Lathe Macros
3 years 11 months ago #257432 by hitchhiker
Replied by hitchhiker on topic Lathe Macros
ok!i have a old emco compact 5 cnc with turret... i look to the fusion website and found the lstest postprocessor was modified arround 40 days ago.
tonight i will check something.. then i make the screenshots...
the way away from mach3 is nomore far ;)
thanks
3 years 9 months ago #260782 by Muzzer
Replied by Muzzer on topic Lathe Macros
Just had another go at updating gmoccapy using the V3.0 files, by pasting the EMBED_TAB_COMMAND line into the HAL file and overwriting the ngc files. I still get the same result:
  • No obvious means of generating or running the resulting g code.
  • If I click on a scroll box before closing a previous (different) one, the keypad gets lost behind the main window somewhere. I can find it again by using alt-tab to switch windows.
    Can anyone see the obvious mistake(s)? I've attached my INI file and a screenshot
    File Name: gmoccapy_lathe.ini
    File Size:8.21 KB
3 years 9 months ago #260784 by andypugh
Replied by andypugh on topic Lathe Macros
Which LinuxCNC version and OS?
It looks like the last-bu-one version of the macros? I have forgotten what it takes to get the run button to show.
3 years 9 months ago - 3 years 9 months ago #260793 by Muzzer
I'm using Mint 20 and 2.8. I downloaded V3 from your github today.
Last edit: 3 years 9 months ago by Muzzer.
3 years 9 months ago #260912 by virencq
Replied by virencq on topic Lathe Macros
I am using Lathe macro version 1.
From the picture attached 1 represents threading macro external and internal. Dia 18.5 mm and pitch 2 mm.
Picture 2 represents OD-g76.ngc tool path, it also has same 18.5 mm dia, 2 mm pitch.
both versions have huge differences in depth, what I
File Name: OD-g76.ngc
File Size:296 B
File Name: threading.ngc
File Size:1003 B
am doing wrong...........
3 years 9 months ago #261248 by Henk
Replied by Henk on topic Lathe Macros
HI
I can seem to get past this error when setting up lathe macros on my lathe.
I copied all the files from V2.0 into the same dir as my .ini file. Edited the ini file, added lines
EMBED_TAB_NAME=Cycles
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u lathehandler.py -x {XID} -g 300x200+0+0 lathemacro.ui
and i get this error when starting from terminal
Glade is installed and gladevcp widgets can be seen in glade. version is 3.8.6
Any idea what im doing wrong?
linuxcnc@linuxcnc:~/linuxcnc/configs/CTX400E with macros$ halcmd sets spindle-engage 0 <commandline>:0: signal 'spindle-engage' not found linuxcnc@linuxcnc:~/linuxcnc/configs/CTX400E with macros$ linuxcnc CTX400E.ini LINUXCNC - 2.8.3 /usr/bin/linuxcnc: line 290: cd: $'/home/linuxcnc/linuxcnc/configs\n.\nmacros': No such file or directory Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/CTX400E with macros' Machine configuration file is 'CTX400E.ini' Starting LinuxCNC... Found file(REL): ./CTX400E.hal Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:10:00:51 hm2_eth: discovered 7I80DB-16 hm2/hm2_7i80.0: Low Level init 0.15 hm2/hm2_7i80.0: Smart Serial Firmware Version 43 Board hm2_7i80.0.7i77.0.0 Hardware Mode 0 = standard Board hm2_7i80.0.7i77.0.0 Software Mode 0 = input_output Board hm2_7i80.0.7i77.0.0 Software Mode 1 = io_analog Board hm2_7i80.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage Board hm2_7i80.