Lathe Macros
3 years 7 months ago #266507 by O.R
Replied by O.R on topic Lathe Macros
I'm using buster, I have glade V3.22.1-4 and glade-gtk2 3.8.6-1. I tried V2 macros and now i can see cycles tab, but text boxes are bit too small and i don't have that same "play button". I tried higher resolution but that did not fixed it.
Could this be related to the problem:
(gladevcp:1576): gtk-xfce-engine-CRITICAL **: 20:29:19.272: draw_box_gap: assertion 'height >= -1' failed task: main loop took 0.104370 seconds
3 years 7 months ago #266515 by andypugh
Replied by andypugh on topic Lathe Macros
The option to show or hide the "Play" button from the command-line isn't in that version. There is a HAL pin to connect to a physical button (which is how I use it) but as far as I can see the button should be visible in the downloaded version of the files (possibly not for face and radius, though...)
If you run the sample gmoccapy config from the LinuxCNC config picker (sim-gmoccapy-lathe-lathe-macros) do you see the Play button?
3 years 7 months ago #266603 by O.R
I did not find where Cycles tab are in gmoccapy. Can you show example how to connect physical button to macro cycles start or how to make it work with Axis original play button.
3 years 7 months ago #266612 by andypugh
It just appears at the top of the preview window for me
And the macros have the play button:
3 years 7 months ago #266689 by O.R
I like to use Axis instead that gmoccapy GUI, so i need help how to start macro cycles when I use Axis GUI. I do not even have that preview tab when i try gmoccapy.
3 years 7 months ago #266691 by andypugh
Do you have a preview tab in Axis? This might be pointing at a more deep-seated issue.
If you open the lathemacro.ui file in the Glade editor, can you see the play buttons? Are they set to "visible" in their properties?
Time to create page: 0.363 seconds
