Which kernel version is best for real time?
1 year 5 months ago #328056 by DarkPhoinix
Why in the kernel of linuxcnc why are hibernation and other acpi function active?
Is not  a problem?
1 year 5 months ago #328057 by DarkPhoinix
Warning: Spoiler!
Yes i have Realtek card but i solved the problem with the r8168-dkms module.
1 year 5 months ago #328060 by DarkPhoinix
root@cnc:/home/cnc/kernel/linux-6.12.27# cat .config | grep -i Preempt # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set # CONFIG_PREEMPT is not set CONFIG_PREEMPT_RT=y CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPTION=y CONFIG_PREEMPT_RCU=y CONFIG_HAVE_PREEMPT_DYNAMIC=y CONFIG_HAVE_PREEMPT_DYNAMIC_CALL=y # CONFIG_DEBUG_PREEMPT is not set # CONFIG_PREEMPT_TRACER is not set # CONFIG_PREEMPTIRQ_DELAY_TEST is not set
ok?
1 year 5 months ago #328090 by unknown
Not quite true, disabling hyper threading is well worth it, as are a number of other generic options that have been discussed.
As for the kernel config, the most important settings are the preempt_rt ones, infact one of the easiest ways is to base the config for the new kernel on the running one.
If you really feel the issue is with the GPU I don't think a different kernel will fix much.
1 year 5 months ago #328098 by DarkPhoinix
youtube.com/shorts/mWCeSrF2TUM
I did a new test 100 windows of glxgears and CPU stresstest active the PC is no longer responsive even the linuxcnc window but the servo continues to go and finishes the job. I don't understand why YouTube goes into error! I must say that today the drivers arrived and the new servos do not make a minimum of noise but I have to check them in the car better.
1 year 5 months ago #328106 by unknown
Yeah I think even anon realtime kernel running a text editor with 100 glx windows open would become unresponsive. Honestly I'm of the opinion that is an unrealistic and silly test, that doesn't prove anything. You're testing for a situation that no sensible person would subject a computer to whilst running gcode.
Obviously you are expecting unrealistic things, and any further interaction is at this point a worthless endeavour on my part.
Time to create page: 0.156 seconds
