XHC WHB04B development?
7 months 3 weeks ago #344007 by Hakan
Replied by Hakan on topic XHC WHB04B development?
Get a real machine, rodw :)
In a milling machine and lathe, there are many situations where you may need to jog before homing.
To get the tool out of the way before homing for example.
7 months 3 weeks ago #344008 by rodw
Replied by rodw on topic XHC WHB04B development?
I had a mill and am building another. I thought HOME_SEQUENCE was designed to get the tool out of the road image missing /media/kunena/emoticons/ermm.png
7 months 3 weeks ago #344014 by Hakan
There are always situations with tool and work piece geometries
and unfortunate stop situations where one need to stick the nose (eyes) close up
to guide the tool out of the situation before it's free for homing.
I guess the best is to leave it up to the user if he wants to jog before homing.
The following user(s) said Thank You: NWE
7 months 3 weeks ago #344016 by rodw
I think there is an oversight in the homing model. I can't see why joint axes can't move in unison before they are homed. If my first machine didn't have a gantry, maybe I'd have a different view. I've often wondered why this treats each side or a gantry as seperate axes when they are always joined at the hip!
7 months 3 weeks ago - 7 months 3 weeks ago #344023 by Hannes
Replied by Hannes on topic XHC WHB04B development?
@Finngineering: So you did not start a rewrite? I see it the same way. The actual component looks like a school book example of object oriented design, then it didn't suite the needs, took way more time then estimated and the needed redesign, simplification and finalizing never happened. But for a rewrite, the chances are high the same will happen and to get it to the functional state the actual module has, it will take a lot of time. So if it works now, fine. If there emerge unsolvable issues, we can think about it again.
I looked quickly into the xhc-hb04: is way less complex but it also has less functionality. I find this automatic change to manual quite nice. And the xhc-hb04 has a complex hal and config file which probably also makes it difficult to use.
@rodw: As I understand linuxcnc, before homing, you can only jog single axis due to the kinematics needs homing. But due to jogging Y1 separate from Y2 will bend the gantry, this is deactivated like in my machine using HOME_SEQUENCE. I don't need jogging before homing, so that's fine for me.
However, the WHB04B tries to activate jogging also before homing and then generating errors. For me, that's a non-issue, I just don't touch the wheel. And if it happens by accident, nothing else happens except an error messages.
For non-gantry machines, you can jog also before homing, so I did not remove that functionality because it might be useful for others.
An solution would be to add a command line option for this. However, I rather create some chips than continue coding... ;-)
Additionally, I started another rabbit hole which is more important for my machine:
github.com/LinuxCNC/linuxcnc/issues/3839
Just a note: Linuxcnc is just a hobby for me I started recently. But I have a lot of experience in coding and bug fixing from my day job and I figured fixing the issues I am having myself and creating PR's would give something back to the community.
Last edit: 7 months 3 weeks ago by Hannes.
The following user(s) said Thank You: rodw, NWE
7 months 3 weeks ago #344066 by Finngineering
No, I did not really start a rewrite. I made a small program to communicate with the pendant, but it was more for troubleshooting than planned as the start of a new component. But I did make a new firmware for the dongle, which I have been using without issues so far.
Maybe it was not completely fair to compare it to the xhc-hb04 component. Anyway, I'm glad somebody made this component in the first place, and of course all your bugfixes and improvements are a clear step in the right direction.
I experienced an issue with arc preview just a few weeks ago that I made a post about. I think this may be a bug or limitation in the preview only rather than connected to the issue you mention. But I thought I might as well mention it, since it has some similarities to the issue you mention.
forum.linuxcnc.org/20-g-code/58285-stran...r-circular-arc-g2-g3
Time to create page: 0.381 seconds
