- Thank you received: 6
Yes PCW, is the same Realtek with dkms driver for fix latency.
Maybe I'm asking the wrong question: is it really necessary to do the test with YouTube?
When you get an error, what does:
halcmd show param *.tmax
(typed in a terminal)
show?
need more of 8Gb ? i need desolder realtek from my motherboard?Did ya set the governor to performance?
Try to remove unnecessary hardware.
blacklist kernel modules of unneeded devices.
Mask and disable unneeded services.
Ensure you have plenty of RAM; disk I/O should be avoided as much as possible.
Caching and buffering will reduce disk I/O and latency, but requires ample free RAM.
Warning: Spoiler!When you get an error, what does: halcmd show param *.tmax (typed in a terminal) show? This will help determine where the fault lies
33 s32 RW 16640759 remora.read.tmax
I don't know the CPU clock frequency but if it's say 3 GHz, this is ~5 ms
so if you have a 1 ms servo thread, you are likely dropping packets
This indicates a network latency issue.
So possible the DKMS patch did not apply or there is still something
remaining wrong with the network setup.
I would run the ping test again, as it will show these issues clearly
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
