- Thank you received: 486
Jeff65 wrote: Z axis part of ini file
[AXIS_2]
TYPE = LINEAR
HOME = 0
MAX_VELOCITY = 12.5492060976
MAX_ACCELERATION = 13.0
STEPGEN_MAXACCEL = 16.25
SCALE = 2000.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -75
MAX_LIMIT = 0.001
HOME_OFFSET = -2
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = 0.050000
HOME_FINAL_VEL = 2
HOME_SEQUENCE = 0
Jeff65 wrote: Sorry - I can be a bit dim sometimes.
OK - I put a minus in front of the Scale setting - now if I press page up it goes up and if i press page down it goes down
However it is now reversed on the screen - goes down when you press page up - up when page down is pressed
Tried homing the axis and it goes in the wrong direction.
So I changed the sign in front of HOME_SEARCH_VEL
page up and down still worked fine but on screen was reversed.
It seemed to home ok - but cannot jog the axis down but it will go a little way up- screen problem still there
++Jeff65 wrote: I have played about with settings many times and never got sorted - so I thought I would join this forum and I'm very grateful for your help.
I have already swopped wires on this stepper motor - I can swop them back
Would be happy to talk on the phone if you have the time
I would think its critical to have the screen match up with the motion otherwise I'll be cutting only air again
