- Thank you received: 15
Configuring a Floating Head
- Aldenflorio
- Topic Author
6 years 1 month ago #182324
by Aldenflorio
Replied by Aldenflorio on topic Configuring a Floating Head
Thank you. I would suggest just removing the $ sign. but i should have noticed that sooner
- Aldenflorio
- Topic Author
6 years 1 month ago - 6 years 1 month ago #182330
by Aldenflorio
question. im suing a 7i96 board with proma 150 thc
how do i write the hal pins? and mode 2 correct? i cant seem to find the answer
Last edit: 6 years 1 month ago by Aldenflorio.
6 years 1 month ago #182332
by phillc54
Replied by phillc54 on topic Configuring a Floating Head
Mode 2 is correct.
Input pins would be something like:
Output pins would be something like:
hm2_7i96.0.gpio.008.in
or
hm2_7i96.0.gpio.008.in_not
hm2_7i96.0.ssr.00.out-00
- Aldenflorio
- Topic Author
6 years 1 month ago - 6 years 1 month ago #182335
by Aldenflorio
Ok so i got it all filled out and set up for my machine then i saved the plasmac. it said it saved and should be able to find in the ini file or config files. but nothing changed i dont think. i normally see a panel that show plasmacs status, but i dont have that. here are my ini files. not sure if youll need anything else
6 years 1 month ago #182336
by phillc54
You should have a directory ~/linuxcnc/configs/<machine_name> with your new config in it.
You start it with:
<machine_name> is the name you gave the machine in the Configurator.
You start it with:
linuxcnc ~/linuxcnc/configs/<machine_name>/<machine_name>.ini
- Aldenflorio
- Topic Author
6 years 1 month ago - 6 years 1 month ago #182338
by Aldenflorio
Yeah when I do that it just opens up the software as it’s always look. Like I said I had my machine all configured before doing thins. So it just looks the same. I thought it was suppose to add stuff
Time to create page: 0.060 seconds
