- Thank you received: 6
I did it and the situation gets worse! if I only move the linucnc window the steppers make absurd noises and change the speed of movement, they are not yet on the machine they are free.. I don't dare to think what they could do at work!If your CNC setup works, then don't worry and just move on.
If you are paranoid, just set your max jitter to some really high value in your config.
Don't worry about stuff unless you need to.
Do you get latency warnings when you run LinuxCNC?
Are you still using the same PC discussed here on several topics?
Why do you keep doing the same things and expect different results? Stressing the system beyond it's limits will always fail.
Change the graphic card, get a used one for AMD, or get a used PC.
You had good latency at one point in time, so what happened?
Do you have a Ethernet connected motion device?
If so, the latency test is relatively useless for determining the actual
LinuxCNC latency.
A simple ping test is much more informative:
sudo chrt 99 ping -i .001 -q -c 60000 [Device_IP]
(will run 1 minute and print out timing statistics)
Where device _IP is the IP address of your Ethernet motion control interface.
