Z axis cuts in the air - not plunging
6 years 1 month ago #180920 by Jeff65
When you say reload - do you mean 'homing'
I haven't been able to home since everything went to pot
6 years 1 month ago #180922 by Clive S
Jeff65 wrote: When you say reload - do you mean 'homing'
No. when you edit any files you need to restart linuxcnc. Not the PC
Forget homing until you have the z axis searching in the correct direction to the switch
6 years 1 month ago #180923 by Jeff65
OK - I did those 2 changes and homed the Z axis and it homed ok
pressing page up makes the spindle go down and page down goes up
But the screen motion is correct
I know how to re set the keys on the key board so thats not a problem to me
6 years 1 month ago #180925 by Clive S
That's strange where is your homing switch located should be at the top.
6 years 1 month ago #180926 by Mike_Eitel
When it comes to the keys.
They are always "connected" to the workpeace, not to the machine. Means f.x. you press the left arrow, table moves to the right. = your tool will make his way into the peace direction left..... You will get used to that ;-)
6 years 1 month ago #180927 by Mike_Eitel
I have no home on z at all... I think you only need that it you can work with fixed tool lenght. I use only z-min as safety shut off.
Time to create page: 0.443 seconds
