Time to setup my lathe with 7i76e
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 Feb 2018 20:17 #106445 by tecno
Replied by tecno on topic Time to setup my lathe with 7i76e
Did a test with
setp axis.0.wheel-jog-active TRUE
would not start LCNC
24 Feb 2018 20:27 #106451 by rodw
Replied by rodw on topic Time to setup my lathe with 7i76e
Axis and /or joint too ?
I have both connected
Mike
I think that may depend on the linuxcnc software version. I'm using master and do not use joint mode anywhere as I have a gantry
24 Feb 2018 20:28 #106452 by rodw
sorry try sets
  • tecno
  • Platinum Member
  • Platinum Member
24 Feb 2018 20:29 #106453 by tecno
OK, will do tomorrow.
Cheers from a bloody cold Sweden
24 Feb 2018 20:43 #106456 by rodw
Maybe thats why you guys are doing well at the winter Olympics!
Its been getting a little bit cooler here 24 degrees C at 7:45am
In the absence of snow, I have no idea why we have competitors there!
  • tecno
  • Platinum Member
  • Platinum Member
25 Feb 2018 10:10 #106474 by tecno
sets can not find signal name. So name am I looking for?
25 Feb 2018 10:13 #106475 by rodw
Its been so hot here today I've forgotten!
Maybe it was here
forum.linuxcnc.org/39-pncconf/33451-time...76e?start=170#106441
  • tecno
  • Platinum Member
  • Platinum Member
25 Feb 2018 11:46 #106479 by tecno
Still no-go.
Been editing this line but still no-go
loadrt ........ sserial_port_0=20xxxx" change to 02 will not find MPG port, 20 and 21 22 starts LCNC but still no MPG working.
Anybody that can see what is wrong in my hal?
25 Feb 2018 11:57 - 25 Feb 2018 11:57 #106481 by rodw
Something like this but ignore the crazy bit file I'm using.
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=/home/plasma/linuxcnc/configs/Plasma3.10.01/7i76e_7i76x1_PktD.bit num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=2xxxx"
Last edit: 25 Feb 2018 11:57 by rodw.
25 Feb 2018 11:58 #106482 by Mike_Eitel
Replied by Mike_Eitel on topic Time to setup my lathe with 7i76e
Ok lets go back one step.
Go to a sserial that shows mpg ports. Control in hal that your values change.
I think you had that in #106438 ?
Do the change value as you want means positive in the direction you want ?
If both are fine your fone with mesa config. Problem is then in hal.
Please report when you are back to that position.
