Re:pncconf - feature requests
24 Feb 2019 16:39 #127060 by pl7i92
Replied by pl7i92 on topic pncconf - feature requests
Thank You very Mutch
it is always a Good idee to Mark Images on the image if they show Some Pinouts
02 Sep 2020 07:39 #180403 by shadab
Replied by shadab on topic pncconf - feature requests
Is there any news on when 7i97 will be supported for the 7i97?
02 Sep 2020 13:28 #180430 by JohnnyCNC
Replied by JohnnyCNC on topic pncconf - feature requests
Chris,
What app are you using to draw that board? I need to document the wiring of my machine and I don't have a tool that makes it easy to draw a simple diagram.
07 Sep 2020 03:44 #181086 by cmorley
Replied by cmorley on topic pncconf - feature requests
It's not on my radar currently, but if someone could post the output from mesaflash for it's pins and sserial that might motivate me.
Chris
07 Sep 2020 03:47 #181088 by cmorley
Chris,
IIRC, I didn't draw it I colored it and changed some labels.
I might of taken a different card's image and edited it.
I use GIMP, which is not friendly if you only use it once in a while.
Chris
07 Sep 2020 14:47 #181155 by JohnnyCNC
Thanks, I've used Eagle CAD but that is way to complicated for doing a simple wiring diagram and MS Paint is way too primitive. I guess I have some Googling to do.
09 Sep 2020 07:12 #181381 by shadab
Chris
Hi Chris,
We are working with 7i97 to retrofit a HURCO Hawk 30 as discussed in this forum post and might be able to help you get the data you need. Let us know what data you need and we will send it to you.
Shadab
09 Sep 2020 07:17 #181385 by cmorley
looking for the output from these commands (address might be different for yours)
mesaflash --device 7i97 --addr 192.168.1.121
mesaflash --device 7i97 --addr 192.168.1.121 --sserial
mesaflash --device 7i97 --addr 192.168.1.121 --readhmid
23 Nov 2020 10:53 - 23 Nov 2020 10:59 #190105 by shadab
Hi Chris,
The reponses from mesaflash for the following commands:
mesaflash --device 7i97 --addr 10.10.10.10
ETH device 7I97 at ip=10.10.10.10
mesaflash --device 7i97 --addr 10.10.10.10 --sserial
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 1
SSLBP Baud Rate: 2500000
I have attached the output of -readhmid command below:
File Name: readhmid.txt
File Size:6 KB
Thanks,
Shadab
Last edit: 23 Nov 2020 10:59 by shadab. Reason: Formatting didn't come out correctly for --readhmid comand, adding a text file with that output.
06 Feb 2022 00:05 - 06 Feb 2022 00:06 #234062 by smc.collins
Replied by smc.collins on topic Re:pncconf - feature requests
Renumber PNC conf inputs and outputs to match screen masking on the cards the drivers support. this off by one thing is kind weird, it also create a room for more errors. The screen masking of the Board should match the numbering of the driver IO etc. Remember, NASA lost a mars mission of a converison error.
Last edit: 06 Feb 2022 00:06 by smc.collins.
Time to create page: 0.726 seconds
