Time to setup my lathe with 7i76e
- Mike_Eitel
- Thank you received: 183
25 Feb 2018 12:08 #106483
by Mike_Eitel
Replied by Mike_Eitel on topic Time to setup my lathe with 7i76e
I include here my working mpg.hal.
Not active as still in development on my lab table, but proofen to run.
It is not yet clean, but sou might find some hints in it.
To know is that I have three switches (U use analog poti) who decide scaling.
Additional I have smoothing against incremental jumps, not yet tuned
They feed four mpg's for my XYZA
As I do not understand completely ;-( I feed the axis and the joints pins ..... At least it works.
Mike
axis
Mike
axis
- tecno
- Thank you received: 127
25 Feb 2018 12:14 #106484
by tecno
Replied by tecno on topic Time to setup my lathe with 7i76e
7i73 is not on my lathe, only 7i76e with 2 MPG
And yes data is coming in.
- tecno
25 Feb 2018 12:25 #106485
by tecno
Still No Go with sserial_port_0=2xxxx
- Mike_Eitel
25 Feb 2018 12:30 #106486
by Mike_Eitel
Dont care that my signals are coming from 7i73. You have already the pins.
Watch that i connect the
.scale from line 84
.count from line 97 on ( you should use here your encoders.count)
.enable from line 118
And as said before for the axis and the joints pins.
Maybe somebody more scilled can advise if that makes sense.
Mike
.scale from line 84
Mike
- tecno
25 Feb 2018 13:19 #106487
by tecno
Sorry but there is no joints so now it complains about that.
# Jog enable
you have
net jog-enable <= halui.machine.is-on
How do I do this as my halui is
net machine-is-on halui.machine.is-on
# Jog enable
you have
- Mike_Eitel
25 Feb 2018 13:30 #106488
by Mike_Eitel
Just for a test use your signal machine-is-on
Is something moving now
- tecno
25 Feb 2018 13:50 #106490
by tecno
# Jog enable
net jog-enable <= machine-is-on
Does not work >>>> No such signal
- Mike_Eitel
25 Feb 2018 14:36 #106491
by Mike_Eitel
net machine-is-on => joint.0.jog-enable axis.x.jog-enable
- tecno
25 Feb 2018 15:28 #106493
by tecno
I have it working now.
Copied Andys code from forum.linuxcnc.org/27-driver-boards/3302...athe?start=10#103244
Thank you guys for helping me out here = much appreciated!
- Mike_Eitel
25 Feb 2018 15:33 #106494
by Mike_Eitel
Love to read that
Have fun with your next steps.
Mike
Mike
Time to create page: 0.304 seconds
