QT C++ code samples
6 years 3 months ago - 6 years 3 months ago #175746 by Grotius
Replied by Grotius on topic QT C++ code samples
Short project update.
The program has now :
- Tools, set up tools like milling, drilling, plasma-laser and oxyfuel.
- Heads, set up your heads for Z, A, etc. with xy offsets.
- Operations, pockets (with or without islands), outside offset, no offset, inside offset, drill hole.
- Jobs, create a job list, select a cad layer and do a operation. Cad layers are highlited when selecting the layer in the combobox.
- All program settings are saved in textfiles for next startup.
Result :
Nesting has improved.
- automatic add's new plate when previous plate is full.
Nesting result :
I have to say, nesting can be improved in the future. For now it's okey.
The pocket milling has the toolradius offset for first offset. Then for next offsets, you can select an overlap input
from 0 to 1 for pockets. You can spot the overlap result in the first picture.
If you do the hole drill operation. It will only drill the hole if the hole is equel or bigger then the tool. You can see the holes as blue circulair outputs in the first picture.
Next thing to do is add the lead in and lead outs into the program.
Have a nice day !
Last edit: 6 years 3 months ago by Grotius.
The following user(s) said Thank You: phillc54, tommylight
6 years 3 months ago #175771 by tommylight
Replied by tommylight on topic QT C++ code samples
Very nice, indeed ! :)
6 years 3 months ago - 6 years 3 months ago #175961 by Grotius
Thank you Tom !
The programming goes fast now !!
Today programmed the most of the c++ gcode into the program.
Tested contours and pockets okey so far.
Added :
- gcode linenumbers (N) on or off
- gcode user defined decimal precision output
- m code character choice for delay,
- made pre-settings for filepath's and file extensions.
- all can be saved for next startup.
Todo :
- write c++ gcode for drill operations, including drill retract option.
- use dijkstra's shortest path algorime to use the cnc more efficient.
The result :
Every day we are closer to the release date. :blink:
Soon will provide a pre-release to use for cam. Integrating the Cad stuff again takes some more time.
The following user(s) said Thank You: phillc54, tommylight, Clive S
6 years 3 months ago #175970 by tommylight
Isle of man, TT ! :)
To old for that now, have not driven any of my bikes over 96KMH in last ..... 20 years ! :blush:
Still to scared of them since i had a mild crash 33 years ago, nothing broken just some bruises and scratches, but the fear remained.
6 years 3 months ago #175974 by Grotius
Same for me. Crashed hard on my right knee in my younger years. Never bought a motorcylce again, just to stay safe !
But isle of man is stil on my bucket list !
6 years 1 month ago #182839 by billykid
Replied by billykid on topic QT C++ code samples
i am never crashed, so i can go faster :-)
Time to create page: 3.365 seconds
