Time to setup my lathe with 7i76e
- Thank you received: 4149
25 Mar 2018 08:50 #107798
Replied by rodw on topic Time to setup my lathe with 7i76e
All you do is to add 2 instancesand use
ilowpass.0 for one axis and ilowpass.1 for the other.
That example does work as I used it on my 7i76e. Take care though, I think the scale defaulted to 1 metre per click on the MPG so I had a massive crash... I think you need to adjust your scale selector settings as well
Just get one of them going first.
loadrt ilowpass count=2
addf ilowpass.0 servo-thread
addf ilowpass.1 servo-threadilowpass.0 for one axis and ilowpass.1 for the other.
- tecno
- Thank you received: 127
25 Mar 2018 08:53 #107799
by tecno
Replied by tecno on topic Time to setup my lathe with 7i76e
Done that Rod and it did not work, maybe some typing error so I will get back on it again today and see what I can come up with.
25 Mar 2018 09:09 - 25 Mar 2018 09:11 #107800
Just looking at your hal file, you already have an instance of ilowpass so you will need to add 3 instances and name them all
These lines need to be sent through ilowpass
This is why I much prefer this 2 line style in my hal
As it lets you change it much more easilly.
Don't expect this to work first time but it should be close
net jog-0-counts axis.0.jog-counts <= hm2_7i76e.0.7i76.0.0.enc0.count
net jog-2-counts axis.2.jog-counts <= hm2_7i76e.0.7i76.0.0.enc1.countThis is why I much prefer this 2 line style in my hal
net jog-0-counts <= hm2_7i76e.0.7i76.0.0.enc0.count
net jog-0-counts => axis.0.jog-counts As it lets you change it much more easilly.
loadrt ilowpass, count = 3, names=ilowpas.spindle,ilowpass.mpgX,ilowpas.mpgZ
addf ilowpass.spindle servo-thread
addf ilowpass.mpgX servo-thread
addf ilowpass.mpgZ servo-thread
# X MPG ilowpass
setp ilowpass.mpgX.scale 1000
setp ilowpass.mpgX.gain 0.01
net jog-0-counts => lowpass.mpgX.in
net ilowpass-0-out ilowpass.mpgX.out
net ilowpass-0-out => axis.0.jog-counts
Last edit: 25 Mar 2018 09:11 by rodw.
- tecno
25 Mar 2018 10:13 #107804
by tecno
Spindle = ilowpass = NO >>>>>>>>> lopass
Are these the same?
Are these the same?
25 Mar 2018 10:30 - 25 Mar 2018 10:32 #107805
Sorry, I got that wrong. If the names are different they are different components. It does not really matter, just starts a bit different.
loadrt ilowpass, count=2 , names=ilowpass.mpgX,ilowpass.mpgZ
Last edit: 25 Mar 2018 10:32 by rodw.
- Clive S
- Thank you received: 486
25 Mar 2018 11:31 #107806
by Clive S
Replied by Clive S on topic Time to setup my lathe with 7i76e
Rod I do appreciate this " This is why I much prefer this 2 line style in my hal " This has helped me no end it trying to understand hal llines of code.
- tecno
25 Mar 2018 11:47 #107807
by tecno
Happy camper over here
as I now got ilowpass working.
I agree to Clives comment and I have learned a lesson today.
1. loadrt is either count or names not both
Here my HAL that is now operational
Thanks Rod for your kind help.
25 Mar 2018 12:29 #107808
Glad you guys learnt something today. Bengt, I just included that error as a training exercise! I told you it wouldn't work first up!
What I learnt this weekend is how to log a series of probe readings to a file. Which in turn taught me that my gantry was out by about 1.6mm in height from one side to the other. Which in turn resulted in almost a day's work shimming the gantry under probe control to get it level!
- tecno
25 Mar 2018 12:32 #107810
by tecno
Yes you told me so
There is always things to do, glad you got you gantry properly leveled. It is nice to have good tools that helps.
- tecno
25 Apr 2018 10:47 #109587
by tecno
Need advise how to set spindel scaling.
I can manually set low speed to ~185rpm
In Axis F9 i need to press + button 3 times to get spindle starting.
M3 S300 is the lowest MDI command I can get spindle starting at ~185rpm
So giving M3 S185 will not start.
Where do I adjust to I get proper Sxxx ?
Cheers
Bengt
Cheers
Bengt
Time to create page: 0.156 seconds
