Work with probe
8 years 11 months ago #102479 by Mech john
Replied by Mech john on topic Work with probe
Hi Ken,
many thanks. I will have a play with it.
cheers,
john
8 years 11 months ago #102488 by Mech john
Hi Chris,
thanks for the reply. Sorry for asking a stupid question but I tried to apply the patch file and could not. I put it in the same directory as my probe_screen.py file and used ´patch < probe_screen.patch' I got the error message 'reversed or previously applied patch detected'. What am I doing incorrectly, how else do I apply the patch?
many thanks,
john
8 years 11 months ago #102489 by csbrady
Replied by csbrady on topic Work with probe
[John,
It's been a while since I looked this and Is was not remembering correctly what I had done. I had two different problems. The "must be in MDI mode" error ended up being an issue with Gscreen and not with the probe code. If your using Gscreen I have a fix. Perhaps a similar problem has been introduced in another GUI. Are you using Axis?
The other issue was the probe functions returning before the probe sequence had completed. My patch fixes that but as far as I can tell I am the only one that experienced that problem. So in short the patch probably will not help you.
8 years 11 months ago #102490 by Mech john
Hi Chris,
I am using axis. The probe stuff was working fine before I upgraded to latest linuxcnc a couple of days ago. I have it as a tab I click - this is Gscreen?
cheers,
john
8 years 11 months ago #102494 by csbrady
I suspect that a change was introduced in Axis that is causing the problem. I am using a modified version of Gscreen and there was code that changed the mode when the interpreter went idle. Gscreen was changing the mode to manual and the probe functions were trying the set the mode to MDI. Maybe similar code got added to Axis.
A good start would be to look at a diff of the old and new axis files.
8 years 11 months ago #102509 by Mech john
Hi Chris,
there a quite a few axis files. Any idea where to start or more simply who might know about this?
I find it hard to believe I am the only one using this probe screen with the latest version having this problem.
how do i test your idea is there some way i can see the mode that axis is in?
cheers!
Time to create page: 0.387 seconds
