Lathe Macros
3 years 7 months ago #266336 by O.R
Replied by O.R on topic Lathe Macros
Ok, i have all ready working configuration for lathe. I added macro files to my working lathe configuration folder which is on my desktop. Then i added that "EMBED_TAB_NAME = Cycles" line to my working lathe.ini file about same spot. After that i tried add that SUBROUTINE_PATH . If I start my working lathe configuration (desktop shortcut) i can not see any Cycles tab and i do not get any errors. What i should do next?
3 years 7 months ago #266338 by andypugh
Replied by andypugh on topic Lathe Macros
Which GUI are you using?
There is a wierd Gmoccapy bug where the tabs all hide at first...
3 years 7 months ago #266340 by O.R
I use Axis GUI
3 years 7 months ago #266342 by andypugh
Are there really no messages printed if you launch from the command line?
3 years 7 months ago #266392 by O.R
ok, i now noticed that there is message "invalid tab configuration" when I start my working lathe configuration. I tested that if I remove "EMBED_TAB_NAME = Cycles" command, then message disappears. I'm using linuxcnc version 2.8.4.
3 years 7 months ago #266401 by cmorley
Replied by cmorley on topic Lathe Macros
please post your INI file.
This explains a but:
linuxcnc.org/docs/2.9/html/gui/gladevcp....adevcp:embedding-tab
Time to create page: 0.355 seconds
