Configuring a Floating Head
6 years 1 month ago #181902 by Aldenflorio
I’m sorry if this is basic or in the wrong category. I have a floating head and switch set up, I also have the proma 150 thc. I planned on using plasmac config (I think that’s its name). I have not set up plasmac yet bc when I started to It suggest you have everything else ready. I have the z axis set to immediate home due to me not having a limit switch for home (I’m using limit switches as shared homes) and since I’m building a plasma cnc there are grates so it can’t always touch off to home.
So I need to configure the floating head without changing the immediate home.
Another issue I’m having. When the floating head switch is triggered then everything stops and it says “error joint 0 limit triggered” or something to that effect.
Linuxcnc 2.9, Mesa 7i96, proma 150 THC. These are my components
6 years 1 month ago #181928 by tommylight
Aldenflorio wrote: When the floating head switch is triggered then everything stops and it says “error joint 0 limit triggered” or something to that effect.
It should say joint 2 or joint 3, not 0, and that is the expected behaviour, but for floating head the switch must be on a separate input from the rest of the home/limit switches.
PlasmaC should be set to mode 2 for Proma, you can use the ArcOK from the Proma but beware that with some plasma cutters that can cause some issues of getting the ArcOK signal before the actual cut has started.
For testing and checking the wiring set the Proma to test mode and check the LED's on the Proma and on screen, make sure they correspond to each other, meaning ArcOK on Proma lights the ArcOK on screen, smae for UP and Down Led's.
6 years 1 month ago - 6 years 1 month ago #181932 by Aldenflorio
It may be joint 2 or 3, I don’t remember. Ok I’ll install plasmac then
Last edit: 6 years 1 month ago by Aldenflorio.
6 years 1 month ago - 6 years 1 month ago #181952 by Aldenflorio
i looked under plasmac and it seems to have recently been updated. Is this guide still correct?
linuxcnc.org/docs/devel/html/plasma/plasmac-user-guide.html
6 years 1 month ago #181971 by rodw
Replied by rodw on topic Configuring a Floating Head
Aldenflorio wrote: i looked under plasmac and it seems to have recently been updated. Is this guide still correct?
You would be better off using V 2.8 which has just become the official release version of Linuxcnc and it includes Plasmac so the correct docs (for 2.8 are here)
linuxcnc.org/docs/2.8/html/
Follow the linkx to Plasmac from there.
6 years 1 month ago - 6 years 1 month ago #181972 by Aldenflorio
rodw wrote: You would be better off using V 2.8 which has just become the official release version of Linuxcnc and it includes Plasmac so the correct docs (for 2.8 are here)
Is there any way to downgrade without losing everything? I have most of the process completed
Time to create page: 0.117 seconds
