Lathe Macros
3 years 7 months ago #266146 by O.R
Replied by O.R on topic Lathe Macros
I use Axis GUI. I tried add that line 37 and files, but no cycles tab.
3 years 7 months ago #266148 by andypugh
Replied by andypugh on topic Lathe Macros
If you start LinuxCNC from the command-line (command "linuxcnc") then you might be given a clue what is going wrong.
3 years 7 months ago #266229 by O.R
That command opened configuration selector where i can see my current lathe configuration and also lathe_macros. If I select lathe_macros,
Terminal shows:
"can't load tool table"
"cannot find file for: core_sim_lathe.hal"
Debug file shows:
Stopping realtime threads
Unloading hal components
3 years 7 months ago - 3 years 7 months ago #266232 by andypugh
That probably means that you need to add the path of the INI to the subroutine path.
In the INI file find SUBROUTINE_PATH and add
to the end. The path is a list of colon-delimited entries, and . means "current directory" so :. means "and also this directory"
(It also says that you have no tool table in that config, but that's a separate issue)
Last edit: 3 years 7 months ago by andypugh.
3 years 7 months ago #266313 by O.R
Ok I tried like this:
SUBROUTINE_PATH = macros:./home/sorvi/Desktop/Lathe/Lathe.ini:.
or
SUBROUTINE_PATH = /home/sorvi/Desktop/Lathe/Lathe.ini:.
but I get still same errors than previously.
I don't have any clue what i'm doing. Are these macros kind of add on to my original Lathe configuration or is it not related to the original at all. Should i have to for example make joint settings similarly to the "lathe_macro.ini" file, like i have done in my "Lathe.ini" file originaly.
3 years 7 months ago #266316 by andypugh
The macros are an add-on.
Start with a working lathe config that controls your lathe adequately, then add the macros as a tab in the GUI.
Time to create page: 0.081 seconds
