Work with probe
- okiejim
probe does not have time to move up when it moves to the side and then says probe already tripped or something like that. I have been keeping the parameters at the default because I really don't know that they really do yet. When I figure this out I will post my fix. Thank you so much for this creation and fun thing to explore.
- Wirewrap
EDIT:
I just found them, they are HAL pins.
- csbrady
- Thank you received: 10
The following change to probe_screen.py fixed my problems:
Orig:
def ocode(self,s, data = None):
self.command.mdi(s)
self.stat.poll()
while self.stat.exec_state == 7 or self.stat.exec_state == 3 :
if self.error_poll() == -1:
return -1
self.command.wait_complete()
self.stat.poll()
New:
self.command.mdi(s)
self.stat.poll()
while self.stat.interp_state <> linuxcnc.INTERP_IDLE :
return -1
time.sleep(0.1)
self.stat.poll()
- LearningLinuxCNC
- Thank you received: 39
okiejim wrote: I have the same issue. Being new to this package I am sure it is what I am doing wrong. It seems very erratic. Seems like the
Sounds like you possibly have the probe connected incorrectly in HAL. If you open halmeter and look at the pin motion.probe-input it should be false unless the probe is tripped. It sounds like motion.probe-input is true unless the probe is tripped.
If that is not it then you may have to add a debounce component between the original input pin for the probe and the motion.probe-input pin to take any electrical or mechanical noise out of the probe signal.
Jim
- Wirewrap
After that error, no parameters can be changed, the input box in the panel changes, but the corresponding ps_ variable does not change as seen in the Halconfiguration watch window.
- auto-mation-assist
- Thank you received: 81
