QT C++ code samples
6 years 4 months ago #172756 by tommylight
Replied by tommylight on topic QT C++ code samples
Grotius wrote: .....After all, it's quite complicated stuff !
It sure is, but you are very good at it.
Regards,
Tom.
6 years 4 months ago #172762 by Patrik T
Replied by Patrik T on topic QT C++ code samples
I peeked at some of the code. I like the straight forwardness of the coding style. Hope you don't mind a few suggestions. I am not pointing out errors, all these examples work fine as is, which you obviously know already.
1) I noticed this in a few places:
double y = radius * sinf(angle_start);
Why use sinf() when y, radius and angle_start are all doubles?
2) What are you trying to do here, with the function style int cast?
double theta = 2.0 * M_PI * int(j) / int(segments);
j and segments are already int and will be promoted to doubles anyway.
3) I noticed in display.h that you change the loop variable every loop. No harm but it is not necessary.
4) Have you considered using an enum for OBJECT::type, instead of a string?
5) std::vector::reserve() is a good idea here:
std::vector<std::vector<double>> C; //2d array C.reserve(object.control.size() + 2); // This is a good idea here. C.push_back({object.start.x, object.start.y}); //spline startpoint for(int i=0; i<object.control.size(); i++){ C.push_back({object.control.at(i).x, object.control.at(i).y}); //spline controlpoints } C.push_back({object.end.x, object.end.y}); //spline endpoint draw_spline(C);
I saw the pocket milling pattern, that looks advanced. Nice work all around.
6 years 4 months ago #172794 by rodw
Replied by rodw on topic QT C++ code samples
Grotius wrote: Hi,
Updates
A big issue was the spline function. I used a Cubic bezier curve as spline. This was not good. Bezier curve's have startpoints cq endpoints that can not be used by dxf files. So i had to look for a Cubic spline like this : mathworld.wolfram.com/CubicSpline.html
The math was to heavy for me to solve. I did not find any plug an play solution that are dealing with a cubic spline in relation to elapsed time. But attached a minimal c++ QT project that does a cubic spline. A nice hollander helped me a lot !!
www.wiskundeforum.nl/viewtopic.php?f=37&t=12717
I have been doing some work in /src/emc/rs274ngc the folder. Now my copy of Linuxcnc knows the radius of any arcs and also the heading at any G1, G2, G3 move that could be used to orient a tangential knife and a few other things.
I don't think a new gcode would be hard to add.
I'd have to check while in front of a Linuxcnc box but gcodes are defined in interp_internal.h. So add your new code trhere. Gcodes are parsed andthen "converted" to tokenised motion segments in interp_convert.cc which inturn calls interp_arc.cc and a couple of others. So you'd need to work your way through the parsing code and create a new convert procedure to convert your spline.
Feel free to email me off forum and I'll try and explore this a bit further for you. All I Will say is that grep is your friend when you venture in to this code!
6 years 4 months ago - 6 years 4 months ago #172819 by Grotius
Replied by Grotius on topic QT C++ code samples
@Hi Tom,
Thank you for compliment ! Step by step we go to finish the program.
@Hi Patrik,
Thank you.
That's correct. The sinf() to be changed to sind().
That's correct. It's quite a old piece of the code. I remember a problem with arc's that missed a short end piece.
Then i tried several things to solve it. It has to be corrected.
No, but i tried it today. I miss some knowlegde to get it right. After one hour i stopped it,
because i was working on splitting up arc's between intersection points.
I you have a example, that would be nice.
Something like this would be perfect : it->type.line; or it->type.line=true;
But then all others must be off.
I use this sometime : it->type==""; For enum, we can choose a dummy name.
An sich it is oke for me. If they are used.
But one thing to mention is :
When we reserve 2 empty controlpoints and they stay that way. Their both coordinates are 0,0,0. That coordinates are used in the eara calculation of the depth calculation. That calculation will not be correct.
So that's one thing to remember.
It's a picture seen on the internet. The c++ header is available. But it can handle no splines, bezier, ellipse etc.
And i don't understand the readme file how to use the class for pocket offsetting.
@Hi Rod,
I agree.
My idea is to make a linuxcnc copy, and edit the nurb class. Ivestegate some more code and see what happens.
After it works, writing it as a clean piece of code in new class. I am fan of header only.
Thank you for your work ! At the moment i need all the time for coding the Cadcam software.
After that the plan is to dig into the linuxcnc code.
Perfect ! Making a tangential mode nice !
I am also interested in something i have never googled before, but where i think about often, i call it "true spline".
For me it's a very interesting fenomen. It's a spline that is the same in two directions. (played from left to right en visa versa)
It could be easely be realised to combine 2 spline algoritmes and take the difference as output.
Another interesting thing for linuxcnc is a c++ interface with full control. Or a c++ interface that has full control via component.
Yesterday i read on this forum that someone has bought a tiny machine with usb interface.
Why don't write some code that usb can be used for linuxcnc. If it works, it has not to be top speed always.
I thought about adding a usb mode to the stepgen file, adding a baud rate and another few things would make this work.
Okey have a nice day !
Last edit: 6 years 4 months ago by Grotius.
6 years 4 months ago #172833 by Patrik T
#include <iostream> enum Type { // Use "enum Class Type" to avoid warning 26812. empty, line, circle, arc, }; struct Object { Type type{ empty }; }; void Print_Shape(Object* object) { switch (object->type) { case empty: std::cout << "Type is empty.\n\n"; break; case line: std::cout << "Type is line.\n\n"; break; case circle: std::cout << "Type is circle.\n\n"; break; case arc: std::cout << "Type is arc.\n\n"; break; default: std::cout << "Type is unknown.\n\n"; break; } } int main(int argc, char** argv) { Object object_1; Print_Shape(&object_1); object_1.type = circle; Print_Shape(&object_1); Object line_object{ line }; Print_Shape(&line_object); Object object_2{ object_1 }; Print_Shape(&object_2); Object object_3{ (Type)5 }; Print_Shape(&object_3); if (line_object.type != empty) std::cout << "Type is not empty.\n\n"; return 0; }
And I think you are mixing up vector::reserve() with vector::resize().
The following user(s) said Thank You: tommylight, Grotius
6 years 4 months ago - 6 years 4 months ago #173014 by Grotius
Thank you Patrik for the code sample. Yes i mixed them up, excuse for that.
This is interesting for me:
Object* object (i guess a pointer)
&object_1 (I guess by reference)
Today i tested some more with the pocket algoritme. To keep it simple i started with lines only. There was much work to do to get
it like the preview. There where some offset difficulties when value's became Nan. Some intersection problems that had to be solved.
A whole list of difficulties to get trhough.
This contour preview is based on a contour offset from farest outside to offset distance.
Next step is do a repeated offset from old offset to new offset and then stop offsetting at some point.
For today i am satisfied. :laugh:
Here you can see how the algortime works at offset distance -12mm
The purple lines are area's with positve area, these will be removed. It is showing how the algoritme works behind the screen.
At offset -21mm, there is almost no positive area left (positive area is color green)
Time to create page: 0.895 seconds
