Which kernel version is best for real time?
1 year 5 months ago - 1 year 5 months ago #328391 by DarkPhoinix
sudo apt-get install r8168-dkms Lettura elenco dei pacchetti... Fatto Generazione albero delle dipendenze... Fatto Lettura informazioni sullo stato... Fatto    r8168-dkms è già alla versione più recente (8.051.02-2). 0 aggiornati, 0 installati, 0 da rimuovere e 3 non aggiornati.
The module is this, they are update...
NO RUSTDESK
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10 PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data. --- 10.10.10.10 ping statistics --- 60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms rtt min/avg/max/mdev = 0.154/0.210/0.417/0.027 ms
WITH RUSTDESK
 sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10 PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data. --- 10.10.10.10 ping statistics --- 60000 packets transmitted, 60000 received, 0% packet loss, time 60006ms rtt min/avg/max/mdev = 0.131/0.213/2.341/0.035 ms
Last edit: 1 year 5 months ago by DarkPhoinix.
1 year 5 months ago #328396 by tommylight
You should really mention you keep using the remote desktop, not everyone here knows what RustDesk is.
And that begs the question, how is the NVEM wired to the PC?
So yes, rustdesk is causing issues, but if you are using a hub/switch, that is a big nono for machine control.
The following user(s) said Thank You: DarkPhoinix
1 year 5 months ago #328400 by DarkPhoinix
So why do they do these tests with 4 YouTube videos in 4k in the forum? in direct connection with stress test 100 GLXgears I can work safely even with NVIDIA! I got this AMD VGA and now I also bought a motherboard with HDMI output to pass the YouTube 4K video test!
1 year 5 months ago #328408 by tommylight
Youtube is used to stress the video subsystem as video uses interrupts that require the PC to halt until whatever is requested by that interrupt is finished, then go on to do other stuff, and so on. I am not aware of anywhere being stated you must use 4 youtube videos, if you are, please let us know so we can fix that. A single window maximizing and minimizing is enough to trigger latency excursions, so 4 are overkill and prove nothing.
Same thing with GlxGears, video, but easier to run, but this also uses OpenGL that is used by LinuxCNC, namely Gremlin uses it to display the stuff being cut. We use 10 as it is very lite on resources, but 100?
You keep mentioning that under stress it works fine (even unresponsive, and this is something Linux does magnificently), so you can try adding a base period and test some values till you get something that gets rid of errors/issues.
Probably something like this should do, add to hal file:
loadrt base_period_nsec=100000
You can safely try from 10000 to 500000 (10K to 500K), above would probably not help at all and below might cause the PC to slow down.
1 year 5 months ago #328411 by DarkPhoinix
forum.linuxcnc.org/38-general-linuxcnc-q...ults?start=40#327937
100 glxgears windows +
stress --cpu 4 --io 4 --vm 4 --vm-bytes 1500M --timeout 200s
= no junction error
4k youtube video (1 or 2 or 3 or 4 windows) with or not remote connection = junction error
in need put like this in hal file:
 #load the Remora real-time component loadrt remora-eth-3.0 PRU_base_freq=500000 loadrt base_period_nsec=100000
i think the problem is not video but the network load.... i can't try a youtube video offline...  i do not why people tell to use this test for combo network + vga load??
I am newbee i read and make ... i try the way of new version kernel fot test but  the new kernel give me more latency.
I ma near to finish the CNC, next try real work for test ...
Sorry all for my bad bad english.
1 year 5 months ago #328421 by tommylight
Yes that is the correct place to put it.
While testing this, no stress test, no glxgears, no video, no youtube.
Time to create page: 0.111 seconds
