LINUXCNC - 2.8.4-1-gb7824717b
Machine configuration directory is '/home/sorvi/linuxcnc/configs/Lathe'
Machine configuration file is 'Lathe.ini'
Starting LinuxCNC...
Found file(REL): ./Lathe.hal
Waiting for component 'trivkins' to become ready.....Waited 3 seconds for master. giving up.
...............Note: Using POSIX realtime
config string '0 out'
Found file(REL): ./custom.hal
note: MAXV max: 20.000 units/sec 1200.000 units/min
note: LJOG max: 20.000 units/sec 1200.000 units/min
note: LJOG default: 2.000 units/sec 120.000 units/min
note: jog_order='ZX'
note: jog_invert=set(['X'])
Waiting for component 'lathemacro' to become ready..............................
(gladevcp:1978): libglade-WARNING **: 15:41:38.559: Expected <glade-interface>. Got <interface>.
(gladevcp:1978): libglade-WARNING **: 15:41:38.570: did not finish in PARSER_FINISH state
**** GLADE VCP ERROR: With xml file: lathemacro.ui : could not create GladeXML object
<commandline>:0: gladevcp exited without becoming ready
Embeded tab command "halcmd loadusr -Wn lathemacro gladevcp -c lathemacro -U notouch=1 -U norun=0 -u lathehandler.py -x 331350450 lathemacro.ui" exited with error: 1
task: 1428 cycles, min=0.000573, max=0.071143, avg=0.010143, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/sorvi/linuxcnc_debug.txt
and
/home/sorvi/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
