Work with probe
10 years 7 months ago #72001 by gizmo6023
Replied by gizmo6023 on topic Installing Work with probe
verser wrote:
gizmo6023 wrote: Pressing probe down generates no move and Error: Unable to open file <down>
Please show me the look of a full path to the down.ngc on your computer.
Here is a screen capture showing the location of the down.ngc
If I am reading this file structure properly it is Home/dave/linuxcnc/configs/ShopFoxMill/subroutines
Second screen shot shows errors produced for pressing Y- X- Y+ X+ all produced a move of the head toward the table then an error.
Pressing probe down produces error with no head movement. Pressing cylinder produced head down table left moves then error.
10 years 7 months ago #72003 by gizmo6023
I am not sure if this error is connected to the unable to open file down.ngc error but it only happens with the modified .ini for work with probe.
10 years 7 months ago #72004 by verser
Replied by verser on topic Installing Work with probe
gizmo6023 wrote: Here is a screen capture showing the location of the down.ngc
so you need to fix .ini
SUBROUTINE_PATH = subroutines
The following user(s) said Thank You: gizmo6023
10 years 7 months ago #72006 by cncbasher
Replied by cncbasher on topic Installing Work with probe
as Verser suggests , most of the errors are because the file paths are incorrect
10 years 7 months ago #72012 by gizmo6023
Thank You Verser,
Probe is now working as expected.
Can I adjust the rapid value to something slower without causing more problems?
10 years 7 months ago #72014 by verser
gizmo6023 wrote: Can I adjust the rapid value to something slower without causing more problems?
Of course, you can set to any value by changing the setting RAPID_SPEED in .ini
Time to create page: 0.210 seconds
