Lathe Macros
3 years 11 months ago #257128 by hitchhiker
Replied by hitchhiker on topic Lathe Macros
yes but my biggest question is... when i want to use a macro i must manual load the ngc file... is there a way to load the correct ngc file automatic?! thanks
3 years 11 months ago #257384 by andypugh
Replied by andypugh on topic Lathe Macros
You shouldn't need to load the ngc file, that would be terribly inconvenient.
Where have you put the .ngc files? Are they included in your SUBROUTINE_PATH ?
3 years 11 months ago #257388 by hitchhiker
i think the problem is thst i use nativecam and lathe macros... could this be a problem?? on linuxcnc 2.8...?! lathemacros version 1...
3 years 11 months ago #257392 by andypugh
That shouldn't be a problem.
Are you saying that you have to (for example) load "turning.ngc" before the "turning" tab will work?
If so, that points to turning.ngc not being in the search path. So, where did you put the .ngc files and what is yout SUBROUTINE_PATH in the INI file?
The following user(s) said Thank You: Masiwood123
3 years 11 months ago #257396 by hitchhiker
i will check it tomorrow and send screenshots!
in the last days i come to the end with wiring my 6i25 to my lathe.. now i testing with cuts in the air...
tomorrow i make screenshots... do you know if the fusion 360 lathe pp works out of the box???
thanks
3 years 11 months ago #257403 by andypugh
I think I modified the lathe PP from Fusion. This is straight from my machine.
Time to create page: 0.381 seconds
