Configuring a Floating Head
21 Sep 2020 02:30 #183028 by phillc54
Replied by phillc54 on topic Configuring a Floating Head
Multiple configs are no problem.
Did you check completely through the file to make sure that pin name does not appear somewhere else?
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Sep 2020 02:49 #183029 by Aldenflorio
Replied by Aldenflorio on topic Configuring a Floating Head
I just checked the ini file, the Hal file, and the Hal connections file. It’s not repeated. Should I zip my config over?
21 Sep 2020 02:53 #183030 by phillc54
Yep, zip it and post it here.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
21 Sep 2020 02:58 #183032 by Aldenflorio
here it is
File Name: the_plasma...tter.zip
File Size:590 KB
21 Sep 2020 03:19 #183033 by phillc54
Try this file.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
21 Sep 2020 03:27 #183034 by Aldenflorio
Seems to have the same issue
imgur.com/a/Nznryam
21 Sep 2020 03:34 #183035 by phillc54
Are you sure then that the config directory you posted IS the config directory you are trying to run?
  • Aldenflorio
  • Platinum Member
  • Platinum Member
21 Sep 2020 03:36 #183036 by Aldenflorio
Positive
  • Aldenflorio
  • Platinum Member
  • Platinum Member
21 Sep 2020 03:41 #183037 by Aldenflorio
Maybe my plasmac is broken? I could delete all configs and start over
21 Sep 2020 03:43 #183038 by phillc54
Well then I have no idea where it is getting that pin assignment from.
Are you sure you copied the file I sent to you into this directory /home/users/linuxcnc/configs/the_plasma_cutter/
Time to create page: 0.271 seconds
