajectory planner
Hi Grotius,
I feel that for 3 axis Gcode, your earlier method of applying 2D bi-clothoids by considering them in the plane holding the two lines should be sufficient for line-line, line-arc and arc-line cases. Only in arc-arc case, you may run into this 3D clothoid / torsion scenario.
-automata
1 year 8 months ago - 1 year 8 months ago #321156 by FabianB
Replied by FabianB on topic scurve trajectory planner
Hi Grotius,
thanks for all the work you have put into this project to bring s curves to LinuxCNC. That's a really impressive achievement. Julian told me about your work.
I have not yet managed to work through all the papers in detail which you have linked so I might be a little bit underinformed but your definition of your torsion for 3D clothoids seems to be a bit unusual (or I don't understand it).
Is your intention like this?
theta0 & kappa0 -> xy => kappa0 = curvature
theta1 & kappa1 -> z => kappa1 = torsion for the 3D case
This would fit to your first approach to extend a clothoid to 3D by simply adding a second clothoid to the z dimension (which does not result in a curve with perfect curvature and torsion transition but probably way better than before). However, this is not how curvature and torsion of a 3D curve are defined in general so it will not fit to the 3D clothoid description in the Frego paper.
Best regards,
Fabian
Last edit: 1 year 8 months ago by FabianB. Reason: typo
1 year 8 months ago #321187 by Grotius
@Fabian,
Thanks for writing me. Mabye you could help us?
The frego paper i tried to read it tonight. It brings up several idea's how clothoids where solved in the past.
And then it bring's up a closed form solution.
However i just miss the knowlegde here to understand how it's done.
This paper i would bring under attention, it uses 4 clothoids to generate a clothoid spline fillet in 3d.
The mathematics are quite well documented. And the result pictures look very promising.
clothoid paper 3d_1
1 year 8 months ago #321191 by Grotius
Hi automata,
Yes you are right.
We will try to implement 3d clothoid.
If this won't succeed we revert to your method.
1 year 8 months ago #321217 by FabianB
The closed form solution from the Frego paper only works if the clothoid starts with curavture and torsion = 0 aka from a straight line. So for our usecase this can not be used in all situation, only if we we want to connect to a straight line and not to arcs or splines etc.
Thanks for the new paper, I will read it later.
Time to create page: 1.129 seconds