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage Board hm2_7i80.0.7i77.0.1 Hardware Mode 0 = standard Board hm2_7i80.0.7i77.0.1 Software Mode 0 = analogout_enables Board hm2_7i80.0.7i71.0.2 Hardware Mode 0 = standard Board hm2_7i80.0.7i71.0.2 Software Mode 0 = output_only Board hm2_7i80.0.7i71.0.2 Software Mode 1 = output_fieldvoltage Waiting for component 'hm2_eth' to become ready...hm2/hm2_7i80.0: Smart Serial Firmware Version 43 .Board hm2_7i80.0.7i70.1.0 Hardware Mode 0 = standard Board hm2_7i80.0.7i70.1.0 Software Mode 0 = input_only Board hm2_7i80.0.7i70.1.0 Software Mode 1 = input_analog .Board hm2_7i80.0.7i70.1.0 Software Mode 2 = input_fieldvoltage ....hm2/hm2_7i80.0: 68 I/O Pins used: hm2/hm2_7i80.0:     IO Pin 000 (J2-01): Smart Serial Interface #0, pin txen2 (Output) hm2/hm2_7i80.0:     IO Pin 001 (J2-14): Smart Serial Interface #0, pin tx2 (Output) hm2/hm2_7i80.0:     IO Pin 002 (J2-02): Smart Serial Interface #0, pin rx2 (Input) hm2/hm2_7i80.0:     IO Pin 003 (J2-15): Smart Serial Interface #0, pin tx1 (Output) hm2/hm2_7i80.0:     IO Pin 004 (J2-03): Smart Serial Interface #0, pin rx1 (Input) hm2/hm2_7i80.0:     IO Pin 005 (J2-16): Smart Serial Interface #0, pin tx0 (Output) hm2/hm2_7i80.0:     IO Pin 006 (J2-04): Smart Serial Interface #0, pin rx0 (Input) hm2/hm2_7i80.0:     IO Pin 007 (J2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) hm2/hm2_7i80.0:     IO Pin 008 (J2-05): Muxed Encoder #0, pin Muxed A (Input) hm2/hm2_7i80.0:     IO Pin 009 (J2-06): Muxed Encoder #0, pin Muxed B (Input) hm2/hm2_7i80.0:     IO Pin 010 (J2-07): Muxed Encoder #0, pin Muxed Index (Input) hm2/hm2_7i80.0:     IO Pin 011 (J2-08): Muxed Encoder #1, pin Muxed A (Input) hm2/hm2_7i80.0:     IO Pin 012 (J2-09): Muxed Encoder #1, pin Muxed B (Input) hm2/hm2_7i80.0:     IO Pin 013 (J2-10): Muxed Encoder #1, pin Muxed Index (Input) hm2/hm2_7i80.0:     IO Pin 014 (J2-11): Muxed Encoder #2, pin Muxed A (Input) hm2/hm2_7i80.0:     IO Pin 015 (J2-12): Muxed Encoder #2, pin Muxed B (Input) hm2/hm2_7i80.0:     IO Pin 016 (J2-13): Muxed Encoder #2, pin Muxed Index (Input) hm2/hm2_7i80.0:     IO Pin 017 (J3-01): IOPort hm2/hm2_7i80.0:     IO Pin 018 (J3-14): IOPort hm2/hm2_7i80.0:     IO Pin 019 (J3-02): IOPort hm2/hm2_7i80.0:     IO Pin 020 (J3-15): IOPort hm2/hm2_7i80.0:     IO Pin 021 (J3-03): IOPort hm2/hm2_7i80.0:     IO Pin 022 (J3-16): IOPort hm2/hm2_7i80.0:     IO Pin 023 (J3-04): IOPort hm2/hm2_7i80.0:     IO Pin 024 (J3-17): IOPort hm2/hm2_7i80.0:     IO Pin 025 (J3-05): IOPort hm2/hm2_7i80.0:     IO Pin 026 (J3-06): IOPort hm2/hm2_7i80.0:     IO Pin 027 (J3-07): Muxed Encoder Select #6, pin Mux Select 0 (Output) hm2/hm2_7i80.0:     IO Pin 028 (J3-08): Muxed Encoder #3, pin Muxed A (Input) hm2/hm2_7i80.0:     IO Pin 029 (J3-09): Muxed Encoder #3, pin Muxed B (Input) hm2/hm2_7i80.0:     IO Pin 030 (J3-10): Muxed Encoder #3, pin Muxed Index (Input) hm2/hm2_7i80.0:     IO Pin 031 (J3-11): Muxed Encoder #4, pin Muxed A (Input) hm2/hm2_7i80.0:     IO Pin 032 (J3-12): Muxed Encoder #4, pin Muxed B (Input) hm2/hm2_7i80.0:     IO Pin 033 (J3-13): Muxed Encoder #4, pin Muxed Index (Input) hm2/hm2_7i80.0:     IO Pin 034 (J4-01): StepGen #0, pin Direction (Output) hm2/hm2_7i80.0:     IO Pin 035 (J4-14): StepGen #0, pin Step (Output) hm2/hm2_7i80.0:     IO Pin 036 (J4-02): StepGen #1, pin Direction (Output) hm2/hm2_7i80.0:     IO Pin 037 (J4-15): StepGen #1, pin Step (Output) hm2/hm2_7i80.0:     IO Pin 038 (J4-03): StepGen #2, pin Direction (Output) hm2/hm2_7i80.0:     IO Pin 039 (J4-16): StepGen #2, pin Step (Output) hm2/hm2_7i80.0:     IO Pin 040 (J4-04): StepGen #3, pin Direction (Output) hm2/hm2_7i80.0:     IO Pin 041 (J4-17): StepGen #3, pin Step (Output) hm2/hm2_7i80.0:     IO Pin 042 (J4-05): IOPort hm2/hm2_7i80.0:     IO Pin 043 (J4-06): IOPort hm2/hm2_7i80.0:     IO Pin 044 (J4-07): IOPort hm2/hm2_7i80.0:     IO Pin 045 (J4-08): Smart Serial Interface #1, pin tx0 (Output) hm2/hm2_7i80.0:     IO Pin 046 (J4-09): Smart Serial Interface #1, pin txen0 (Output) hm2/hm2_7i80.0:     IO Pin 047 (J4-10): Smart Serial Interface #1, pin rx0 (Input) hm2/hm2_7i80.0:     IO Pin 048 (J4-11): Muxed Encoder #5, pin Muxed Index (Input) hm2/hm2_7i80.0:     IO Pin 049 (J4-12): Muxed Encoder #5, pin Muxed B (Input) hm2/hm2_7i80.0:     IO Pin 050 (J4-13): Muxed Encoder #5, pin Muxed A (Input) hm2/hm2_7i80.0:     IO Pin 051 (J5-01): IOPort hm2/hm2_7i80.0:     IO Pin 052 (J5-14): IOPort hm2/hm2_7i80.0:     IO Pin 053 (J5-02): IOPort hm2/hm2_7i80.0:     IO Pin 054 (J5-15): IOPort hm2/hm2_7i80.0:     IO Pin 055 (J5-03): IOPort hm2/hm2_7i80.0:     IO Pin 056 (J5-16): IOPort hm2/hm2_7i80.0:     IO Pin 057 (J5-04): IOPort hm2/hm2_7i80.0:     IO Pin 058 (J5-17): IOPort hm2/hm2_7i80.0:     IO Pin 059 (J5-05): IOPort hm2/hm2_7i80.0:     IO Pin 060 (J5-06): IOPort hm2/hm2_7i80.0:     IO Pin 061 (J5-07): IOPort hm2/hm2_7i80.0:     IO Pin 062 (J5-08): IOPort hm2/hm2_7i80.0:     IO Pin 063 (J5-09): IOPort hm2/hm2_7i80.0:     IO Pin 064 (J5-10): IOPort hm2/hm2_7i80.0:     IO Pin 065 (J5-11): IOPort hm2/hm2_7i80.0:     IO Pin 066 (J5-12): IOPort hm2/hm2_7i80.0:     IO Pin 067 (J5-13): IOPort hm2/hm2_7i80.0: registered creating ladder-state Found file(REL): ./custom.hal INFO CLASSICLADDER-   No ladder GUI requested-Realtime runs till HAL closes. Found file(REL): ./atc-spindle2.hal Found file(REL): ./c0-spindle-vel.hal Found file(REL): ./c1-spindle-vel.hal Found file(REL): ./hydraulics-and-io.hal Found file(REL): ./CTX400E-panel.hal note: MAXV     max: 167.000 units/sec 10020.000 units/min note: LJOG     max: 167.000 units/sec 10020.000 units/min note: LJOG default: 100.000 units/sec 6000.000 units/min note: AJOG     max: 180.000 units/sec 10800.000 units/min note: AJOG default: 50.000 units/sec 3000.000 units/min waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> interp __init__ 1 7011 note: jog_order='ZXCW' note: jog_invert=set([]) interp __init__ 0 7014 /usr/bin/gladevcp:191: GtkWarning: Attempting to add a widget with type GtkImage to a GtkButton, but as a GtkBin subclass a GtkButton can only contain one widget at a time; it already contains a widget of type GtkLabel   builder.add_from_file(xmlname) HAL: ERROR: insufficient memory for pin 'gladevcp.chamfer.sf-f' Traceback (most recent call last):   File "/usr/bin/gladevcp", line 347, in <module>     main()   File "/usr/bin/gladevcp", line 213, in main     panel = gladevcp.makepins.GladePanel( halcomp, xmlname, builder, None)   File "/usr/lib/python2.7/dist-packages/gladevcp/makepins.py", line 52, in __init__     widget.hal_init(self.hal, idname, self)   File "/usr/lib/python2.7/dist-packages/gladevcp/hal_widgets.py", line 28, in hal_init     self._hal_init()   File "/usr/lib/python2.7/dist-packages/gladevcp/hal_widgets.py", line 219, in _hal_init     self.hal_pin_f = self.hal.newpin(self.hal_name+"-f", hal.HAL_FLOAT, hal.HAL_OUT)   File "/usr/lib/python2.7/dist-packages/hal_glib.py", line 72, in newpin     def newpin(self, *a, **kw): return GPin(_hal.component.newpin(self.comp, *a, **kw)) hal.error: Cannot allocate memory <commandline>:0: waitpid failed gladevcp gladevcp <commandline>:0: gladevcp exited without becoming ready Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u lathehandler.py -x 48234924 -g 300x200+0+0 lathemacro.ui" exited with error: 1 Shutting down and cleaning up LinuxCNC... Running HAL shutdown script task: 106 cycles, min=0.000037, max=0.037753, avg=0.007759, 0 latency excursions (> 10x expected cycle time of 0.010000s) interp __delete__ 1 7011 hm2_eth: in hm2_eth_reset hm2_eth: HostMot2 ethernet driver unloaded hm2: unloading Note: Using POSIX realtime LinuxCNC terminated with an error.  You can find more information in the log:     /home/linuxcnc/linuxcnc_debug.txt and     /home/linuxcnc/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal linuxcnc@linuxcnc:~/linuxcnc/configs/CTX400E with macros$
Time to create page: 0.129 seconds
