Configuring a Floating Head
16 Sep 2020 05:09 #182355 by phillc54
Replied by phillc54 on topic Configuring a Floating Head
Netmask should be 8, I dont think you need a gateway or DNS.
Can you ping the 7i96?
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Sep 2020 05:11 - 16 Sep 2020 05:12 #182356 by Aldenflorio
Replied by Aldenflorio on topic Configuring a Floating Head
I can ping 10.10.10.11
Last edit: 16 Sep 2020 05:12 by Aldenflorio.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
16 Sep 2020 05:14 - 16 Sep 2020 05:14 #182357 by Aldenflorio
I can also ping 10.10.10.10
Last edit: 16 Sep 2020 05:14 by Aldenflorio.
16 Sep 2020 05:17 - 16 Sep 2020 05:22 #182358 by phillc54
Hmm, if you can ping 10.10.10.10 then you can "see" the 7i96.
I don't know why it won't load, hopefully someone else will chime in...
Last edit: 16 Sep 2020 05:22 by phillc54. Reason: missed second "." in IP address
  • Aldenflorio
  • Platinum Member
  • Platinum Member
16 Sep 2020 05:21 - 16 Sep 2020 05:21 #182360 by Aldenflorio
Hopefully. Thank you for all your help. I’ll post my config just for reference in case some come to see it overnight. Tommylight I believe knows about Mesa boards, they might be able to help.
Last edit: 16 Sep 2020 05:21 by Aldenflorio.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
16 Sep 2020 05:24 - 16 Sep 2020 05:25 #182361 by Aldenflorio
Check this out, I tried opening it a different way and it seems like I got a different message. There are 3 pictures
imgur.com/a/ErB4qzg
Last edit: 16 Sep 2020 05:25 by Aldenflorio. Reason: Bc it won’t let me check the notification box in the original making of the post. Which is annoying and rather stupid
16 Sep 2020 05:26 #182362 by phillc54
Can you post your new HAL file?
  • Aldenflorio
  • Platinum Member
  • Platinum Member
16 Sep 2020 05:27 - 16 Sep 2020 05:27 #182363 by Aldenflorio
File Name: plasma_cutter.hal
File Size:11 KB
did you look at the error message?
Last edit: 16 Sep 2020 05:27 by Aldenflorio.
16 Sep 2020 05:31 #182365 by phillc54
Comment out this line:
net dout-01     <=  motion.digital-out-01
You have:
hm2_7i96.0.gpio.003.in
connected in this HAL file and also somewhere else, probably in plasma_cutter_connections.hal. It can only be used once.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
16 Sep 2020 05:33 #182367 by Aldenflorio
I'm not sure i understand what you're asking me to do, sorry
Time to create page: 0.529 seconds
