Z axis cuts in the air - not plunging
6 years 1 month ago #180823 by Clive S
Jeff65 wrote: changing the scale to -ve makes the other axis reverse as well it seems
It should not
6 years 1 month ago #180824 by Jeff65
I'm not using stepconfig anymore I manually edit the INI file
6 years 1 month ago - 6 years 1 month ago #180825 by Clive S
Jeff65 wrote: I'm not using stepconfig anymore I manually edit the INI file
Ok that's good. All the axis are independent of each other.
Does pressing page down make the z axis go down or up. It should go down
Did you correct the spelling in the ini file
Last edit: 6 years 1 month ago by Clive S.
6 years 1 month ago - 6 years 1 month ago #180827 by Jeff65
I have now swopped 2 wires and set Home_offset to -1
pressing page down now makes the spindle come down and it matches what is on the screen.
However, if i press the 'home all' button the spindle goes the opposite way to the switch which is at the top end of the travel
I have also corrected the 'H' that was missing
Last edit: 6 years 1 month ago by Jeff65.
6 years 1 month ago - 6 years 1 month ago #180828 by Clive S
Jeff65 wrote: I have now swopped 2 wires and set Home_offset to -1
That's good. Now you need to change the sign in home search vel to -
HOME_SEARCH_VEL = 1.000000 ##### changing the sign make the motor go opposite ie -1.0000
HOME_LATCH_VEL = 0.050000 ##### the same with this it should hit the switch and then back off
OME_FINAL_VEL = 2
The numbers are the speed it will move at in units per second ie 1.0000 will be 60mm per min
6 years 1 month ago #180829 by Mike_Eitel
Sorry guys, i disslike all those changes. And yes, hecan do as you propose and it will work.
BUT
The question in my eyes is his code generator. I think most are setup to have the starting plane on top, with a value near to zero. Than dig into material with negative values. His code increases, like a sliced peace.
Jeff I would have a look to the gcode generator to invers his behaviour.
Mike
Time to create page: 0.418 seconds
