Configuration 7i92m_7i76x1D
- aleksamc
- Thank you received: 67
09 Mar 2018 09:47 #107158
by aleksamc
Replied by aleksamc on topic Configuration 7i92m_7i76x1D
I took source from Frequency drive 0-10V. It should be constant.
I've measured
S900 - U12=0,9V, Power Source (Pin1-3)=10,44V
S800 - U12=8,91V, Power Source =10,44V(not changed)
I've measured
- Thank you received: 5337
09 Mar 2018 10:00 #107161
Replied by PCW on topic Configuration 7i92m_7i76x1D
Try setting the output scale to 1000 (its set to something crazy in the ini file)
The following user(s) said Thank You: aleksamc
- aleksamc
09 Mar 2018 10:16 #107163
by aleksamc
Works great with OutPUT_SCALE =1000. Thank you hundred times, Peter.
I wonder why it differs from OutPut_Scale from linuxcnc docs:
linuxcnc.org/docs/2.4/html/examples_spindle.html
There is wrong explanation.
09 Mar 2018 10:49 #107164
How the output is scaled depends on the output device
The PWM example is closer to the way the 7I76 (and all sserial devices) scale outputs
Pretty sure pncconf sets this up correctly, though it might name the scaling constant a little
differently for clarity (say Full_Scale_Output instead of Output_Scale)
- aleksamc
03 May 2018 04:51 #110103
by aleksamc
For a long time of work under this CNC machine, we have turned on electricity at it and and made wirst moves.
Now make configurations for machine.
Now I try to configure spindle and I've seen that spindle output of 7i76 depends of temperatre a lot.
When I configured it at first time, it was 9 of March, and it was cold, It gave me 10V, but now, when it's hot, at 100% it gives me only 80%.
MAX_OUTPUT = 4000
OUTPUT_SCALE = 4000
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 4000
May be I'm wrong, because I has some error mstakes when I start machine and turn on linuxcnc:
hm2/hm2_7i92.0: smart serial card
hm2_7i92.0.7i76.0.0 remote error = (27) Over current
hm2_7i92.0.7i76.0.0 remote error = (8) remote fault
But all axes work fine, everything OK.
Does it could be solver of this problems?
MAX_OUTPUT = 4000
OUTPUT_SCALE = 4000
03 May 2018 09:28 #110115
The output PWM circuit should be quite stable (it should drift no more than a fraction of a percent over 0 to 70C temperature)
I would check that the input voltage is not changing
Did the sserial errors start at the same time? the over current error may indicate an external short or a damaged output driver chip
- aleksamc
03 May 2018 11:39 #110127
by aleksamc
Over current temperature error few times was blinking. After some time and restart, I don't see it any more. Also, I've inverted output GPIO outputs if step signals.
I will check input voltage but I think it's OK.
Max voltage from resistor is still 8V.
03 May 2018 12:38 - 03 May 2018 12:44 #110131
So if the supply is 10V and you get 8V out (and you have full scale in hal)
Then there is a hardware problem (damaged OP-AMP etc)
The PWM circuit is pretty simple OPTO --> CMOS gate --> passive RC filter --> rail-rail opamp
It typically has better that 1% linearity and should only have a few millivolt shift with temperature.
Last edit: 03 May 2018 12:44 by PCW.
- aleksamc
07 May 2018 08:09 #110324
by aleksamc
Thanks, Peter for that. I've checked output voltage.
I use voltage from Freequency converter and it's 10.4V. But at output maximum is only 8V. If it's problem with CMOS gate, it's good enough. I made settings on freequency converter to linerize input voltage to output freaquency.
But if it's a problem of ambient temperature, I will have big problems with changing weather and seasons.
07 May 2018 08:15 #110325
That most likely means that the output circuit has been likely been damaged somehow and
will not be predictable until repaired
Time to create page: 1.644 seconds
